Question about Frigidaire Dishwashers
My dishwasher will not run
The bracker is good I have power to moter but it still will not run water is turned on
Youll have to take out and take off cover to clean impeller its prob full of stuff, hair etc.
Then run
Posted on Jan 14, 2013
I have a beko de 2762 fw dishwasher when i press start 3 out of the 4 lights come on and the moter continually runs.
It sounds like you have a leak. You need to take the dw out and lean in back untill the water will run outside.
Dec 16, 2013 | Dishwashers
Kenmore Elite 665.17053400. Powers up ok, fills up with water ok, but wash cycle won't start. I can hear the motor trying to turn but sounds like its seized up. If I cancel the wash, the machine drains...
This dishwasher has a very sophisticated wash system. In order to improve the wash efficiency it uses a chopper and a soil sensor. It is very likely the chopper assembly is clogged which is blocking the water from circulation and straining the wash motor.
See this diagram. Item 6 is the chopper. Worst case is the pump motor needs replacement. This is item 10.
Good luck
May 27, 2011 | Kenmore Dishwashers
The dishwasher moter is running when the door is open however no washer is present. dishwasher does not go through a cycle it just keeps running
It seems to be a Safety Switch. Is there any Leak? Check Properly specially into the Base of the Dishwasher. I have seen many Times that could Turn OFF the Safety switch.
Turn off and lean the machine back at 45 degrees, you may see water come out the base. Wait for it to dry out then try again.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 17, 2010 | Siemens 24 in. SL84A302UC Built-in...
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
Our PLD4375RFC2 dishwasher fills up with water but doesn't run
no their is no fuse. sound to me like your motor is not working, however
the pump should still drain out.push cancel only and unit should drain if it does then id say motor bad. you can try to take apart and check motor blade ive seen toothpics, food , other objects hold motor impeller from turning making it seem like its the motor but actually its just stuck..remove btm wash arm and filter cover thentake two or 3 small screws from a plastic cover covering motor impeller, look to see if anything is in their if so remove. warning if you see a white ball down their leave it alone reinstall and see what happens. hope this helps.
Sep 17, 2009 | Frigidaire PLD4375RFC Dishwasher
The washing arm isn't turning on a wherlpool dishwasher , water is circulating, moters are running
check to see if the arm is free turning if so check the tube that lines up with the arm that feeds water up to it. it may have something plugging it up.
Aug 22, 2009 | Whirlpool DU1055XTS Built-in Dishwasher
My dishwasher will not fill with water therefore i can't use it. the moter is running but no water intake
Check the power coming to the water valve during the fill cycle. If power is there the valve is shot or the screen is plugged. remove the valve and check the screen or replace if clear.
Eric
Jun 28, 2009 | Whirlpool Dishwashers
Miele dishwasher g664 12 years old maybe?
Hi Lawrenceo,
I'm Harvey the Master Plumber.
You stated your problem as: the dishwasher won't drain.....can here a valve opening and gurgling but then no water exiting. Have cleaned everything and pushed water via tap back through water-exit hose.I to have a Miele G664 dishwasher and when turned on no water no fill. Just sits there with a moter running. Un able to get anyone to come and have a look at it as I live in Mount Victoria NSW.
It sounds like the pump has failed. The motor and the pump are two different parts. This is a common problem with older units. Frankly, after 12 years of use, at least you got your money's worth. At this age, to repair it is to throw good money after bad. It's time o replace it. You'll find there are much nicer models available now.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
Bosch SHU4302UC/06 Sound Like It is Work But NO WATER
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 15, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher problems
TURN POWER TO OFF ... REMOVE THE LOWER RACK. THE SPINNING SPRAY BAR USUALLY WILL LIFT SRAIGHT-UP AND OUT ... INSPECT TO SEE IF ANY THING IS IN THERE TO PREVENT IT FROM SPINING FREELY ... THEY SPIN BY WATER PRESSURE SO THE NEXT THING TO CHECK IS THE WATER SUPPLY VALVE (MOST OF THE TIME IT IS RIGHT UNDER YOUR SINK.) AND THE STARAINER is LOCATED WHERE IT CONECTS TO THE DISH WASHER. MAKE SURE YOU HAVE A BUCKET AND RAGS HANDY FOR SPILLS... CAREFULLY TURN THE VALVE OFF AND REMOVE THE COMPRESSION FITTING NUT THAT IS ON THE "SIDE CLOSEST TO THE WASHER".... THEN CRACK THE VALVE OPEN AND FILL THE BUCKET UP A FEW TIMES TO ENSURE GOOD WATER FLOW. TURN VALVE "OFF" AND GO TO WERE THE LINE OR HOSE CONNECTS TO THE WASHER. REMOVE THE CONNECTION ... INSIDE YOU SHOULD FIND A STRAINER THAT MAYBE CLOGGED UP. CLEAN-IT AND MAKE SURE TO TIGHTEN ALL THE CONNECTIONS BEFORE STARTING A TRIAL RUN. NOTE: THERE IS A SOLENOID INSIDE THE MACHINE THAT CAN STICK AND GET CLOGGED BUT USUALLY ITS THE VALVE OR THE STRAINER. GOOD LUCK AND STAY DRY ... Joe_Rex
May 01, 2007 | Frigidaire GLDB958JS Dishwasher
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
