Question about HP 2211x 21.5-Inch LED Monitor - Black
Hp 2211x ps3
I have a hdmi to dvi d adapter and for some reason it just shows a black screen and tells me to check my cables. the HDMI is gold plated and the dvi d cable is a single link dvi d. I really need help, I would be very appreciated. thank you!
  • 36 Answers
SOURCE: how to hook up a hp pavilion laptop to a hdtv
if it worked fine at some point then it should work fine now... i use hdmi to hdmi from my laptop to tv all the time dvi would only cause quality loss.
the first thing i would try would be to change your resolution on your laptop to a couple different settings. a lot of times, if its not set to one thats compatible with your tv, you won't see anything.
if that doesn't work, go to personalization and open the tab that says "connect an external display" and toy around with it. but yeah it doesn't sound like you have any hardware problems there.
hope this helps
Posted on Jan 16, 2009
  • 788 Answers
SOURCE: I have an HP Pavillion DV5000, and would like to
Try going to menu on TV and set input to DVI HD. Hope this helps
Posted on Sep 20, 2009
  • 129 Answers
SOURCE: Does my HP PAVILION 9500 have a DVI port for me to
yes DVI port is available in dv9000. its on left side of the laptop
Posted on Feb 09, 2010
parrotheadpc
  • 2600 Answers
SOURCE: HDMI to HDMI
We are running our DV-7 with a 20 foot high quality HDMI cable with no frop out or interference. The DV-7 has a decent video chip and will push the signal without incident.
Posted on Aug 01, 2010
Testimonial: "Exactly the information I needed. Thanks for the quick and "right on point" response! What a great site!"
puertobori
  • 7733 Answers
SOURCE: how to connect hp pc to sanyo hdtv? I have a
HP Support ->link.
Posted on Oct 06, 2010
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
How to connect the HDMI Cable from monitor to Computer which has no HDMI ports?
You need a purchase a new cable. I assume your HP pavilion is under 5 years old. And you should have a white DVI port in the back for a monitor. If you do have that connector, then all you need is a DVI - HDMI cable, make sure the DVI will be to the computers end and HDMI to the monitor.
for example this cable:
http://www.amazon.com/AmazonBasics-HDMI-Adapter-Cable-Meters/dp/B001TH7T2U
Dec 31, 2013 | HP Pavilion Computers & Internet
When using PS3 on RCA D52W19 TV, the screen does not fit ( it is zoomed and off-center) in 1080i resolution.
hello!
Have you tried to toggle "format" or "screen size"? On those sets non HD and HD settings could be adjusted separately. Try that, first. If no luck, try similar settings on PS3. I bet, you will be able to match screen format there, as well. To me it looks, like picture formats are mismatched. Also: try to use "component" cables, instead of DVI adapter cable, if nothing works.
good luck,
Alex.
Feb 16, 2012 | RCA D52W19 52" Rear Projection Television
How do i set up my acer pc to work on my tv
The detail in this answer is somewhat in disproportion to the detail in your question, since I want to help you to the best of my ability. It is, however, much easier for a solution-provider to give succinct, accurate, relevant and useful answers if the customers helps the process, as much as possible, by providing as much background information as possible.
You give no specific information about either the PC's or the TV's model number or specifications and are yet to respond to the other expert's valid prompt for additional details, so I will assume that you are only interested in general non-specific advice, as that is all that I will be able to offer you because of the sparse information in your question.
If both your computer and your TV have Video Graphics Array (VGA), Digital Video Interface (DVI) or High Definition Multimedia Interface (HDMI) ports, then you can connect the two devices with the appropriate VGA, DVI or HDMI cable.
If your TV does not have the above ports but only has Radio Corporation of America (inventor - RCA/Phono) connectors, then you can use the appropriate VGA to RCA/Phono, DVI to RCA/Phono or HDMI to RCA/Phono Adapter Cable between the TV and the PC (see images below).
Since all cable interconnections suffer from some degree or other of signal degradation os dissipation and gold is the most efficient conductor amongst the metals commonly used for cable connections, cables with gold plated connectors perform the best and therefore cost more than standard cables with connectors made with cheaper, less conductive metals. You should consider buying the best cabling that you can afford.
Once connected, if your TV has a Remote Control, press:
Menu -> Input (Signal/Device) Source -> PC -> Select/OK.
If you have no RC, then you can try using the Program or Channel selector buttons on the TV's control panel to manually select the Input Device.
When the Desktop PC is powered up, after setting up the TV as described above, the PC should send the image to the TV.
If the above information does not match the specifications of your equipment, them please post further background information here and one of the experts here will try to offer you further advice.
11_27_2011_10_20_21_pm.jpgGold Plated Male to VGA Cable
Gold Plated Male to Male HDMI Cable
11_27_2011_10_21_13_pm.jpgGold Plated Male to Male HDMI/VGA to RCA Adapter Cable
Gold Plated Male to Male DVI to RCA Adapter Cable
Gold Plated Male to Male DVI Cable
11_27_2011_10_40_02_pm.jpgStandard Male to Male DVI Cable
Nov 27, 2011 | Acer Computers & Internet
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
PS3 to Infocus LP 350 projector using HDMI
M1-DA is a type of DVI connection that produces both analogue and digital signals, the easiest and most quality source cable for you to get is a HDMI to M1-DA cable which is now widely available for purchase.
Infocus should have included this cable in with your projector, but instead the power at bee decided to put a M1-DA to DVI-D cable instead when most visual devices now support HDMI and not DVI nowadays.
Thanks
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
DVI port not working
change the resolution of the screen the computer does not suport that resolution, if you chang that will be ok.
Jan 19, 2009 | NEC-Mitsubishi MultiSync 1735NXM Monitor
THE MONITOR SONY SDM M81B HAVE HDCP??
A DVI to HDMI cable should work, I have the same monitor, but attached to an Xbox 360, if that doesn't work then buy a HDMI Cable and a HDMI (Female) to a DVI (Male) Adapter
Cheers
Nov 03, 2008 | Sony SDM M81B (Black) 18.1" LCD Monitor
Ps3 hook up
Yes, you can! But not straight out of the box. You need to purchase a DVI to HDMI cable adapter. It will convert it so your tv can use it. Here is a link to some:
http://www.connectworld.net/syscon/dvi-to-hdmi-adapters.html
Hope this helps! Please rate me!
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Phantom horizontal upward-scrolling lines... from a PS3 with HDMI to DVI
Everything works better on component, I know the salesman at the store says its better, but its not....I tell customers all the time (I could hook up three tvs side by side..HDMI-DVI-Component and the human eye cannot tell the difference) The reason the DVI and Hdmi were created was for copy guard encription....Although the component is an analog signal, it goes to a A/D conversion..........But this is just my insane opinion...Good Luck
Jan 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
HP 2211x 21.5-Inch LED Monitor - Black Logo
65 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
