Question about Brother CS-8060 Computerized Sewing Machine
The thread on the bottom of my fabric is loose and loopy. I have adjusted the tension but it doesnt help.
  • Brother Master
  • 1,564 Answers
Seems silly... but did you remember to put the presser foot down? Leaving it in the up position will circumvent the tension and give you fits.
Posted on Jan 14, 2013
SOURCE: Tension problem Bottom thread is loopy and sloppy
SALUDOS, MI MAQUINA HACE ESACTAMENTE LO MISMO UN DIA DERREPENTE DEJO DE BORDAR Y TIRA TODO EL HILO, LO HACE BOLAS POR LA PARTE DE ABAJO, Y DESCUBRI QUE SE ROMPIO UNA LAMINITA QUE LLEVA FRENTE A LA LANZADERA DONDE SE COLOCA LA BOBINA.
TAL LAMINITA SE LLAMA RESORTE PERO NO TIENE NUMERO NO LA HE PODIDO ENCONTRAR, DICHO RESORTE VA INSTALADO AL LADO DERECHO EN EL MISMO LUGAR DONDE ESTA INSTALADO EL LASER. AGRADECERIA ME DIERAN EL NUMERO PARA PODERLA COMPRAR. MIL GRACIAS.
Posted on Aug 15, 2008
SOURCE: Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Posted on Mar 29, 2009
Mimito7
  • 128 Answers
SOURCE: thread loopy on top
General rule of thumb::
loops on the bottom, problem on the top.
loops on the top, problem on the bottom.
It sounds like your bobbin thread is not thru the little tensioner in the bobbin compartment.
Posted on May 28, 2009
bargainbox
  • 1388 Answers
SOURCE: Huge loops on back of fabric!
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
bargainbox.com.au
Posted on Aug 02, 2009
  • 1116 Answers
SOURCE: I get loops on top and/or bottom of fabric during
Top tension back to 4 and leave the bobbin tension as is.
Make sure you have a new needle for the type of fabric being sewn installed with the flat side to the back of the machine. A bent needle can sometimes go unnoticed.
Always thread the machine with the presser foot up and this will give proper tension to the stitch.
Check the manual to be sure you are threading correctly (always with the presser foot up) and that the bobbin thread is feeding in the correct direction from the bobbin spool and through the guides.
Take hold of the thread at the needle as you lower and raise the needle to pull up the bobbin thread. Take both thread ends under the presser foot and to the back of the machine.
Posted on Mar 11, 2010
Baby lock quest plus and the bobbin thread is all loopy. I have done everything. I believe it is in tension discs. When I move it to 8 or 9 it sews ok. When I sew faster it seems to start looping.
Is it really the bobbin thread that is loopy--not the top thread looping under the fabric? If this is the case, it is called bird nesting. (problems appearing under the fabric are usually a top thread issue, problems on top of the fabric usually indicate a bobbin issue)
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. You may need to loosen the top tension to get it where it should be. The two threads should meet in the middle of the fabric.
If the bobbin thread is still too loose, then an adjustment may be needed to its tension.
Understanding Thread Tension Threads
Feb 10, 2018 | Baby Lock Sewing Machines
In my SWF single head which tension do I adjust top or bottom or bobbin if I have loopy threads on top ??
Generally, thread problems on top of the fabric are a bobbin issue, thread problems under the fabric are a top thread issue.
Aug 23, 2017 | Sewing Machines
Why does the bottom tread come out loose and loopy
First, check the stitching to verify that it is in fact the bobbin thread that is loose & loopy. Usually, loopy thread under the fabric is the upper thread--which, if that is the case, is an indication it is either threaded incorrectly or the upper tension is too loose.
Make sure you are using a brand-new needle.
Always RAISE the presser foot and then thread the upper thread making sure that every guide and the correct path is followed.
Set the upper tension to the midway point between high & low number and re-test the stitching. Re-adjust as needed. The tension is correct when both upper and bobbin threads meet in the middle of the fabric.
If it is in fact the bobbin thread causing looping, it could be that the bobbin case is not threaded properly or the tension is way off.
