Question about Hoover HF7 160E Front Load Washer
Hoover hf7 150m
Hi the machine , was working fine , but then kept stopping at any spin stage , it pumps out ok even checked the filter , and now will not fill hot or cold , the drum does turn as if its washing , I did take the drainage pipes off the bottom to check for blockages but all ok
4 Suggested Answers
gittos73
  • 244 Answers
SOURCE: Drainage
more then likely that your pump or the drain hose has a slight blockedge you can kill 2 birds with 1stone here you can get rid of the water and see if the pipe is blocked by taking the pipe and placing it low to the ground into a bucket if the water comes out slow then you will have a blockedge and your pump will be ok now make sure you pull the plug out pull the asher out now tip it backwards just enough so you can see the pump at the back undue the clip which holds the pipe onto your pump now there will be some water that will leak out once pipe is free you can pure water down it by putting it onto the tap if it comes out fast then the block is in the pump
Posted on Oct 18, 2007
  • 1003 Answers
SOURCE: hoover nextra wont fill
REPLACE WATER INLET SOLENOID
Posted on Feb 02, 2008
  • 38 Answers
SOURCE: Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Posted on Mar 05, 2008
Hi i have a hoover washing machine hnf 6127 it functions perfectly but wont spin the drum goes round on the wash cycles but will not pick up speed on the spin i have checked the filter is not blocked
If it is not picking up speed on the spin cycle then it is the motor or the belt. check the belt first for proper tension and make sure the motor has the proper output. I think something is slipping and not transferring torque to the tub.
Mar 12, 2014 | Hoover Washing Machines
Hi, I have the Hoover d14194 bagless pet vacuum..when I switched it on it worked but kept cutting out, I emptied it and cleaned the filters but now it won't even switch on.is there something I can
You could check the motor brushes, if they are worn and check for loose wire connections.
Another possibility is that there may be a break in the lead, plug it in and shake the lead, if it starts and stops you have probably found your problem with a broken lead.
Jan 01, 2013 | Vacuums
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
Blocked filters/dodgy pump?
The problem you are having could simply be the inlet valve.
The inlet hose is attached to the inlet valve on the machine. Where it screws on that is.
You can get a valve from an appliance parts shop and they are inexpensive.
Jun 18, 2009 | Hoover HTC243 Top Load Washer
Hoover Zodiac 12 that won't spin.
possible filter blockage, or the pump has failed/seized, machine CANNOT spin while it CONTAINS WATER, the door interlock will not open for the same reason,WATER in drum.
manually drain excess water into a bowl now
1 clean filter, 2 check pump for objects that prevent impeller working may still need pump if seized
Jun 12, 2009 | Washing Machines
Hoover CA230 1300 Special Edition Washing Machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Mar 08, 2009 | GE S8000E
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Jan 14, 2008 | GE S8000E
Washing machine say NO!
because of what you say about it feels like it is exploding on spin cos too much water, suspect it may be drain pump. check filter is not blocked. check no foreign object stuck in pump - bits of bra wires are the favourite
Nov 17, 2006 | Hoover H120M Front Load Washer / Dryer
Hoover HF7 160E Front Load Washer Logo
128 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
