Question about SAMTRON 55V 15" CRT Monitor
Screen turn into pink (light rise color)
Display monitor screen suddenly turns to pink after some min it back to its normal position.. I have adjust the color setting and hadware accelaration setting in the Windows display setting option, but it is not working. From booting screen itself gets pink.. so i feel it is the problem inside the monitor.. Pls suggest me any solution.......
  • Anonymous Dec 28, 2007
    my Samtron monitors color changing. it some times get back into normal position. for each color some other colors are showing. for eg. for red some black like color appears (not exactly black).
It may also because of a bent pin or loose connection of your monitor to the system
Posted on Sep 30, 2007
  • 65 Answers
If you have the skill for take off the cover,take off the metal shield and cables until you reach the CRT board,have a 100watt light on,a solder hot iron in one hand and a few rings of tin in the other, obviously take off the plug and left it over a few meters,and waited a few minutes to give some capacitors discharge time,.............it's easy !!! resolder the joints that like dark,mainly see the big transistors,(or IC)that have like rings on it's pins, and thats all. I tell you its easy okay then you have to "rebuild" your monitor back.
Posted on Jul 10, 2007
SOURCE:
How do I adjust the color on monitor?
Instructions
  1. PC Monitor
    • 1Check the color balance options on your monitor. Typically, there is a button on the monitor itself that can be used to enter the Settings menu and configure color. The color balance may have somehow been changed, resulting in the pink image.
    • 2 Calibrate the color system for your monitor through Windows. Press "Windows-X" to open the Power User menu and select "Control Panel." In the Search bar, type "calibrate display" and click on "Calibrate Display Color" when it shows up. Provide your administrator password or confirmation if prompted.
    • Sponsored Links
    • 3 Check to see if the cable connecting the monitor to the computer is loose by lightly jiggling the connector at both points. If it's loose, this could be the cause of the display error. Secure the connection and see if the issue has cleared up.
    • 4 Check the connectors themselves for bent or damaged pins. A damaged pin can cause a faulty connection, which can lead to errors like a pink-tinted screen. If the pins are just bent, you can try to bend them back into place with a pair of needle nose pliers. If they are otherwise damaged or missing, you'll have to replace the cable itself.
    • 5 Perform a factory reset of your monitor if replacing the cable has not repaired the issue. Instructions for a factory reset vary from one model and manufacturer to the next, so consult your owner's guide for detailed instructions.
    • 6 Connect your computer to a different monitor if the problem persists after factory reset. If the problem persists with a new monitor, the issue is likely with your video card. If this is the case, consult the card's manufacturer for detailed diagnosis and assistance. If not, your monitor may be damaged and incapable of rendering a properly colored image. Take it to a repair professional for repair or replace it.
Read more : http://www.ehow.com/how_8446307_fix-color-pink-hue-everywhere.html
GOOD LUCK.
May 11, 2014 | Acer V193w LCD Monitor
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
MY MONITOR HAS TURNED PINK
what monitor you have LCD or the picturetube monitor?
If it is a Picturetube monitor, the blue/ yello/ green cathod might have lost.
If they are showing ok then you can adjust your Monitor Data Cable, if needed if may need to replaced. The major probablity here is showing as Data Supply Cable for Monitor needs to be changed, i could help more if i had more details about the problem.
Feb 24, 2010 | Computers & Internet
My monitor suddenly turned pink and light green. I can hardly read text or see picturs. How can I fix the monitor/screen color problem? Thank you.
if this is a CRT or big monitor to the back you have cold solder on the CRT board this is the board to the back to make sure tap the monitor to the back and see if the color change back you will have to open and re solder that crt board
Jan 11, 2010 | Gateway FPD1975W 19" LCD Monitor
My monitor suddenly altered the colors on the screen; white background now appears slightly pink, green appears black. How can I make adjustment to correct the color?
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
Aug 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
LCM-22w3 monitor suddenly changed colors. All
Try adjusting the monitor cable that goes from your monitor to the back of your computer.
Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
Dead screen
this would be due to a convergence issue either in the color wheel or the ballast. It is probably a balast that will need to be replaced.
Mar 31, 2009 | LG Televison & Video
Pink tint on Dell 1704FPT Flatpanel LCD
Unfortunately if you have tried a different machine (it could be a bad video card) and tried the cables most likely it is the screen itself. Typically when one of these lcd's begin to fail the pixles no longer access the blue field and you see mostly red instead of the other two colors. In short pink screen is terminal, it will last for a while longer.
Oct 01, 2008 | Computers & Internet
I have a HP pavilion mx70 monitor which is about 7 years old. Suddenly when I switch it on the screen keeps turning a 'rose' color. It occassionally goes back to normal but will constantly turn pink again....
Its the monitor. first I highly suggest upgradeing your computer. But the problem is that over time the connection port in the monitor that hooks the wire up to the computer gets worn down and the solder begins to weaken. And eventully a connection becomes loose or breaks and when the cable is at a certain angle or is moved around the screen can change colors. So if you have this problem jiggle the cable a bit or try to find a position you can put the cable in so that it doesent move around too mutch.
Jun 05, 2008 | HP Computers & Internet
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
179 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Ekse
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
