Question about Craftsman Garden
Craftsman chain saw 358360120
Fuel lines to carb.
  • 61 Answers
SOURCE: Homelite xl-175 chain saw no prime
As long as the line fits tight so its not sucking air you should be ok.. try changing out the plug if its old. Clean out the air filter too.. But the line should be ok as long as its tight..
Posted on Jul 10, 2009
  • 15 Answers
SOURCE: I have a Benchmark chain saw - replaced brittle fuel lines
sounds like your clunk has come free from fuel line or it is stuck at top of fuel tank. i would empty tank and see if clunk is free by giving the saw a good shake if you cant here the rattel of the clunk you have found the problem PS clunk is a weight attached to the end of your fuel line in tank it makes the line stay at the bottom of the tank
Posted on Sep 06, 2009
dontbother10
  • 2220 Answers
SOURCE: ZAMA carb fitted to Makita chain saw which way
Hello Gordon; We need the complete make, model, and serial numbers with every question in order to fully help you. The IPL for the DCS510-18 can be found on this page: http://www.makita.ca/index2.php?event=tool&id=361&catid=40 Fuel line routing2.gif while pictured isn't clear. In the US of A these are red and called Dolmars. A local dealer may allow you to look at his shop manual if one exists. Sorry to not be helpful. Lou
You must help us if we are to help you!
Posted on Sep 13, 2009
dontbother10
  • 2220 Answers
SOURCE: chain saw, there is a line from primer to the
Similar to this, typical fuel system.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Posted on Dec 19, 2009
Testimonial: "thanks, very helpful diagram!"
hunter19_46m
  • 7482 Answers
SOURCE: need to know about fuel
Hi arisaleman...
This drawing is how most chainsaws,weedeaters,and most 2 cycle small engines fuel systems are run.
Please take time to rate me
Posted on Sep 10, 2011
How do you replace fuel lines on a craftsman 16" chainsaw model#358.352161?
remove the carb and then pull fuel lines from tank ,there should be a filter in tank attached to the fuel line you will put that on the new line then feed it through from in the tank out
Oct 30, 2014 | Craftsman Garden
My craftsman chain saw 18 will not start
The 3 things needed for an engine to run:
1. Compression (Cylinder, Piston, rings, gaskets)
2. Ignition (Spark plug, ignition module/coil)
3. Fuel (Fuel lines, Carburetor, gaskets, bad fuel)
More than Likely I would start by checking fuel related since that is usually the biggest offender (fuel lines broken/dry rotted, bad carb.)
Jun 19, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Fuel lines on craftsman chain saw
go to the website and see if you can download a manual
most saws have 2 lines fuel in and a return
the fuel in line is the one that goes in the tank and has a filter on it
hold you finger over the fuel line on carb and pull cord, the one that sucks is your fuel in, the one that blows air out is your return
Mar 07, 2014 | Craftsman 42cc 18" Gas Chain Saw
No fuel going to carb
Either you have a air leak fuel inline or at fuel tank or a plugged up carb- sour aged fuel or foreign debris
Jun 12, 2013 | Craftsman Sears Chain Saw Manuals Model...
I have a walbro carb on a craftsman chainsaw..Can you tell me which fittting on the carb (TOP RIGHT) OR (BOTTOM LEFT) gets the fuel line with the filter on it??
All chainsaw primers pull fuel from the carb, so the fuel inlet ( pipe with filter on the end ) goes to the connection nearest to the pump cover of the carb ( the alloy cover with a single central screw )
Feb 01, 2013 | Craftsman sears 18" Chain Saw Chain (...
Craftsman 18" chainsaw runs but dies when I press the throttle, new carb and fuel lines low and high speed set at 1 turn .
remove the muffler and run it after seeing that it runs good open the muffler and clean the screen inside
Sep 27, 2012 | Craftsman sears 18" Chain Saw Chain (...
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Fuel lines on a craftsman chain saw need to be replaced which lines go to primer and carb
just connect them both anyway you chose. press prime button a few times to pressurise tank. you get a 50/50 chance to get it right.
if it just sucking air release pressure first by removing filler cap to prevent face full of fuel then swap pipes over on carb. i did this job a couple of weeks a go on my husky66. only use proper flexy pipe from a lawn mower centre. costs about £2.50 / foot.
Aug 10, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
