Question about WMF Bistro 384002022 Espresso Machine
Does anyone know how to open the or slide up the front of the machine? WMF BISTRO SILVER LINE
I have a 3L 22cm wmf perfect cooker which leaks, can you help?
Make sure the gasket is in the right position, the handle is placed on correctly and the slide on the handle is in the locking position. Here are more details on how to use this pressure cooker.
http://www.hippressurecooking.com/pressure-cooker-review-wmf-perfect-plus-rating/
Aug 24, 2011 | Wmf/Usa 2.5qt Stainless Steel Perfect Plus...
No.1 part, the round whistle in the middle of the lid doesn't pop up when the cooker is on and pressure is building up instead the steam comes out of small pressure ball and it sprays everywhere.
Here are detailed instructions on how to use it. It sounds like the slide on the handle was not set to the locking position:
Mar 22, 2011 | Wmf/Usa 2.5qt Stainless Steel Perfect Plus...
I have a WMF Presto coffee machine and when I switch it on it comes up with WMF-AG Bootmanager P8.5 USB 1.1 on the screen and cannot do anything at all with the machine
You have to have a lap top and software to repair! The only way to turn off the boot manager is to use the software that you can get from WMF! Try giving them a call if you don't have a tech in the area. 954-583-2269, good luck
mikey@espressomachineexperts.com
Feb 28, 2011 | Coffee Makers & Espresso Machines
How do I remove the drawer from my Hotpoint aquarius WMF 540 to clean it??? x
Open the drawer, lift or push it upwards, and pull it out towards you.
You should now be able to clean it.
Please rate my solution.
Thankyou.
Jan 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Wolfgang Puck Bistro 5 qt Pressure Cooker. How to steam?
Throw away this "Made in China" piece of **** and buy American. That's what I had to do.
Jan 05, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Cannot get replacement part...
did you try wpcookware.com?
Try this link to see if it is the right spindle.... ($6.99)
http://www.wpcookware.com/proddetail.asp?prod=BFPR00015%2D30A
Dec 29, 2008 | Wolfgang Puck Bistro 620 Food Processor
Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
Aug 12, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Lanier 5645 paper jamb
The fuser assembly can be removed by sliding it out from the front of the machine. You may have to remove a retaining screw and plastic knob, all are accessed by opening the front copier cover. Unplug machine from wall before attempting this.
Dec 02, 2007 | Office Equipment & Supplies
WMF Bistro 384002022 Espresso Machine Logo
32 people viewed this question
Top WMF Coffee Makers & Espresso Machines Experts
David Burbee
David Burbee
Frank Russell
Frank Russell
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a WMF Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
