Question about Acer Aspire 4720 Notebook
Windows Error Recovery
Two weeks after we purchased the system the computer refused to run Windows. It says Windows failed to start. a recent hardware or software change might be the cause. To my knowledge no software was installed with direct supervision.
  • Dan rogers
    Dan rogers May 11, 2010
    try to push F8 or F10 right before windows loads and start windows in safe mode. Then see if the computer found any new hardware. If not try to restart but normal this time and see if it works
  • Steve Ndatinya Jun 09, 2013
    i tried to start windows in safe mode, but it shows me that it is repairing endlessly the problem, i have been waited for 5 hours it still searching for the problem. Any other solutions?
  • 1,179 Answers
Using the Windows installation cd. Boot the system with the CD in the drive. When given the option select the repair option. This should correct the issue. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 23, 2009
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem: 1. Insert your windows installation disc and restart your computer. 2. Choose your language settings,...
Big trouble. Try safe mode, if possible. Don\'t use recovery procedure, just manually remove unnecessary things. Finally backup your data, and reinstall whole system?
Mar 19, 2014 | Acer Computers & Internet
Windows XP failed to start because of a recent hardware or software change?
You have corrupt or deleted windows files or possibly a hardware error. The first thing is to try a repair using a Windows XP CD that came with your system.
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below. This portion of the Setup program prepares Microsoft Windows XP to run on your computer: To setup Windows XP now, press ENTER.
  • To repair a Windows XP installation using Recovery Console, press R.
  • To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup: do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you do not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
7. You will need to apply Windows updates after this procedure.
Not a trivial task but it will work. I do this for fun & feedback so 4 thumbs would be nice.
on Sep 21, 2010 | Computers & Internet
Windows will not start up or launch start up repair
please insert your operating system disc in the drive and restart the computer .
Select the boot device as cd/dvd drive and save the settings in BIOS .
restart the system and boot it using the CD.
also, you can insert the disc restart the system in safe mode.
try to restore the computer using system restore.
May 21, 2012 | Dell Inspiron Mini 10v Netbook
Windows fails to start
Is the hard disk, change the hard disk and/or the sata interface wire.
Mar 10, 2012 | Toshiba Computers & Internet
My dell inspiron 530 goes to windows error recovery.Window fail to start
Do you allow it to 'Repair' the Windows Install? - If not try that - if still having a boot failure - then you will need an OE Windows disk to fix Windows.
Dec 02, 2011 | Dell Inspiron 530s Desktop Computer
I get this error "The application failed to
Probably cause: The Windows Registry is corrupt.
1. Try to set back a recent but older Recovery Point from the System Recovery.
2. If it does not help, set back an older Recovery Point from the System Recovery.
3. If that does not help, Restore a System Back-up (I hope you made a back-up).
Jul 11, 2011 | Computers & Internet
Everytime i boot my Toshiba Satellite L305D i get a message on a the black screen before windows startup saying "windows has encountered a problem communicating with a device connected to your...
If you have external USB and/or CD disconnect them and try again. Otherwise it could be a fault hard rive - try to boot from an emergency CD (hopefully you created one when you installed Windows).
May 11, 2011 | Computers & Internet
When i start my laptop it wont start windows, it just goes straight to a windows error recovery screen, it says windows failed to start. a recent hardware or software change might be the cause. it...
I recently had the same problem. I also thought it was a windows update that caused this: forced shutdown, startup repair, etc. The last time it did startup repair it could not repair it. Lucky for me my pc still had one month of warranty left. So after leaving it with the "pro's" for a week, I called to say what's up, figured it out yet? The techs told me that they had run every diagnostic test available and all the hardware had passed safely. So I asked what it could be and they said, more than likely, that Windows Vista software had somehow become corrupted- the only repair to fix this? a complete recovery. They offered to do a recovery for me for $130- lose all info except what's on recovery partition.
(No, thanks, I'll do it myself.) Went online, found how to start recovery (Alt + Fn + F11, for my Gateway DX4710), did it myself, works fine now, haven't had a problem since.
On a side note, if your RECOVERY software becomes corrupted, you will need recovery disks to fix this. I got lucky this time, but bought a set of those (JIC) for 20$.
I now do a backup at least once a month so it won't be a TOTAL loss should it ever happen again.
As a worst case scenario, if you need to figure out how to recover your computer, looks like HP owns Compaq. You could start here:
Hope this helps.
Dec 15, 2009 | Computers & Internet
Windows boot manager page with status 0xc00000e9
If you don'yt have a Vista DVD,you can borrow any for startup vista repair. This is very common and HP/Compaq don't usually give operating systen vista dvd
Oct 02, 2009 | HP Compaq Presario V6000T Notebook
Acer Aspire 4720 Notebook Logo
436 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
