Question about Vehicle Parts & Accessories
Neither of the 2 provided remotes will arm/disarm, lock/unlock the system.
Purchased this system for my wife's van over 6 years ago - finally got around to installing it this weekend - yes, it sat on a shelf for 6 years. After installation, the unit appears to operate properly: I can get it into and out of Valet mode correctly and the doors lock when the ignition is turned on and unlock when the ignition is turned off - a default setting. Following the instructions in the owner's manual, I can get the system into programming mode using the key and Valet/Programming button but after that it does not appear to accept any input from the remotes - even with the remote right beside the antennae. I have replaced the batteries in the 473V remotes and followed the instructions in the manual (as well as numerous postings on the net) for resynching the remotes - no joy. Is there a way to test the remotes and or a sure fire way to synch them with the unit?
  • Gordon Blackett
    Gordon Blackett Jan 14, 2013
    In case it gets "lost" - the system is a Viper 310HV.
  • 625 Answers
First make sure that the antenna cable is plugged into the brain then, make sure that the antenna cable is plugged into the antenna.
Now, turn the ignition on, press and release the valet switch then press and hold. While holding the valet switch, press and release the lock button on the remote. The system should respond with a long chirp. repeat for second remote.
Posted on Jan 17, 2013
  • Gordon Blackett
    Gordon Blackett Jan 18, 2013
    Thanks for the response. Unfortunately it didn't help. This unit (310HV) does not have a removable antennae. I opened the unit and confirmed that the antennae was firmly soldered to the board. The re-synch procedure you describe is exactly what I have tried a number of times with no success. I had Directed Electronics support on the line while performing this procedure and instead of accepting the response from the remote, the system just eventually times out with one short and then one long chirp. DEI says it;s either a faulty unit or faulty remotes (big help there...). I'm currently trying to borrow a compatible remote locally to test. Neither DEI nor the store where I purchased the unit will honour the warranty as I did the install myself (20 years as an IT Manager doesn't rate). Thanks again.
doin12volt
  • 233 Answers
SOURCE: intermittent arm/disarm of Python model 560XV
this "could" be a bad ground, however, usually when these units lose ground, they activate the siren at a really low level, because they are trying to ground through the siren.
I would say to check where the antenna plugs into the main unit,(brain) but honestly, in 17 years of dealing with DEI alarms, 99.9% of these problems are due to the transmitter - it may blink the LED like it is supposed to, but that doesnt gaurantee it is sending a signal. I would recommend buying a new transmitter and programing it to the brain.
Posted on Jan 15, 2009
  • 87 Answers
SOURCE: Python 990 isnt locking or unlocking my doors .
Its going to be either the wires going to the locks or the programming in the alarm. The only way to tell is to get the wiring tested. A plug could have just pulled out also. Do many variances for one straight answer.
Posted on Jun 04, 2009
SOURCE: Scytek 5100 RS-2W system Problem
How do you reset the remote, alarm. I have a scytek two way security alarm, remote start. I can lock and unlock my vehicle, however the remote start and alarm won't work. When I press the middle button to have the car start it just beeps, and when I lock my car it just locks it doesn't beep to let me know the alarm is on.
Please advise, do I need another alarm, or just reset it.
Claudia
Posted on Mar 02, 2010
richroth
  • 9472 Answers
SOURCE: I have a PR00E4BS 4-button
Here is a link to the programming guide for the remote Here is a link to the manual Here is a link to the installation guide
Happy Holidays
Posted on Dec 12, 2010
  • 63 Answers
SOURCE: We just realized that the previous owners of our
Any valet switch will work. Then simply program your remote. As long as you have a DEI remote there should be no problem unless you are trying to program a two way remote (pager) to a one way system (non pager)
Posted on Jan 10, 2011
Service immobilizer light is on an car wont start. It's a 2004 Pacifica
You are using an outdated browser. Please upgrade your browser to improve your experience.
