Question about HP Pavilion xt565 PC Notebook
My hp pavilion xt 565 keeps saying "Operating System Not Found"
What do i do? How can i six this?
  • 43 Answers
A few things can fix this, all depends on what exactly is wrong, it could be the hard drive, you can access the bios and go to diagnostics and run the hard disk scan, if either fail call hp and see if they will replace it, if your out of warranty its failry simple and not to expensive to do yourself. you can also attept a recovery if you have the disks...one of these two will work its a 50/50 hope it helps!
Posted on Jan 24, 2009
Hp pavilion zd8000 keeps restarting never even getting to the start operating system
First step: Clean up the air vents (inlet and outlet) and the fan. You can use canned air to clean it up.
Second step: Use Windows media (DVD) to reinstall the operating system (it will fix the boot up problem).
If the problem persist: use a good working hard drive and install the operating system from scratch.
Mar 09, 2014 | HP Pavilion zd8000 Notebook
I have an HP Pavilion dv6500, and while I was working on my laptop it suddenly shut down by itself and restarted. When it rebooted, a message came up saying "Operating System not found". I...
Your hard drive may have failed.
I suggest you remove your hard drive and re-connect it to your laptop to make sure it is make proper connection. Boot up and go into the BIOS to see if the hard disk is detected.
If the hard disk is not detected then most likely the hard disk has failed.
To get your laptop working, you will need to purchase a new hard disk and install Windows on the new hard disk plus the Pavilion device drivers and your programs,
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Dec 18, 2010 | HP Pavilion dv6000z Notebook
Operating system not found
the hard drive might be bad or the os is not installed properlly
Oct 18, 2010 | Compaq Presario 2100 and 2500 ,NX 9000...
Operatig system not found"
Try reinstalling the operating system, if fail, try running checkdisk on the HDD. If problem persists, replace the HDD.
Cheers!
Oct 20, 2009 | HP Pavilion dv6000z Notebook
NEED HELP TO GET MY COMP RUNNING WITHOUT LOSING MEMORY
your PC SMPS has been faulty .So pls replace it.
Sep 10, 2009 | HP Pavilion xt938 PC Desktop
FAILURE to boot
is the constant noise a clicking noise? does it say operating system not found?
Jun 04, 2009 | HP Pavilion dv6000z Notebook
My hp pavilion 4200 i took the hard drive out and put it back in when i booted it up it says media cable not found then it says operating system not found. tried to run the operating system cd and it says...
The laptop can't find a hard disk, eirher the hard drive is faulty or not seated properly.
Take out the hard drive and reseat it again then see if the laptop boots up. If it still can't find the hard drive, listen to the hard drive, is it spinning up, is it making clicking noises? This indicates a faulty drive and needs to be replaced.
You can also test the hard drive by removing the hard drive and attaching it to a USB hard drive adapter and then plug it into a working computer's USB port. If the hard drive is OK then the computer will see it as an external drive and you can view and open the files.
Mar 08, 2009 | HP Pavilion ze4200 Notebook
HP Pavilion xt565 PC Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
