Question about Line 6 Spider Iii 75 Guitar Combo Amplifier
Why does my line 6 make a loud screeching noise when cut on
It worked fine one day, the next it wasn't. It screeches a high pitched uncomfortable noise when i cut the amp on with the guitar jack in the input. When i cut it on without the jack in, it makes a popping noise inside.
danforddan1
  • 192 Answers
SOURCE: amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Posted on Apr 13, 2009
  • 1137 Answers
SOURCE: cable broke off in the input jack
I'm pretty sure t6hat the output jack is a sealed unit(contacts inside soldered to the surface of the circuit board. You may be able to grasp the center shaft of the plug with a thin jawed hemostat or really skinny long nosed pliers and pull it out that way. Make sure the amp is off and unplugged from the wall. If that doesn't work you will either have to get it removed at a shop or disassemble the amp to remove the circuit board and unsolder the jack and replace it or get the broken plug out of the jack once it is unsoldered. I've never had a Line6 apart yet but thats probably the type of jack they used. Thats because it has to be electronically isolated from the chassis. Hope this helps.
Posted on May 15, 2009
paulm10
  • 73 Answers
SOURCE: line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Posted on Jul 09, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Posted on Aug 27, 2009
Kree8iv
  • 192 Answers
SOURCE: I don't know....
As you know, when you plug in your headphones, the amplifier cuts the sound to the external speaker, routing the signal through your headphones instead.
When you accidentally pulled the headphone plug from the jack, it apparently damaged the jack, which has the relay attached that routes the sound to your headphones.
Replace the jack, and everything may be OK. I say may be, because the jack is attached to a circuit board in these line 6 ampllifiers, and if you have damaged the circuit board, you will have to send it to line 6 to be repaired.
The downside is if it is not under warranty, it is an out of pocket expense, and Line 6 will not even give an approximation on how much a fix will cost. I have gone through it with Line 6 in the past, so I am very aware of the procedure. It is also a limited warranty, and they may not cover this particular damage.
However, if you are straight with them and they feel obliging, they may fix it under the warranty, if it is still active on your amp.
I had a spider 2 x 12, which was switching between amp models by itself, and they told me that because it was not under warranty, that I might want to consider NOT sending it to them, and just buying another amp. I didn't like that advice, because they seemed as though they didn't care about retaining my business.
Now, something to consider is taking it to a reputable amp repair shop (preferably one that is Line 6 authorized), and see what they can do. Maybe your clip is just bent, not allowing it to spring back from the contact switch that cuts off the main speaker. It could be a very inexpensive fix, but you need to have a shop actually take a look at it up close and personal.
Good luck. I, for the most part, enjoy Line 6 products, and their excellent distortions. Just remember, their amps tend to have a LOT of problems. You can find sites that list many many dissatisfied Line 6 amp owners. All that electronics (on board effects, soft buttons and switches, etc.,) make them vulnerable.
Now I mainly use my old reliable Marshall 1/2 stack with my Line 6 pod, as well as quite a few other pedals.
You would be amazed by the fact that you can still get pretty good money for a broken line 6 amp, maybe get something with less bells and whistles to break, and go with off-board effects pedals and processors.
Please excuse me for adding my own opinions, I am quite well versed in this type of advice having grown up in a luthier / guitar shop and have been playing for 38 years.
Good luck with everything, and if all goes right, adn it is just bent, it may cost you as little as a few dollars to fix. I'll keep my fingers crossed for you.
Thank you for using FixYa.
Posted on Sep 09, 2009
My line 6 spider mk 11 starts making a cracking noise about 50-60 seconds after i turn it on, then loud fuzz noise- whats wrong plz help
Disable ALL digital settings....problem gone? If not, with tube guards and/or shileds removed try lightly tapping on each tube (one at a time). Does your amp go crazy while tapping one particular tube? If yes then it is new tube time.
Oct 18, 2012 | Line 6 Spider Valve 112 MkII 40 watt 1x12...