Electrical • Vehicle Theft Security • Description Report a problem with this article
DESCRIPTION
VEHICLE THEFT SECURITY SYSTEM
The Vehicle Theft Security System (VTSS) is designed to protect against whole vehicle theft. The system monitors vehicle doors, and ignition action for unauthorized operation.
The alarm activates:
  • Sounding of the horn
  • Flashing of the headlamps/park/tail lamps
  • An engine kill feature (with SKIS)
SENTRY KEY IMMOBILIZER SYSTEM
The Sentry Key Immobilizer System (SKIS) is designed to provide passive protection against unauthorized vehicle use by disabling the engine, after two (2) seconds of running, whenever an invalid key is used to start the vehicle. The SKIS is active whenever the ignition is on and does not require any customer intervention. The primary components of the system are the Sentry Key Remote Entry Module (SKREEM), Sentry Key (ignition key with a transponder molded into the head), indicator light, Body Control Module (BCM), and the Next Generation Controller (NGC). The SKREEM is mounted on the ignition switch/lock cylinder assembly with the molded, integral antenna mounted around the ignition housing. The indicator light, is located instrument panel switch pod, just to the right of the instrument cluster.
Electrical • Vehicle Theft Security • Operation Report a problem with this article
OPERATION
Upon failure of proper SKREEM communication to the Next Generation Controller (NGC), the NGC will shut off fuel after two seconds of run time. The engine will not re-crank on the key cycle that the failure occurred, a full key down sequence must be performed for the engine to crank again. After six consecutive fuel shut-offs, the engine will no longer crank on subsequent key cycles. The failure must be corrected and a valid communication process between the SKREEM and the NGC must occur for the engine to crank and start again.
The electronics for the VTSS are part of the Body Control Module (BCM). The system is armed when the vehicle is locked using the:
  • Power door lock switches (with any door ajar)
  • Remote Keyless Entry transmitter.
  • Door Cylinder Lock Switches.
For vehicles equipped with SKIS, the doors do not have to be locked to enable the fuel shut off feature.
After the vehicle is locked and the last door is closed, the set LED indicator in the instrument panel switch pod will flash quickly for 16 seconds, indicating that arming is in progress. If no monitored systems are activated during this period, the system will arm and the LED will flash at a .5 Hertz (Hz) rate. If the liftgate is open, the LED will change its flash rate.
This indicates that the system is armed. If fault is detected on the driver key cylinder input, the indicator LED will remain solid during the arming process, although the system will still arm. If the indicator LED does not illuminate at all upon door closing it indicates that the system is not arming.
Passive disarming occurs upon normal vehicle entry by unlocking either door with the ignition key/remote transmitter. This disarming will also halt the alarm once it has been activated.
A tamper alert exists to notify the driver that the VTSS had been activated. This alert consists of 3 horn pulses when the vehicle is disarmed.
NOTE: The VTSS will not arm by pushing down the door lock mechanism. This will manually override the system.
For Door Cylinder Lock Switch service, (Refer to 8 - ELECTRICAL/POWER LOCKS/DOOR CYLINDER LOCK/UNLOCK SWITCH - REMOVAL).
If the VTSS is triggered, the horn will pulse, headlamps/marker lamps will flash, and the VTSS warning lamp will flash. If BCM determines the threat to be false and the VTSS is not triggered again, the system will shut down and rearm itself after three minutes. If a trigger is still active, the alarm will continue for an additional 15 minutes without the horn. The VTSS monitors the passenger compartment.
NOTE: System will not arm if passenger compartment is not secure.
ARMING THE VTSS - METHOD A
  1. With the key removed from the ignition lock and any door open (excluding liftgate), actuate one of the following:
  • Power door lock button to LOCK,
  • Key fob LOCK button
  • Driver door lock key cylinder to locked position.
  • Close all opened doors. Liftgate can remain open.
  • After the last door is closed, an arming time-out period of sixteen seconds will start, then the VTSS will become armed.
    ARMING THE VTSS - METHOD B
    Actuating the key fob transmitter LOCK button, key locking the front doors with the doors closed and the ignition locked will begin the arming time-out period. If method A, 16 second time-out sequence was in process when method B was actuated, the 16 second time-out will restart from the time of the second actuation.
