Question about Cameras
Need to replace power source
Power supply no longer works. I would like to purchase a replacement adapter
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Different devices take different adapters. Do you have a particular item in mind?
Posted on Jan 15, 2013
How do I purchase a replacement ac adapter for peak AKC0A0 portable battery jump starter
Try the source of that non-Mopar equipment. If they don't have a website, well...........
Jun 01, 2014 | PEAK PKC0A0 300 Amp Jump-Starter And 12...
Dell Inspiron 1721 will not power on,light on power supply flashes rapidly.
First, try and take out the battery and start the computer with just the power adapter. If the power adapter is still blinking, replace the power adapter. If the computer turns on with just the power adapter, replace the battery.
If the battery status light rapidly flashes amber, the battery may be defective. Purchase a replacement battery from Dell.
If the power supply status light flashes, the power supply may be defective. Purchase a replacement power supply.
Feb 15, 2011 | Dell Inspiron 1721 Notebook
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
I no longer have power to my monitor; is there a way to check power source or, if necessary, to buy a new power source pack?
You can measure the adapter output with a voltmeter. The output should match the voltage marked on the adapter. This model uses a 12-volt adapter.
If the adapter doesn't have any output, it may be because the wire has broken inside the cable near the plug from flexing. It's possible to repair this by soldering on a new plug. Sometimes it's tough finding the right plug, though; some brands of equipment use oddball sizes.
You can also purchase replacement adapters. Several sources came up after a search for "scanport n9 adapter". Here's one on eBay. You'll be able to find what you need.
Mar 05, 2010 | Scanport N9 19" LCD Monitor
Hp laptop will not power up...at all. In fact the
1) You need to check the power supply itself to mkae sure it still puts out the DC voltage as indicate on the power supply.
2) You may have cracked solder joints at the DC input jack of the laptop.
look here for more info: www.insidemylaptop.com
Oct 26, 2009 | HP Pavilion dv9000z Notebook
DELL INSPIRON 1525 WILL NOT POWER UP
what do you mean "in" the laptop?
if you meant the AC adapter it should be 65W or 90W check on the adapter itself, for the rating. and if you meant the battery on the bottom it can be 4,6,or 9Cell again written on the battery, to remove just slide the switch on the bottom and remove and put in new one.
you can find the REPAIR / SERVICE MANUAL'S here...
http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
to replace any part.
and to confirm the faulty power source start the laptop with battery only connected and then start it with adapter only.
Apr 22, 2009 | Dell Inspiron 1525 Notebook
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
I have a 3 pack Panasonic cordless phone system model kx-TGA542M. I ran over and shreded the cord with a vacuum cleaner and the charger PQLV30030ZAM no longer works. 1. Can I find a replacement...
Start by putting in the very same part number you put in here.
It will lead you to the base without power supply, and a reference to a KX-TC1 power supply. How about this one?http://www.google.com/search?q=kx-tca1&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
Carl
Dec 26, 2008 | Lands Phones
Lost power supply
I think you might find this link most useful, from the Seagate Community Forums.
http://forums.seagate.com/stx/board/message?board.id=onetouch&message.id=1973
In short, others have had great difficulty buying Maxtor replacement power adapters, however you can buy a generic 12V, 3A DC power supply for $15-20 from a number of sources. Confirm your actual power requirements by referring to the product label on the drive itself.
Hope it helps,
Mike
Dec 02, 2008 | Maxtor OneTouch III Mini Edition 120GB...
DELL XPS M140 POWER ISSUE
Hi brendanram!
I am claudus_07 and i was a Dell - XPS Technical Support Specialist before so i will be glad to assist you with your concern.
As you said into your post, you tried plugging the AC Adapter to the power source without plugging the other end into the XPS laptop and the Green Light on the adapter is lit. But when you plug the jack on the laptop, the Green light is out. As for my experience on your laptop, there could be a problem with the power supply or the motherboard of your XPS laptop. Because everytime you plug the adapter to the laptop, the green light is going out so it means that the laptop or the adapter is grounded.
Here's what you need you to:
Step 1: Call Dell XPS Technical Support 1-800-624-9896
Step 2: Tell them the issue and the things that youve done.
Step 3: At the end of the troubleshooting, i know that the Technician will either replace the Power Supply, Motherboard, or the Adapter. (if you have a friend that has a Adapter same as yours, you may try to use it just to isolate the issue the Technician will choose from the Power Supply or the motherboard)
Step 4: If the Technician replaces the power supply and the issue still persists, call technical support again and ask them to replace the motherboard, no need to repeat the troubleshooting steps anymore just tell them that youre already done with it. (Dont ask for a system exchange, because i know that they will not give what you want.)
Thanks!
I know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Jul 27, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
