Question about Toshiba Satellite A105 Notebook
Lost file
Need help finding solution for missing dll file dont got disk to reinstall
  • 70 Answers
You need to repair your system
But if you havn't the CD
Below is the step
But make sure you close any unnecessary software and applications that run in the system tray like Windows Live Messenger, Yahoo! Instant messenger and others, before using winnt32. This should speed up the whole process.
Understand that after a while your computer will start to slow down, freeze and sometimes not even shut down correctly. These symptoms are perfectly normal for Microsoft Windows operating systems that require a clean, fresh start. But sometimes manufacturers do not include a copy of the operating system on a disk to save you money when purchasing your computer and ultimately save them money too.Access the copy of the operating system on the hard drive. If manufacturers do not supply a Windows XP CD with the purchase of your new computer, they have most definitely stored a copy in your hard drive for later use. You can easily access this copy of the CD on your hard drive to completely reinstall or format partitions on your computer.
Back up your personal data including photos, pictures, documents, favorites, passwords and settings to CD/DVD/USB.
Make sure you have your Windows product key/serial number. This could be located on the computer itself, or in the original packaging it was supplied with. If you do not have one, look in the registry or contact your manufacturer immediately for more support regarding the issue.
Click on My Computer then C: then i386. This is the a part where a lot of people get confused. They realize that a copy of their Windows XP CD is here, but they look for the wrong files. Most people will try to find a file named "Setup", "Install", or "Windows". The file you are looking for is called "winnt32.exe".
Open this application and proceed with the instructions given. It will lead you through 5 simple phases that will wipe out your computer and reinstall the operating system.
Get your product key ready to enter it. Make sure you agree with the terms that should be provided when using the winnt32.exe application.
If you are using any operating system below Windows 2000 or Me, try looking for the winnt.exe application as the winnt32.exe application may not be availible for your version of the Windows OS in the I386 folder. Winnt.exe uses a command driven interface, and therefore requires simple commands to use to reinstall Windows or format partitions. You can find these simple commands here
All drivers will be wiped clean. That includes graphic cards, audio drivers, wireless drivers, etc. Make sure your manufacturers has supplied you with the correct softwares to reinstall the drivers that will be lost on reinstallation of the OS.
Do not forget to back up all of your data with a system restore tool, or else everything will be lost. This means all software and programs currently installed on the computer.
Remember Microsoft will not take any responsibility for anything that may go wrong and cause damage to your computer system.
If the I386 folder or Winnt32.exe/Winnt.exe application does not exist, or you cannot find it, use the Search feature to help you (Start>Search). If it does not yield any results, a copy of the CD may not have been stored on your hard drive. Contact your manufacturer for more support.
Posted on Jan 24, 2009
Corrupt or missing hal.dll/ wrong boot.ini wont boot up
Check that you have not left a CD, DVD or USB stick or device plugged in when you are trying to boot as the laptop may be trying to boot from that instead of the correct internal hard drive.
HAL.DLL is for the Hardware Abstract Layer and if this is really missing or corrupt you will need to look for a recovery disk.boot.ini is normally used on such as Windows XP and you should be able to find examples of this file by searching on Google or the Microsoft site.
See which gives examples of how to edit boot.ini for Windows XP.
Dec 13, 2011 | Dell Latitude D510 Notebook
I have toshiba satellite 2065cds, when started windows loads, then when logon/password screen show, error occurs, "missing msvcrt.dll.. how can i reload the msvcrt.dll file into windows without...
does your laptop have a cd drive and do u have a computer with a burner i can find you the msvcrt.dll and can walk you thru how to copy it into the right directory.
Mar 15, 2011 | Toshiba Satellite 2065CDS (PAS206U-S6CW8)...
