Question about SewShop.com Singer Model 9010 Instruction Manual
Adjust the tension on a singer model 9010 - SewShop.com Singer Model 9010 Instruction Manual
Where do I tighten bobbin thread
on the outside of the bobbin case where you pull the bobbin thread around and down a small; slot to under a small flat spring
that flat spring is the bobbin thread tension and is adjusted by the screw that holds that plate on
a very small amount of turn of that screw make a large difference to the tension
However if your problem is birdnesting under the material ( total mess) then the problem is not bobbin tension but the needle tension is too loose and not pulling up the bobbin thread properly
Jan 26, 2016 | SewShop.com Singer Model 1021 Instruction...
How do i tighten the bobbin tension on Singer model 4552
When you drop the bobbin into the housing there is normally a tension screw on the side of it.
Oct 17, 2014 | SewShop.com Singer Model 4552 Instruction...
Lot of thread and no stiches
you should be able to do a free download of manual from this site. Click download link and insert the 3 letter code to enable download. Singer 6202 6212 User Manual
Must be a tension adjustment problem.
Sep 07, 2014 | SewShop.com Singer Model 6212 Instruction...
How do i fix the tension
There is a dial on the left side of the machine. It is numbered 1 to 10. Adjust this to get the tension... There is also a screw on the bobbin holder but it seldom needs adjustment.
Aug 09, 2014 | SewShop.com Singer Model 7108 Instruction...
How to adjust bobbin tension
Just un ravel the hole thing and wind it back up again making shore you wind it up tightly.
Apr 29, 2014 | SewShop.com Singer Model 9410 Instruction...
Adjusting the knobs on the front of my Singer 9005
If the bottom thread is showing through, back off the tensioner, 1/2 number at a time.
Jan 18, 2013 | SewShop.com 9005 Singer Instruction Manual...
I have a Singer 95 40. Seems to sew well, but rhe thread keeps breaking. I adjusted the tensions. They seem to be OK.. Any suggestions
Suggestion:
1.Improper threading
2. bobbin threaded improperly
3. Tension adjustment too tight.
Jul 05, 2011 | Vacuums
I have a Tacsew T11-115 and I do not have an instruction book. I need to see if I have it treaded correctly and how to adjust the bobbin tension. The top thread is laying on the fabric and the bobbin...
For all sewing machines, if the bobbin thread is showing on the top surface, then the top tension is probably too tight. Turn the tension indicator to the left by half a number to a lower value. (So that if 5 was lined up with the dot initially, then go to 4.5 lined up with the dot).
See this article for some clear pictures of thread tension adjustments: http://www.ca.uky.edu/HES/fcs/FACTSHTS/CT-MMB-213.pdf . If you can find it the Singer Sewing Book is a good reference http://www.amazon.com/Singer-Sewing-Book-Gladys-Cunningham/dp/0307098702 .
This site, http://www.allbrands.com/products/abc0762.html , may be able to find and send you a manual to the TacSew T11-115. They have the T11-155 for sale.
I hope this helps.
Jun 12, 2011 | Vacuums
Help I need a free manual for a Singer sewing machine model 756
If you go to singer's site you can order another manual for it. They do charge for it however. Their site adddress for ordering it is http://www.singerco.com/accessories/manuals.html
You will find free online picture illustrations for how to thread this machine and wind the bobbin here http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_756_threading_diagram.htm
You can go to this site http://www.tandtrepair.com/700TS.html for free online instructions for things like threading and tension adjusting for your machine. They also have parts and repair manuals for sale.
There are many sites who sell the manual but none that I could find have free ones. Hopefully the picture instructions above will help you some.
Apr 29, 2011 | Vacuums
SewShop.com Singer Model 9010 Instruction Manual Logo
35 people viewed this question
Top SewShop.com Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
