Question about Mitsubishi VS-60705 60" Rear Projection Television
Mitsubishi VS-60705 - picture flutters vertically and horizontally
We have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally.. Can anyone give me some input on what could possibly be wrong?? The TV is about 8 years old.
  • 2 more comments
  • jesus hernandez Dec 04, 2007
    I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
  • Anonymous Oct 20, 2008
    I also have the same problem with mine. I was told to check the two 9 volt regulators on the signal board. Also, check the capacitors that come off of the output of the regulators.
  • JONLCY Nov 29, 2008
    i have a set that when i turn it on it's blurry untill it warms up?? then it's ok ????
  • mmason011 Jan 18, 2009
    My VS60705 flutters Vertically all of the time. Sound and all other features work great. Who can fix it?
  • 398 Answers
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Posted on Jul 09, 2007
Posted on Jul 10, 2008
SOURCE:
My tv mitsubishi vs-60705 looks great when i first turn it on after it warms up picture starts to shake and gets worse the longer its on. what is overheating to cause this ?
Sounds like you have a swollen cap in your horizontal hold circuit. Look at your board closely, and I am sure you will find one that is bulging on the top. Just replace with the same value.
May 16, 2011 | Mitsubishi VS-60705 60" Rear Projection...
VS-60705 60
The picture is flipped left-to-right or is upside-down or both. This cannot happen as a result of a failure. For a CRT-based TV or monitor, it almost certainly means that the wires to the horizontal or vertical deflection yoke have been swapped to enable the picture to appear correct when viewed via a mirror (horizontal only) or if the unit were mounted base-up to a ceiling (both). The remedy is simply to swap the two wires to the relevant deflection yoke(s). There may even be obvious splices to guide you. There is usually a connector with 4 relatively fat wires that go to the deflection yoke on the CRT neck (NOT the PCB attached to the tube base). If you don't have a schematic, trace these on the main PCB back to their origin. The horizontal will originate somewhere in the vicinity of the flyback transformer. It may be possible to disengage the wires from the connector shell and swap them there. If not, cut, splice, and solder. Adjustment of the appropriate centering controls may be needed. For flat panel displays, it is even more unlikely this would happen as a result of a hardware failure. Most likely, there is a mode setting in the one of the setup menus for the TV or monitor itself. It could also be in the receiver for the TV, or the driver or application software of the PC. If the source is a video projector, the menu setting is likely there, to select between front and rear projection (horizontal) or table or ceiling mount (both). So, don't bother to open up the flat panel TV or monitor. The problem is not there! :)
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Mitsubishi VS-60705
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Visual
The same is true for rear projection. There may be an adjustment for vertical hold in a hole in the back of the cabinet.
Oct 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 60" Rear Projection Television Logo
670 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