I seem to always get a static sound out of my Line 6 Spider Iii below 9 o'clock on the volume knob. Not only is it staticy, but the volume jumps all around and goes from whisper quite 1 second to house...
It sounds like you have a dirty pot (the volume control). Unfortunately the only way to clean the pot is to open the amp up and try to spray some Servisol Super 10 in through the small opening in the pot case.
WARNING: Tube amps contain lethal voltages even when unplugged! If you are not an experienced service engineer then take it to someone who is! It is a pretty common task in guitar amps so shouldn't cost too much.
Sep 10, 2011 | Line 6 Bogner Spider Iii Valve Tube Combo...
Just bought a ps-6 today, tried it through my overall set up the pitch shifter, detuner & super bend are fine, as soon as i use the harmony setting it takes a sweet medium gain lead sound and adds the...
By ading in the harmony signals you are combining 3 signals so gain is probably going to be high you will have to reduce it before it goes to the amp or turn down the input gain of the amp.
NEVER use a pedal in the external effects loop of an amp as the levels are wrong.
Jul 26, 2011 | Roland Boss PS-6 Harmonist Pedal
When I plug in my guitar to the Fender Frontman 64R Amp and I just barely move the cord, it make this really loud screeching type noise. It's not an old amp; I got it about five months ago. I can't...
Yes, there are several possibilities. First thing is to disconnect your guitar and then plug in the cord to the amp. Expect a bit of hum. If it screeches, then problem is not feedback via the guitar. If it doesn't MAYBE your guitar is "hearing the amp" which the guitar is then a microphone and can feedback. Moving the cable generates electrical noise which can trigger the feedback to start.
If you get the screech without the guitar connected, then TRY a new guitar cable. Make sure it is an INSTRUMENT cable... I have seen some try to use speaker cables or junky 1/4 inch cables intended for home stereo... these will NOT work and can cause the feedback. The next possibility is a broken jack on the amp. This would require repair. The common cause of this is to fail to run the cord through the handle of the amp... one trip on the cord or step on it pulling the plug sideways in the amp and the jack is broken and it is a trip to the shop as well. While on the subject ALWAYS run the cord at the guitar end either through the strap or your belt loop. Cords left dangling keep rotating and soon wear out the plug and also the jack in the guitar and then that has to go to the shop.
May 16, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Amplifier Screech at High Volume
What you're hearing is FEEDBACK caused by the nearness of the guitar to the amplifier speaker. Always mute it when not in use, or don't move it close to the guitar amplifier speaker when unmuted.
Usually, even though you hear a high-pitched screech, the problem is actually caused by low frequencies, sometimes below the human hearing threshhold (i.e., subsonic) because they are more omnidirectional and thus more easily easily can loop between input (the guitar pickup, especially on a hollow-body guitar) and output (the speaker). The screech frequency is determined by the distance between input and output, determining how quickly the output reaches the input (then loops around through the amplifier). Therefore, reducing the BASS a bit will often alleviate some of the problem.
This is basically the same type of feedback heard when a microphone is turned up too loudly or the mic is pointed at the PA speaker. Avoid those actions and your feedback will be minimized.
Only time and experience will allow you to automatically take actions to avoid feedback. I worked in the San Francisco Bay Area as a manager and sound man for rock bands and several nightclubs for 22 years. My college major was Physics (which includes acoustics).
Keep on rockin'!
Feb 10, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Peavey Bravo 112 hums and has less poast gain volume
Try checking to make sure that all the tubes are properly seated in the tube sockets and that one wasn't broken at the base. Considering that you just bought it you should be able to take it back and have it serviced for free.
Jul 19, 2009 | Orange Crush 30R Reverb Guitar Amplifier
Line 6 Spider Iii 75 Guitar Combo Amplifier Logo
102 people viewed this question
Top Line 6 Music Experts
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Line 6 Music Expert? Answer questions, earn points and help others
