Question about Mach Speed Trio STEALTH-7CM4.0 triostealth7cm tablet computer
Can't connect to internet
I just bought a trio stelth and i can't get internet!
  • Mach Speed Trio Master
  • 27,725 Answers
Im not sure these devices but if it has an operating system and cant get an internet connection
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Posted on Jan 15, 2013
How do I reset my trio stelth G4 7.85
Have you tried using the reset button on the tablet? Manual can be found here: http://www.manualslib.com/manual/749979/Trio-Stealth-G4.html
Feb 05, 2015 | Tablets & eReaders
Can not connect to internet
Check and see if the WI-FI is activated.
Dec 31, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
Trio stealth pro 4.0 will not connect to the internet
You can try to go online on a different computer download compatible driver save to sd card then reboot your tablet . Id try a hard reboot first too see if that works
Dec 25, 2013 | Mach Speed Trio 4GB 7" Trio Stealth Pro
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Hello, We bought X6 TRIO from usa. We live in
You will have to look at the machine. It should say the voltage it operates on. I would use a transformer unless I'm sure.
Aug 21, 2013 | FrancisFrancis! X6 TRIO
My Trio Stealth Pro 7 in. Internet Tablet will not connect to my wi-fi.
I HAVE AN TRIO STELTH PRO.I AM ON RR INTERNET.I CANNOT CONNECT TO INTERNET NOR WI-FI AT HOME BUT I CAN TAKE IT TO MY DAUGHTERS & IT WORKS FINE.ALSO MY LAO TOP WORKS OK ON MY WI-FI.IT IS BLOWING MY MIND.THANKS TROY PRUITT
Jan 30, 2013 | Mach Speed Trio 4GB 7" Trio Stealth Pro
Is there an operator's manual for the trio stealth 9.7 tablet?
Hope this helps: Link HERE
I was looking for the same things with little to no help.
Jan 21, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
Mach Speed Trio STEALTH-7CM4.0 triostealth7cm tablet computer Logo
55 people viewed this question
Top Mach Speed Trio Computers & Internet Experts
k24674
juanmireles1
Tom Chichester
Are you a Mach Speed Trio Computer and Internet Expert? Answer questions, earn points and help others
