Question about Xerox WorkCentre M20i All-In-One Laser Printer
DADF not feeding on a xerox m20i - Xerox WorkCentre M20i All-In-One Laser Printer
3 Suggested Answers
  • 2072 Answers
SOURCE: xerox workcertre m20i
Most likely not going to find just the glass. Go to google and search for " the parts drop" they will be the first item in your search. Call them and ask for Britt, he will work with you to get what you need at a very fair price.
Posted on Oct 15, 2008
  • 239 Answers
SOURCE: xerox m20i scanning problems
In this problem, you might need to have xerox download the latest software with the Xerox laptop computer to correct the light copies.
Not seeing this machne, there are optics mirrors that get dirty in the lazer areas and head assembly that might need to be serviced.(cleaned)
Posted on Nov 18, 2009
Codigo 05.283 xerox 7655
El manual responde que la DADF onde escanias tus papeles tiene un sensor malo adonde se sale el papel.
Esto es para la WC7655?
005-283 RAP
BSD-ON: BSD 5.2 - Document Stacking
DADF Stack Height Sensor Logic Fail.
Jun 14, 2016 | Xerox WorkCentre Pro 765 Laser Printer
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Download xerox m20i scanner software
Go to Xerox.com and under drivers and downloads for the M20i , download firmware version 3.02.
And follow the instructions to put the new software onto your printer.
Jun 22, 2011 | Xerox WorkCentre M20i All-In-One Laser...
Error code 005-121
005-121 RAP DADF Feed Sensor ON Jam. You may have some paper jammed inside the printer.
May 03, 2011 | Xerox DocuColor 240 All-In-One Laser...
Will not feed original to copy from top insert level. Will copy if original is placed under, laid flat .
your feed tires for the document feeder are probaly needing replaceing. turn off mach and make sure document feeder plug is secure.
Dec 31, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox m20i scanning problems
its probably set to a low DPI.......change your dpi to like 600 when scanning
Nov 02, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Cannot print double sided
On the machine when a 2 sided document is inserted in the document handler, select the 2x2 button on the console. Press the start button and the machine will feed the document in, and do a reverse of the document for the second scan. In the paper feeder, the machine feeds the paper in and reversed the copy back into the machine, flips the copy then feeds the copy back for the second side to be copied.
If you do not have a m20i, the lower model numbers will not do two sided copies.
Aug 14, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Changing print properties shuts down all open programs instantly!
I would first of all Go to the Xerox.com site and go to Drivers and downloads for the M20i and install the newest firmware. I believe the current version is 3.4.
I believe your problem would be resolved in loading the newest machine firmware.
May 05, 2009 | Xerox M20I Printer
Xerox M20i scan to e-mail
You can not scan with a M20i with an Ethernet cat 5 cable. It can ONLY be done via a USB or parallel cable.
If you don't believe me, which many on here wont accept the truth, here is the note from the Xerox documentation..
The WorkCentre can scan a document via Direct Scanning using a USB or Parallel Port connection only.
Jan 11, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox 423 DADF seting
what do you mean dadf seting
you choose the dadf from the front screen
Dec 11, 2008 | Xerox WorkCentre M123 Copier
Xerox WorkCentre M20i All-In-One Laser Printer Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
