Question about AOpen XC Cube EA65-II Barebone
Processor fan doesn't start
I have my new barebone but I noted that the processor fan tries to start rotating when I switch pc on, but doesn't start: is that normal?
Thank you.
    President:
  • 1,179 Answers
No, it's not normal. Make sure you have the cpu fan plugged into the proper mb plug. It should not be plugged into a chassis fan plug or your cpu will severely overheat. On the mb there should be either a 3 pin or 4 pin that is marked cpu fan. It will look exactly like the chassis fan pin group but that one will be marked cha fan. If it is plugged into the proper area then you may have a faulty cpu fan. Replace with a new one and see if that fixes the problem. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 23, 2009
Nc6220 did not display unless i pres down the proccesor
The processor sounds as if it is not being held by the CPU locking device. Get it re-installed and you should be okay. It is just a case of removing the cpu fan and heatsink ( while the power lead is unplugged of course) lift the locking lever (dependinding on the processor type) and reseat the processor, lower the lever and lock in place. try to give the cpu a wiggle, but not too hard, as long as it doesn't move then rebuild the computer and try it out. Good luck, and don't try it as if you are removing a six inch nail with a mallet. It should come to bit easy enough.
Jan 25, 2012 | HP Computers & Internet
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
167 bios
To troubleshoot processor issues, follow these steps and test the processor after performing each one:
Notes:
  • If either the system board or processor have been replaced, reflash the BIOS to the latest level before proceeding.
  • Some computers allow the fan to stop spinning. This is not a malfunction. The fan should start spinning as the system heats up.
  1. Ensure the latest BIOS code is installed. This will correct any 167 POST errors for the Intel microcode update and "176 No Processor CPUID" post errors.
  2. Reseat the processor and the heat sink
    Note: Do not touch either the processor or system board contacting surfaces. These can be extremely fragile and bent pin damage due to touching is not covered under warranty.
  3. Verify the processor fan operation is not blocked by cables or other hardware.
  4. Verify that any replacement processor is the correct architecture for the system.
May 25, 2011 | IBM NetVista PC Desktop
On switch on, amber loading light is fixed on, & monitor displays "no anologue signal" & then switches off.
Emachines (the older ones) are bad for the thermal paste to dry up causing the processor to overheat,pick some up at radio shack and remove the heatsink from the processor and put a light coat on top of the processor then replace the sink. Are there any beeps coming from the pc? Does the fans kick on? Try opening the case and pulling a stick or ram and restart if no luck replace the other stick with the one you pulled first.If all that doesn't work I have seen a power supply go bad and do just that. I know it may be a lot of ifs but its a place to start!!! GOOD LUCK
May 09, 2011 | E-Machines eMachines Desktop PC
I have a sony vaio vgn nr430e laptop the display goes off as soon as the cpu fan starts rotating
That could be a problem with the heatsink/fan assembly on the processor. It sounds like the processor is starting up, getting warm as they do, the fan starts up but does not cool efficiently enough and forces a shut down due to heat.
Clean out the fan assembly and replace the old heatsink compound on the processor heat sink.
Hope that helps.
Dec 09, 2010 | Sony VAIO VGN-NR430E/S NoteBook
My computer comes on and then immediatley shuts off the starts the process over. Doesn't have time to even try to boot.
1.Processor may be overheated,because the processor fan may not be rotate.
if processor fan is rotating then...
2.Remove the Hard disc power connector and data cables then try to on the computer.
3.Remove the Cd/Dvd drive power connector and data cables then try to on the computer.
4.Remove any other drives connected with your computer.
5.Remove the printer,scanner,mouse,keyboard connected with your computer.
thank u .... now u can find the problematic device. All The Best...
Apr 22, 2010 | Dell Dimension 2350 PC Desktop
Problems installing a new processor
take proc. out and check if you bent any pins when replacing it. make sure you installed it correctly. some motherboards wont boot if cooling fan is not connected to motherboard. make sure motherboard supports new proc.
Jan 08, 2008 | ASUS Pundit P1-AH2 Barebone
Socket processor Fan -p2
As I see your system is a bit old so the fan may be broken. try to replace it with a new one. Those fans are very cheap today.
Do not use your computer without the processor fan.
I am sure your problem will be solved!
If you have found this solution helpful please rate it as "Solved"
Thank you
Oct 31, 2007 | Computers & Internet
My shuttle wont boot
If it's a new build, can you give details on processor etc. But if there is no bios, it's normally a memory incompatability problem, or the processor isn't active.
Jan 08, 2007 | Shuttle SN41G2V2 Barebone
AOpen XC Cube EA65-II Barebone Logo
170 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
