Question about AT&T High Speed DSL Modem
Are you able to work on computer from your end to solve connection problem
    Brigadier General:
  • 10,406 Answers
Yes, if the "problematic" computer still has an Internet connection, then one can use a tool like "Remote Desktop Protocol" to connect over the Internet to the computer.
Posted on May 27, 2009
On gateway w350i laptop screen comes on white computer works fine plug in HDMI and no issues please help
looks like you have a defective screen. Disconnect the screen and connect it back in, it might solve the problem. Otherwise you might end up changing screen.
May 24, 2014 | Computers & Internet
Call end button was not working in micromax x600
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Dec 07, 2012 | Cell Phones
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
HP 1550E Desktop soon as you turn it on the fans come on and the Monitor goes to sleep ....I have replaced the power supply, Mother Board checked all the connections and still have the same problem,,,HELP
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they might be faulty:
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Jul 01, 2011 | HP Computers & Internet
My wd3200bpvt is not working now...how to solve the problem because there have many important files inside the hardb disk...
you have not stated what is not working so i have to guess you need an overhaul
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 23, 2011 | Western Digital WD Scorpio Blue WD3200BPVT...
The universal cord, one end goes into LCD the other into computer, the end going into the LCD needs to be wiggled a lot to get the connection to work. Will a new cord solve the problem?
Does the universal cord go into the rgb1 , rgb2 or S video input.
if it's the rgb input, swap to the other rgb input.
otherwise borrow a cable from the neighbours computer and try that.
if the wiggling is still needed then that socket on the LCD has dry joints on the pcb inside
Mar 18, 2011 | Panasonic PT LC75U Multimedia Projector
My monitor shuts down (I mean goes to sleep) immediately when I turn on the computer......how to solve this??? ziaudeen
hope this will help
don
Feb 19, 2011 | Microsoft DCL 9A+ 19" LCD Monitor
No problem just purchased and going online for 6 months tech support. can't seem to find out how to do this
haaa, HP offered on-line services if only if you pay...but it won't do any good because it only could solve low-end user problems who don't know how to connect computer to router/modem, who don't know how to stop invader steal their internet services(most low-end users even didn't know it) thru wireless router...
uless your computer still could run internet at least O.S/Bios, beyond that you can't solve your problem by on-line services, or phone-services.
Sep 14, 2010 | Computers & Internet
Can the Boston BA 7900 be converter to use with TV or DVD Player?
Yes, but so far I can only get the 2 front speakers and subwoofer to work.
You need a wire that converts a headphone-style jack (like the green one with the Boston speakers) into a red and white AV connection (typical CD/DVD, etc. connection). I've had this connector for a long time and I'm guessing it's under $15. You connect the green Boston speaker connection to the converter end (mine connects to the back end of the headphone-jack (which has a hole for the connection) and the red/white AV connectors to your TV.
I'd been trying to solve the problem too for a long time. Only problem is that I can't get all 5 speakers to work because I think the red/white connector doesn't work with all 5 speakers. I have yet to figure out how to make all 5 work, but the system gives great sound anyway. You will have something like a 5.1 system with your computer speakers, the Boston speakers and subwoofers.
One more issue is that if you connect it directly to the TV, you have to manually turn the Boston speakers on and off.
Nov 06, 2009 | Boston Acoustics BA7900 Computer Speakers
HTC Touch Pro has stopped syncing with computer
I had the same problem go to settings connections and usb to pc and make sure you dont have the (enable advanced network functionality) box checked this solved my problem.
Mar 25, 2009 | HTC Touch Pro Smartphone
AT&T High Speed DSL Modem Logo
142 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