    If the security lamp does not illuminate at all upon final door closure, it indicates that the system is not arming.
    The current VTSS status armed or disarmed shall be maintained in memory to prevent battery disconnects from disarming the system.
    TRIGGERING THE VTSS
    After the VTSS is armed, the following actions will trigger the alarm:
    • Opening any door (excluding liftgate).
    • Turning the ignition to the RUN position.
  • NOTE: When the VTSS is ARMED, the interior power door lock switch ?UNLOCK? will be disabled until the vehicle is disarmed.
    CAUTION: The VTSS indicator LED will trigger and engine will continue to run if the vehicle is equipped with SKIS and the proper key is used to start the vehicle. This condition will occur if the VTSS has been triggered. If valid key is used, VTSS will disarm.
    CENTRAL LOCKING/UNLOCKING
    This vehicle theft security system feature allows you lock all the doors with the key by using the drivers door lock cylinder.
    All vehicle doors and liftgate are locked with the first turn of the key to the LOCK position from the drivers door. A double activation feature of central unlocking requires you to turn the key in the door lock cylinder to the unlock position two times within two seconds to UNLOCK all vehicle doors at once.
    The first turn of the key in the door lock cylinder will disarm the system (the driver door cylinder lock switch connected to the back of the driver door lock cylinder) and unlock your drivers door. The second actuation within two seconds will then unlock all doors and the liftgate.
    The SKIS includes keys from the factory which are pre-programmed. Each SKIM will recognize a maximum of eight Sentry Keys. If the customer would like to own additional keys other than those provided with the vehicle, they can be purchased from any authorized dealer. These keys must be programmed to the SKREEM on the vehicle in order for the system to recognize them as valid keys. This can be done by the dealer with a DRB III® scan tool or by a customer if this feature is available in their market and they have two (2) valid keys already available to them. The SKIS performs a self-test each time the ignition switch is turned to the ON position and will store Diagnostic Trouble Codes (DTC's) if a system malfunction is detected. The SKIS can be diagnosed and any stored DTC's can be retrieved using a DRB III® scan tool as described in the appropriate Body Diagnostic Procedures manual.
    With the light being on there is a code stored in the computer that controls anti-theft , Your best bet would be to take your vehicle to the dealer !
    Aug 20, 2016 | Cars & Trucks
    How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
    Theft Deterrent Arm/Disarm Modes
    Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
    Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
    Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
    Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
    Changing the Feature Customization Modes
    1. Turn off the IP dimmer switch.
    2. Turn the ignition switch to the LOCK position.
    3. Remove the BCM PRGRM fuse.
    4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
    5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
    6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
    7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
    6.1.
    Insert the key in the left front, right front, or liftgate door lock cylinder.
    6.2.
    Rotate the key from the center to the unlock position.
    6.3.
    Press the horn button on the remote keyless entry transmitter.
    6.4.
    Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
    6.5.
    Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
    6.6.
    Turn the key back to the center position and remove the key from the door key cylinder.
    In order to exit and save the current feature customization modes use the following procedure:
    1. Turn the ignition switch to the LOCK position.
    2. Reinstall the BCM PRGRM fuse.
    If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
    Aug 25, 2015 | Cars & Trucks
    Car alarm goes off 30 seconds after disarm and open a door
    Apparently the alarm is set to passive arming and, once you disarm it, it immediately begins the arming process and it is not registering the door being open. I'm going to go out on a limb and say that the alarm door trigger is wired to the dome light and the dome light is turned off; an issue that occurs with GM vehicles that have a dome light override switch. What's the year, make and model of the vehicle?
    Sep 02, 2012 | AviStart 4400 2-Way Security / Remote...
    Remote start work but door will not unlock or lock!
    Do the doors unlock when the remote starter is not running? If so, then you to connect to a different set of door lock wires.I usually connect to the factory alarm and disarm wires in the driver kick panel. They are blue for arm and pink for disarm. You test them by turning the key in the drivers door.
    Aug 18, 2012 | 991 Responder LC3 SST Security/Remote...
