Question about Dishwashers
Bosch dishwasher doesn't cycle
We got our dishwasher about a year and a half ago. Apparently this is just long enough to be out of warranty. Bosch wants about $600 to come out and fix this thing but for that money I would rather get a new one (it will NOT be a Bosch). Anyway, I figure I've got nothing to lose but I'm gonna need some help. When you turn on the dishwasher it hums and makes noise and sprays a little water around in the bottom (there is about 1/2 a cup of water in the bottom that won't drain). Anyway, we called Bosch. One tech told us that it was the motherboard going bad. Another guy told us that it was the circulating pump. When they told us that it was going to cost roughly the same amount as what we paid for it to begin with I said nevermind. I'll do it myself and take my business elsewhere. Can you guys point me in the right direction to: 1) get this thing diagnosed correctly 2) get the right parts and get it fixed Thanks in advance for the help! -Jon
  • 1 more comment
  • jonvh
    jonvh Jan 14, 2013
    By the way, this is a Bosch SHE43F16UC/60
  • jonvh
    jonvh Jan 15, 2013
    it turns out I've got a bad fill valve
  • jonvh
    jonvh Jan 16, 2013
    My fill valve has a bad disconuity. This video helped me troubleshoot. Ordered a new part from Sears. Sears is great because they have online manuals with exploded views to make sure that you got the right part.
  • 54 Answers
SOURCE: Bosch Dishwasher
what is the model #?... there are 2 buttons when pushed together it will drain the water out..try the button to the left next to power scrub... and economy...hold the 2 buttons for 3 sec. you will hear you drain pump running.. if you don't hear any water draining out into your sink, you might have a clog d/w drain line.
Posted on Jun 25, 2008
  • 478 Answers
Replace the fill valve that sound is it trying to open
Posted on Mar 12, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
  • 205 Answers
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Posted on Jul 21, 2009
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
What doesn't my dishwater finish its cycle?
What is the make and model number
Jun 09, 2013 | Dishwashers
Bosch dishwasher makes noise but doesn't start
When you start a wash cycle on your Bosch dishwasher and it does not work, stay calm. It could be something simple, especially if you just installed it. Make sure the power cord is connected properly and a circuit breaker did not trip. How to Troubleshoot Bosch Dishwasher That Doesn Fill With Water
Sep 25, 2017 | Bosch Dishwashers
The heating cycle has changed and there is now a shorter cooler activity
the fan is probably busted. may just need to replace the fan. but if its washing the dishes fine and drying them , then you probably shouldnt worry too much about it.
Nov 20, 2011 | Bosch 24 in. SGS43C12 Classixx...
Hi, we have a Bosch SHU53EO6UC/14 dishwasher. It is getting stuck in wash and isn't advancing. We think it may be the timer but there are lots of references to running a test program. Unfortunately...
My Bosch DW SHU5302 also got stuck during a cycle and ran and ran. Turns out this is a known problem with these DW's. The problem is that a trace on the main board burns off that controls the heater. If the heater doesn't come on then the DW keeps running waiting for the water to heat up. Re-soldering this trace fixes this problem. If you get a repair guy out, he will only change the board. They are not allowed to re-solder which doesn't fix the problem for long as the same trace will burn off. Did this about 8 years ago and it is still fine.
Aug 29, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
I have a Bosch SHE4AM15UC Dishwasher that short cycles. After about 2 minutes it quits and the clean light comes on. The unit doesn't fill with water and the soap dispenser does not open when this...
they will send out an engineer not supply you the part while still under warranty if you fit parts under warranty you will in validate it get the engineer out.
Mar 03, 2017 | Bosch SHX65P05UC Dishwasher
My Bosch is only a few months old and it won't drain the water.The filter is fine. It's a shea43p16uc60.
Your bosch washer should still be under warranty:
  • Limited warranty, entire appliance, parts and labor (1 year)
  • Limited warranty for non-electronic components; parts only (1st to 2nd year)
  • Limited warranty for control board (microprocessor); parts only (1st to 2nd year)
  • Limited warranty for motor or any component of the motor (1st year to 10th year)
May 19, 2011 | Bosch SHE43P16UC Builtin Dishwasher
I bought a new bosch dishwasher less than one year ago, and it doesn't clean my dishes because the lid on the soap dispenser will not open during the cleaning cycle. Please help SAP! Thank...
Try cleaning the latch that holds the door. After a year the detergent will build up on the spring causing it not to open. If that doesn't do it call the people who you bought it off of. It should have a extended warranty for a year.
May 14, 2011 | Dishwashers
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
Bosch Dishwasher
you have a 3 year warranty on bosch dishwashers
Jan 01, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
