Question about Exercise & Fitness
I have a Diamondback HRT 1000ES Stair Stepper. When I turn it on the lights come on and it makes the high pitched beep but never turns over to activate. Do you think its the computer chip or the motor?
5 Suggested Answers
  • 2336 Answers
SOURCE: Stair stepper won't start
Wide Ride Pedal CTGID0 Stair stepper won't start
Posted on Dec 01, 2008
maxtreadmill
  • 832 Answers
SOURCE: Hello, I have a Diamondback HRT 1000 ES stair
Take of the cover off and inspect the inside of it you should see a large flywheel and on that wheel their should be some type of black and silver target wheel ,and next to it possibly on the frame their is a circuit board with a photo speed sensor check voltage it needs to be 5v dc if it is not present then uplug wire to main power board connect and if the 5v dc is present at board connection replace sensor. If 5v dc is present at sensor then gently clean target wheel with a soft cloth ,then try the unit without the cover and see if that take care of problem if not then adjust sensor closer without touching the target wheel.
Posted on Mar 14, 2010
  • 48 Answers
SOURCE: i have a diamondback 1100 stair stepper, it won't
check your batteries and work on it without power about 30 mins they will re-charge
Posted on Mar 20, 2010
walesarumi
  • 6993 Answers
SOURCE: Hi...I have a Diamondback 1000es
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Dec 22, 2010
Stair master 4400cl Stepper making clunking sound user pedals when stepping
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
This can cause a clunking sound. For the replacement parts, please see the link below.
Why does one Pedal Drop on my Stairmaster Stepper
Apr 03, 2012 | Stairmaster 4400CL Stepper
My DiamondBack HRT 1000 ES Stair Climber isn't powering up. The power supply tests OK. The display was replaced 3 years ago. Any ideas on how and where to test ?
No we have little to zero info on this type of product, sorry. I suggest you give the customer service dept for the product a call, you should be able to track down their phone # on the Internet.
Jan 20, 2012 | Exercise & Fitness
I have a diamondback 1100 stair stepper, it won't "power up". the control panel won't turn on and no resistence
Feb 27, 2010 | Exercise & Fitness
Hello, I have a Diamondback HRT 1000 ES stair stepper. The resistance seems to be backwards. i.e. when you start it is at the hardest level even though the electronic resistance graph says it is at the...
Feb 11, 2010 | Exercise & Fitness
I have a Diamondback 1100 ES stepper which recently started operating incorrectly. It appears that the magnetic flywheel is not exerting any resistance no matter what setting I plug in. Initially when I...
I've had this problem years ago. If I remember, the flywheel pickup sensor on the left side of the flywheel is slightly misaligned. If you tweek it it should solve the problem.
Jun 06, 2009 | Exercise & Fitness
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Dec 01, 2008 | Schwinn Wide Ride Pedal
Exercise & Fitness Logo
106 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
