Question about Nordic Track Incline Trainer X9i Interactive
X9i Calibration failed - Nordic Track Incline Trainer X9i Interactive
Died during exercise
Computer panel is possibly dead. I had them send me a completely new panel for my x9i. I was under warranty, though. It's actually pretty easy to install yourself, with their instructions and another person.
Jul 22, 2014 | Nordic Track Incline Trainer X9i...
I just got my Nordictrack X9i treadmill and assembled it. When I turn it on it will not boot up and says it has an update error. That's all I get nothing eles and nothing will work. Does anyone have any...
Have you connected the tablet to the internet via WiFi? As I am reading on your treadmill it has the ability to connect to internet and that maybe what it is looking for, so it can update itsself.
Jan 24, 2014 | Nordic Track Incline Trainer X9i...
My x9i gives off a burning smell and rattle when running .
I also have an X9i treadmill hardly used .smells like its burning. It also is not acting right while on it. Whats causing this? it cost $2000.00 no joke I thought Norditrak was a better company. I purchased it from Back country.
Aug 15, 2013 | Nordic Track Incline Trainer X9i...
I just bought a Nordic Track X9i incline trainer. Started working well, however after a few hours of use I cannot use any control keys and belt and incline does not work. The touch screen display works but...
You should immediately replace the console. That console will just keep getting worse. This is endemic of this brand, however it usually happens a lot further in the life of the unit. When you call Nordictrack have your model number.
Aug 11, 2013 | Nordic Track Incline Trainer X9i...
X9i incline trainer clicking
Step 1:
RUN the calibration software . and fix it. God bless you
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 2:
Feb 07, 2013 | Nordic Track Incline Trainer X9i...
Nordic Track x9i screen stuck in boot
Disconnect wifi and boot machine. This works well for a non-internet workout. I had a similar problem--endless looping of the boot up routine--which ultimately fixed itself when I tried updating. I believe they came out with a new update which must have fixed some bug in the system.
Dec 16, 2012 | Nordic Track Incline Trainer X9i...
Ifit console will not load keeps running in a loop?
try to RUN the software calibration, see your instr. manual how to enter and proceed for easy diagnose, troubleshooting, and fix it.
God bless you
Dec 11, 2012 | Nordic Track Incline Trainer X9i...
Nordic track X9i controls not responding
Dear Sir:
Adjust the reed switch, see the diagram attached, clean, and tight the connector very well.
Anyway I recommend to call the service Help, in the place where you did buy your treadmill.
However you can RUn THE SOFTWARE calibratin for diagnose, troubleshootin, and fix it, follow the steps in your instructions manual.
sincerely. God bless you
May 07, 2012 | Nordic Track Incline Trainer X9i...
Nordic Track Incline Trainer X9i Interactive Logo
87 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