Liz Kettle adjusting your bobbin case tension 1 wmv
Apr 11, 2016 | Sewing Machines
Model 525B. Why is bottom stitch loopy and the hand wheel and needle jam?
try a new needle
try adjusting the top thread tension to see if that helps the bottom loopy stitch
Jan 10, 2016 | Janome Sewing Machines
Correct bobbin size for a Necchi Omega 6030
You can use either 16 or 16J. If your threads are loopy on the bottom side of fabric, the problem is either your needle thread tension is too loose or you have a snag in your needle plate where you have broken a needle. Check needle plate and clear snag if any. Then tighten up your needle thread tension until both needle and bobbin threads are in middle of fabric.
Jan 30, 2015 | Necchi 6030 Mechanical Sewing Machine
Over locker loopy bottom stitch
Loopy on bottom means the top tensions need to be adjusted. "All on 3 means nothing" These are tension knobs and are not required to be on the same number.
In the mean time rethread the machine with a different color on each spool This will help you determine which thread is the offender. sew the same type of material this thread set up... tighten the corresponding tension dial. Once you get a good stitch, Lift the food, cut all the threads near the spools and tie off new thread/spools and pull the thread through to the needle. Once it is all threaded again test your stitch with the same fabric again.
Oct 02, 2013 | Sewing Machines
Brother cs-6000 will not sew, the top thread go through and tangles on back, and the bobbin thread is a straight line and can be easily pulled out, please help, trying to make kids school clothes
Hi:
Ok... so try to remember that loopy stuff on top means the bobbin tension is too loose (or the top tension is too tight...)
Loopy stuff on bottom, means the top tension is too loose. (or it's not threaded right)
Now. Get some scrap of the same material. Loosen that bobbin back to where it was. RETHREAD the top, with the foot in the UP position.
Place your scrap under the foot, and sew. still have problem? clip your threads and try again only this time hold the top and bottom threads off to the side as you begin to sew. How did that do?
Adjust the top tension to the point where you start seeing the bobbin thread come up in loops to the top... then back off until the disappear.
Now... be sure you have the correct thread and needle for your fabric. A lot of problem are caused by not having the proper needle and thread.
Jul 09, 2012 | Brother CS-6000
Back thread loose and loopy - tension
If you have the instruction manual, you might read the chapter which describes the proper adjustment for threads and fabrics.
If you do not have one, try to find it on eBay. It is the huge source of everything.
Feb 20, 2012 | Juki MO-644D Mechanical Sewing Machine
Bottom thread is loose and loopy, have tried new needle, thread, cleaned out bottom, tension adjusted.....nothing works, can you help. I see many others have same problem but i cannot see an answer
When your bottom thread is loopy it means that the UPPER thread is not properly threaded. First make sure your needle has the flat side to the back of the machine and that it's the right size needle for your machine and the fabric you're using. You probably missed the tension discs when you threaded the upper thread. Make sure that your presser foot is up and that your needle is in the uppermost position. Try re-threading it and when you get to the tension discs pull the thread back and forth so you hear a little snap. That tells you that your thread is being placed in the discs correctly. (This also cleans out your tension discs in case there's lint in them.) Make sure that you tension dial is on about #4. Finish threading and you should be good to go. Thanks for using FixYa!
Aug 26, 2010 | Elna Heirloom Edition 6005
The top thread is really loopy on the underside of the fabric, sometimes it misses a stitch, sometimes, the upper thread breaks, and it often gets so tangled underneath that the machine won't feed.
Your tension is way too loose on top or too tight on the bobbin. Try adjusting the top tension one number at a time until you get it right. (Only adjust the bobbin tension as a last resort). Also you could have different thickness of thread in the bobbin than on the top or are sewing a very heavy fabric. Try adjusting the tension with same thread in both bobbin and top and use a normal weight fabric until you find the right tension to get you back to a normal stitch before going to a heavier fabric or thread.
Nov 19, 2009 | Craft Master 4300 Mechanical Sewing...
Brother CS-8060 Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
