Question about Toshiba E-Studio 3040c Color Copier
Toshiba e-studio 3040 c won't recognize new black toner cartridge. Have tried 3 different ones, all genuine toshiba
4 Suggested Answers
  • 1126 Answers
SOURCE: Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Posted on Jun 26, 2009
  • 653 Answers
SOURCE: toshiba e-studio 720 toner low message but bottle
If everything is OK, but the message is still appear, then u can clear it by following below steps:
User Function--> User--> General--> Toner Near Empty Detection -->Yes
Posted on Sep 17, 2009
  • 10 Answers
SOURCE: Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Posted on Nov 06, 2009
E studio 256 not recognizing toner. how to remove this error. there is a new toner cartridge.
1. Make sure genuine toner is use
2. Toner chip not dirty
3. Toner detection inside the machine not dirty
Aug 23, 2015 | Toshiba E-Studio 256 Digital Copier
What happened if toner not recognized in toshiba e studio 225
This model no code to bypass...Make sure you are using genuine toner with toner chip on it...Then, clean the toner chip(with 6 springs) and harness inside the machine...If still persist, u might need to change the toner chip on the machine...
Aug 11, 2015 | Toshiba E-Studio 225 Multifunction Copier
Konica minolta bizhub c35 black toner being recognized as empty
sir/mam replace the cart then might have gotten a bad one from the store
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 11, 2014 | Konica Minolta bizhub C35 Black Toner...
Bizhub c35 new cartridge being recognized as empty
When i start my toshiba e-studio 206 show Ink blinking icon
Please check the toner cartridge is actually emptied, if so replace it with a new one, if not, clean the contact of the chip, that locates in the back of the cartridge. You must use the genuine Toshiba toner cartridge, that has a chip circuit board on the back, those 3rd party cartridge created lots of problems, results lost of time and money that you would not like to hear.
Oct 29, 2013 | Toshiba E-Studio 206L Copy Machine
E-studio-232 adding toner problem
change the developer with the new one and change the sensor toner.
May 24, 2012 | Toshiba e-Studio 232 Black and White...
I have a problem with toshiba e studio 181: i've changed a new toner cartridge but the indicator of toner is still flashing, and the machine didn't give any acces.
first check if the cartridge is original usually "have a serial & par code"
& Shake it will & clean carefully the green ship at the end off cartridge
check if the cartridge is already opened
turn the cartridge upside down " open the wight square tab & turn the Shield the Opposite Hand
[ check if broken ] while turning it .. you must see tone Flipping or moving at the square tab window
if not that's mean shield broken
try to fill its toner to an empty cartridge..
Jul 06, 2011 | Toshiba 1360 Black and White Copier
Toshiba e studio 170f error message, toner not recognized
maybe the roner cartridge you inserted is not supported by Toshiba e-Studio 170f. This may be one of the reasons that the machine can't recognize the toner cartridge.
Reinstall the toner cartridge that you have. If that doesn't fix the issue try to replace the toner cartridge with new one.
If you continue experiencing this issue contact your technical support team.
Jun 19, 2011 | Toshiba EStudio 170f Fax 170f
Toshiba E-Studio 3040c Color Copier Logo
543 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