    Car won't start.Theft light blinks,clicking sound under hood and thumping like horn wants to go off.Seems like it's stuck in anti theft mode
    anti theft light should blink every few seconds.
    try disconnecting the battery for 15 minutes.
    Anti-Theft-Perimeter The perimeter anti-theft system consists of the following components:
    • anti-theft indicator (THEFT)
    • remote anti-theft personality (RAP) module
    • hood switch
    • keyless entry remote transmitter
    • deck lid ajar switch
    NOTE: The remote entry features will not function when the ignition switch is in the RUN or ACC position.
    Up to four keyless entry remote transmitters (15K601) can be programmed at one time.
    The keyless entry remote transmitters :
    • Are programmable.
    • Must be set at the same time.
    • House four buttons.
    • House three buttons (Mexico Anti-Theft System only).
    Programming
    Refer to Section 501-14B.
    Inputs and Outputs
    The remote anti-theft personality (RAP) module receives input from the following components for anti-theft operation:
    • Hood switch.
    • Deck lid ajar switch.
    • Keyless entry remote transmitter.
    • Power door lock switches (LH and RH).
    • Door courtesy input.
    The RAP module distributes output to the following for the anti-theft system:
    • Power door unlock relay.
    • Power door lock relay.
    • Liftgate unlock relay (Wagon)
    • Park lamps relay.
    • HORN relay.
    • Dome lamp.
    • THEFT indicator.
    • Deck lid release.
    Arming
    The anti-theft system can be armed if:
    • The ignition switch is in the OFF position.
    • The panic alarm is off.
    • All doors are closed.
    NOTE: If a door is open, the anti-theft system is prearmed and waiting for all the doors to be closed. The THEFT indicator will remain illuminated for up to 30 minutes waiting for all the doors to be closed. If a door remains open after 30 minutes, the THEFT indicator will turn off and the system will return to a disarmed state. After all doors are closed and the 30 second prearm (continuous THEFT indicator illumination) is complete, the system is armed.
    NOTE: If the theft LED does not flash after 30 seconds, check the LED FLASH PID to see if the feature is enabled.
    The anti-theft system will be armed when the lock button on the keyless entry remote transmitter is pressed, all doors are closed and 30 seconds have elapsed.
    When the system is armed, the THEFT indicator will flash quickly until the system is triggered or disarmed.
    Disarming
    NOTE: Using a key in a door lock cylinder to unlock is not a valid method of disarming the anti-theft system.
    Untriggered System
    NOTE: If the driver arms the system and remains in the vehicle, an untriggered system can be disarmed by turning the ignition switch to the ON position.
    An untriggered alarm system can be disarmed by pressing the unlock button on the keyless entry remote transmitter.
    Triggered System
    NOTE: If the hood or trunk are open when the system is armed, it must be closed and opened again before it can trigger an alarm.
    An armed anti-theft system can be triggered by the following conditions:
    The deck lid door, liftgate, hood or any door is opened using a key, inside door handle, hood release, etc.
    • The keyless entry remote transmitter can activate a panic alarm which is similar to the anti-theft alarm, but does not cause the THEFT indicator to flash.
    A triggered alarm system can be disarmed by:
    • Pressing the unlock or panic button on the keyless entry remote transmitter.
    • Turning the ignition switch to the ON position.
    Alarm State When Battery Power Is Cycled
    When the RAP module is supplied power the first time at the vehicle assembly plant, the system will be in the disarmed state. The RAP module will remember whether it is armed, disarmed or triggered in its non-volatile memory. When the battery positive cable is removed and then reconnected, the system will return to the state it was in just before the battery was disconnected. If the system is in any prearm state, then the system will return to a disarmed state when the battery is disconnected and then reconnected.
    Nov 06, 2010 | 1999 Mercury Tracer
    Car's alarm system is my problem.Alarm would not disarm from key pad remotes (2) Problem began with system not arming from keypad.Using key to lock car system would arm after a few secs.and the chirp...
    the location of the kill switch was chosen by the monkey who fitted it,so anybodies guess....under the dash by the side of the steering column is as good as any....
