Question about Dell 5110cn Laser Printer
The screen is saying "reseat fuser" - "contact support" What does this mean?
I printed a page on Friday and since then, I get this message and the printer won't print.
Corysf62
  • 188 Answers
SOURCE: Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Posted on Sep 28, 2008
  • 3 Answers
SOURCE: ERROR CODE 010-387 RESEAT FUSER
I had the same exact issue with my 5110cn printer. It turned out that the 5100 fuser is wrong for this printer and will not work. The 5110 has a circuit board on the inside and the 5100 fuser does not. Dell item number KX491 with a BCN # of 652423 works perfectly.
Hope this helps!
Posted on Jan 20, 2009
cene765
  • 787 Answers
SOURCE: my printer says printing alignment and prints out
For alignment complete you need both print cartridges printing all colors.If you have empty cartridge or clogged cartridge alignment will not complete.Look which color missing and replace cartridge.
Posted on Nov 16, 2009
brett207
  • 231 Answers
SOURCE: Dell printer will not print. Receiving message: fuser error
Fuser error usually means that the heater element has blown, or is not functioning properly.
The device will usually lock itself out to prevent any risk of overheating and causing a fire
You will need a technician to fix this
Posted on Feb 02, 2010
  • 903 Answers
SOURCE: dell 725 printer wont print after windows 7 install
You need the correct drivers for the printer. Go to Dell's support page and download and install the Windows 7 driver.
Posted on May 28, 2010
Hp t1100 error 50.2
nstructions
  1. Remove the printer from any UPS supplies, additional power supplies, or power strips.
  2. Plug the printer into a wall outlet to check whether this resolves the problem.
  3. If the printer is already plugged in, try another power source in the building independent of the one being used.
  4. The line voltage and current source at the printer location might need to be inspected to make sure that it meets the printer's electrical specifications.
  5. Turn the printer off then on.WARNING: Be careful when removing or reseating the fuser. Temperatures can reach 400+ degrees Fahrenheit.
  6. If the message persists, turn the printer off for 30 minutes to allow it to cool, then reseat the fuser after checking the internal wiring connections on the right and left side, ensuring that these connections are properly seated.
  7. If the 50.1 or 50.2 error recurs after power-cycling the printer or when trying to print, try installing a known good fuser from another HP LaserJet 4100 series printer, if available.
  8. If the fuser is near or at the end of its estimated life expectancy (approximately 200,000 pages), then replace the fuser. After replacing the fuser, print a Configuration page, a Menu map (shows fuser settings), an Event log, a Supplies status page, and a Usage page, to reference the status of the new fuser and to ensure that the previous fuser settings are in place with the replacement fuser. To print an Information page on the HP LaserJet 4100, perform the following steps
    1. Press the MENU rocker key until INFORMATION MENU appears on the printer display.
    2. Press the ITEM rocker key until PRINT CONFIGURATION (or until PRINT MENU MAP, etc, appears in the printer display.
    3. Press the SELECT button to print the selected information page.
    To print an information page on the HP LaserJet 4100MFP, perform the following steps
    1. Press the MENU button.
    2. Press the DOWN Navigation button until INFORMATION is highlighted.
    3. Press the RIGHT Navigation button.
    4. Press the DOWN Navigation button to highlight PRINT CONFIGURATION (or PRINT MENU MAP, etc, appears in the printer display.
    5. Press the SELECT button, the button with the checkmark on it to print the selected Information page.
  9. If 50.x errors persist after properly installing a known good fuser, or if the errors follow the questionable fuser (provided it is not near the end of its estimated life expectancy), contact HP for further assistance.
Removing and replacing the fuser
Mar 23, 2013 | HP Designjet T1100 Photo Printer
55.0 printer error
Error 55.A is an internal communication error. It typically indicates a communication error between the formatter and the DC controller. The most common cause of this error is normally related to the fuser.