MY pc does not start anymore. I have a Seagate hard drive ST380011A. I got the message: The following fail is missingC:/windows rootsystem32hal.dll
<windows root>system32hal.dll. is missing or corrupt. â How to fix it?â The Hal.dll file is the first file that boot.ini tells the system to look for at boot. â Looking at it this way, this error message can be rather misleading. In fact the reason could be a number of things, such as: â The boot.ini file is actually corrupt or damaged, â or it is pointing the Startup to look in the wrong place. The Hal.dll file is located in the System32 directory of your %SystemRoot% which in a default XP setup is:â C:WindowsSystem32.â You can use the Dos boot disk (or NTFS Reader above) to quickly determine if the file is missing.â If it is, then you should extract it from your XP CDrom and place it in its proper location.Boot to your XP CDrom, and then choose 'r' to go to the Recovery Console.â With your XP Cdrom in the drive, issue this command:Expand D:i386hal.dl_ C:Windowssystem32â â (This assumes the CDrom is D and your System Partition is C) â If this does not cure your issue this may be due to issues in your boot.ini file.â â The boot.ini file is actually corrupt or damaged, or it is pointing the Startup to look in the wrong place. Resolution:â The easiest way to fix this is to boot to the Recovery Console and replace the old boot.ini with a new one.â Once you have booted to the Recovery Console run these commands at the prompt:Attrib -H -R -S C:boot.iniâ â â (This removes the attributes and allows deletion). DEL C:boot.iniâ â â â â â â â â â â â â â â â â â (Deletes the corrupted boot.ini file)â â â â â â â â â â â â â â â â â â â â â â â â â â â â BootCfg /Rebuildâ â â â â â â â â â â â â â â â (Recreates the new boot.ini file)If you would like to view the boot.ini file, you will need a boot disk to get to the DOS prompt.â If you have formatted with FAT32, then you may use a Windows boot disk (such as a W98 disk), but if you are running NTFS, you will need a NTFS reader boot disk, such as NTFS Reader For DOS which is available for download here.â To diagnose the problem, copy the boot.ini file from the hard drive (C:boot.ini) and open it with Notepad.â You will want to verify that the "Default=" line as well as the ARC path line are pointing to the right location.â Here is two examples of boot.ini files (ARC paths start with multi): [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Professional" /fastdetect This is a sample of the above Boot.ini file after adding another partition running Windows 2000 Professional. [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS [operating systems] multi(0)disk(1)rdisk(0)partition(1)WINDOWS="Windows XP Professional" /fastdetect multi(0)disk(0)rdisk(0)partition(2)WINNT="Windows 2000 Professional" /fastdetect â â
Nov 20, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I need msvcr71.dll i dont no wat it is?
...or try . If your dll does not exist, propose it. It should arrive in a few days.
If not you can find it on HUBs (peer-2-peer).
Copy it to your win/sys32 folder and it should be ok. :)
Jul 23, 2009 | Microsoft Windows XP Home Edition
"<Winnt_root>\System32\Hal.dll missing or corrupt:
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Missing wininet.dll no disk
probably u are trying to reinstall the same windows program that is damaged and is still in the cpu. find another windows disk and dowload this from "bios" (select the option "download from cd-rom") this will totally reset yr hard disk and all yr data and settings will be lost
Jan 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
When I try to boot up my Compaq Presario model no SR 1420UK, I get the message: “Windows could not start because the following file is missing or corrupt: <Windows...
You can download the hal.dll file from this site most of the windows missing dll files you can find here.
Also download windows nt or xp boot image from the net and create floppies or cd rom from that to boot up.
problem solved
Jul 20, 2008 | Computers & Internet
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Type bootcfg /list to show the current entries in the BOOT.INI file
Type bootcfg /rebuild to repair it
Take out the CD ROM and type exit
Mar 26, 2008 | HP OmniBook XE3 Notebook
Winxp cannot boot - missing files message
Just make sure you get these files on your computer.
Download hal.dll from here:
Place it in windows\system32 folder.
Now go to the drive you have windows installed in (C:/ for example), and then create a new file, name it boot.ini.
Open boot.ini with notepad, and enter this:
[boot loader]
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS /usepmtimer
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Save boot.ini now, and try booting your computer, it should work.
Nov 17, 2007 | Computers & Internet
Missing or corrupted files
get the 98 start up floppy and stick it in the a:/
Copy, or anything else missing to your c:/ from the floppy. type help/? at the c:/ and you should find the proper format for the version of DOS you have.
C:/copy a: c:
Oct 21, 2007 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