    Jun 01, 2010 | BMW 325 Cars & Trucks
    Blue led stays on instead of blinking .
    disarm system get inside the car turn key to ON position with door OPEN push the black valet button one time turn key off
    now your out of Valet mode
    or
    open your door hit ARM then DISARM then ARM and that should also remove Valet mode if you don't know where the valet button is at.
    May 14, 2010 | Viper Security and Remote Start System...
    When i arm and dis arm system i get error beep?
    Hit f and then unlock
    You may have lock out the remotes. If that doesn't work DEI has a one yr gurantee on remotes. In your box there should be a registration card. Call them.
    Jan 26, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
    Jun 04, 2009 | DEI Python 990 2-Way Security...
    Replaced the alternator, now anti theft won't disable
    The ignition lock anti-theft switch (19A438) detects if the ignition key cylinder is broken or "slam pulled" during a theft. The ignition lock anti-theft switch is always monitored by the remote anti-theft personality (RAP) module. This allows the alarm system to be triggered in the case that the ignition lock anti-theft switch detects tampering of the ignition key cylinder (even in the event that the alarm is not active at the time).
    Refer to the Section 501-14B for more details on the keyless entry remote transmitter (15K601).
    The door open warning lamp switch (14018) communicates to the RAP module through the generic electronic module (GEM). This input to the RAP will cause the anti-theft alarm to be sounded if the anti-theft alarm was armed.
    The door disarm switches are assembled into both LH and RH lock sets. The door disarm switch must be triggered before the mechanical lock unlocks. This is to prevent the anti-theft alarm from activating when it should have been disarmed.
    The RAP module controls the anti-theft system and is the brains of the keyless entry system. The RAP module communicates with the GEM to request that the interior lights be turned ON/OFF with use of the keyless entry remote transmitter, and the GEM communicates to the RAP to inform when the door is opened. Refer to Section 418-00 for inter-module communication.
    The RAP module has three wire connectors attached to it:
    • The antenna for the keyless entry remote transmitter.
    • 26 circuit connector (C256).
    • 22 circuit connector (C257).
    In addition to the perimeter alarm that uses the door open warning lamp switch, the RAP module also uses the ignition lock anti-theft switch and the autolock/relock feature to prevent theft of the vehicle. For a full description of the autolock/relock system, refer to Section 501-14B .
    The THEFT LED is found on the instrument panel between the tachometer scale and the needle pivot point. The LED is illuminated during prearming and flashes when armed or triggered.
    Prearming and Arming the System
    The system can be armed if:
    • The ignition is OFF.
    • The PANIC alarm is OFF.
    There are two ways to prearm the system:
    • Press the LOCK button on the transmitter.
    • Open a door, press the power door lock button and close the door.
    After 30 seconds the system will be armed and the theft indicator in the cluster will flash every two seconds.
    Disarming an Untriggered System
    An armed system will be disarmed with one of these valid actions:
    1. Pressing the UNLOCK button on the transmitter.
    1. Placing a key in the door and turning to UNLOCK.
    1. Turning the key to RUN or ACC.
    The anti-theft alarm can be triggered by the following conditions:
    • The ignition cylinder is damaged with or without the RAP being armed.
    • A door is opened without disarming the armed RAP module.
    The remote transmitter can activate a panic alarm which is similar to an anti-theft alarm, but does not deactivate the starter or cause the theft indicator to flash.
    Disarming a Triggered System
    If the system has been triggered, (the horn honks, the lights flash, and an external starter interrupt relay is engaged), the system can be disarmed by:
    1. Pressing the UNLOCK or PANIC button on the transmitter.
    1. Putting a key in the door and unlocking the door.
    1. Turning the ignition to RUN/ACC (Turning the key to RUN/ACC will not disarm an alarm that has been triggered by the ignition lock anti-theft switch.).
    Apr 10, 2009 | 1997 Ford F150 Regular Cab
    Vehicle Parts & Accessories Logo
    61 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