Some steps to try:
1. Turn off and turn on the printer to clear the error message. If the error returns after doing this, then, check external printer connections.
a) Remove the formatter.
b) Reseat any memory DIMMs and EIO cards.
c) Reseat the formatter.
2. If the printer has a duplexer installed, remove it. Turn off and turn on the printer, and see if the error clears. If the error clears, then, the duplexer PCA may be defective. Replace the duplexer.
NOTE: With a worn fuser, the 55.A error usually manifests itself while duplexing, however in extreme cases, the error could appear without a duplexer.
3. Verify that there is no issue with the site power. If the printer is on a surge protector or a UPS, remove it, and plug the printer directly into a wall outlet. If the printer is plugged directly into a wall outlet, try it on another outlet, preferably one that is on a different circuit.
4. Print a PCL configuration page to verify the number of pages since last maintenance. If the printer is close to the 350,000-page service interval, then install a maintenance kit.
If the service interval is not near the 350,000-page interval, then, replace the fuser.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 09, 2012 | Office Equipment & Supplies
My Dell 3110 Colour Laser Printer comes up with the following message - Reseat Fuser Contact Support 010 - 390 Restart printer
There's not much on the web about this error message, but it does say to reseat the fuser. I found a writeup (with a picture) on how to do this.
http://en.community.dell.com/support-forums/peripherals/f/3528/p/19309114/19606748.aspx
Make sure that your printer is unplugged while you do this, also be aware that the fuser gets quite hot while it's printing and stays hot for a few minutes afterwards. Don't burn yourself! While the fuser is out you may want to blow out the dust from the printer with a can of compressed air.
If reseating the fuser doesn't get rid of the error message call Dell technical support at 1-877-293-1197.
Hope this helps
Please rate this solution, thanks!
Mar 09, 2011 | Dell 3110cn Laser Printer
THE 942.02 Service Yellow TMC Sens message is in the screen. What does it mean. It will not let me print
Error indicates a problem with the Cyan toner cartridge/developer. Try the following steps:
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page. Did the error message return? Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Try printing another test page, verify if you're still getting the same error. It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
For further assistance, please contact Lexmark Technical Support Center.
Jan 27, 2011 | Lexmark C540N PROD SPECS TBD Printer
Paper Jam? Print quality
If the toner wipes off the printed pages, then the fuser is the problem....not hot enough or enough pressure to heat the toner to the paper. I would try to reseat the fuser...make sure it is making good electrical contact. I have also seen the paper actually wrap around the fuser roll, which would cause the same symptoms...be careful removing the paper if that has happened...the fuser roll can be easily damaged !
Jan 22, 2009 | HP LaserJet 2840 All-In-One Printer
RESEAT FUSER
Hi G,
99% of the time the error is the fuser. Either it is damaged, or just not locked in place, and with power off, reseating it will fix the error. Since you just replaced the fuser, I guess the question is did you do it because it was also giving this error, or because it reached EOL ( end of life ).
If it was for EOL message, I would try reinstalling it. If the "reseat fuser" error goes away, but comes back with the new fuser again, then the new fuser you purchased is defective and should be returned or exchanged.
See the information below to correctly troubleshoot your issue.
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
In most cases, the fuser itself is the problem. If you tried to reseat or replace the fuser while power was still on, the LVPS could have been damaged just as if there were an electrical storm.
Hopefully this helped.
Oct 28, 2008 | Dell 5100cn Laser Printer
HP Laser Jet 2840 50.2 Fuser Error
Usually this means that the fuser is not heating to the correct operating temperature. Remove the fuser and check all contacts. Be careful it can be very hot. Always let it cool down for atleast 30 minutes before touching the face of the fuser. After you check it over and clean off any contacts, reseat the fuser back into the printer. Plug it back in and turn the printer on. If this doesn't work and you still get the error, the fuser needs to be replaced.
Apr 12, 2008 | HP LaserJet 2840 All-In-One Printer
010 397 Error Message on Dell 5100cn
Apr 04, 2008 | Dell 5100cn Laser Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
Dell 5110cn Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
