When i press fn and f1 my option list does not shown can't get on to the internet
  • 27,725 Answers
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Posted on Jan 14, 2013
  • 7993 Answers
SOURCE: FN+F1 no longer switches on internet, but restarts PC instead
You may have inadvertently reprogrammed the keys.
Look for utilities provided by the laptop manufacture (Programs) to configure the Fn-esse key combinations.
Hope it helps.
Posted on Sep 08, 2009
SOURCE: My Wireless Status List Menu is frozen.
got to program files,then launch manager and double click WisWBSet
Posted on Nov 10, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: computer is on, but screen is blank. used Fn &
If you shine a flashlight on the display, can you faintly see an image? If so, the trouble is that the backlight isn't working. This is pretty common, and it's usually because the inverter in the display goes bad.
Replacing the inverter is fairly simple. You need to open the open the display, which is normally a matter of removing screws at the corners and separating the front bezel from the back. The inverter is a small circuit board at the bottom, held in by one or two screws. A couple of cables plug into it. Unplug them, mount the replacement and reconnect it, put the display back together and you've repaired your own laptop. Of course you can also take the computer to a service shop if you don't feel up to trying the repair yourself.
Replacement inverters are pretty easy to find for the major brand computers. A few minutes searching the Web or checking on eBay will give several sources. Typically a new inverter costs $30 to $50. There are also many YouTube videos showing how to replace an inverter.
Good luck! Thanks for using Fixya.
Posted on Feb 28, 2010
  • 1542 Answers
SOURCE: i have just got a
Hi
you could try this combination of keys to enable/disable your webcam
FN+F1 then if you use skype or msn you could then try the camera to see if it works
also take a look in device manager under imaging devices to see if it in there and no yellow question mark beside it
if it is in there and has a yellow question mark beside it then un install it and restart the laptop
and hopefully on start up windows will re install the webcam correctly for you
many thanks
Posted on Mar 16, 2011
  • 83 Answers
SOURCE: As soon as I power
hi hope you are well, there could be a few issues that caused this, if you have another system where u can test that all components are working then try to do that, if you already did and nothing happened. Unplug the system and remove the battery. Hold the power button for 30 seconds. Then try powering up -- if it won't, the motherboard is faulty, and you'll need to replace it am really sorry could not be of further help..
Posted on Jul 07, 2011
My function keys doesn't work in my laptop toshiba satellite c660-a047
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
Jan 09, 2013 | Toshiba satellite c660
Tip
How to use F1, F2 ?..Function buttons on Acer laptop.
For those who do not know how to use the F1, F2, F3..... buttons on Acer laptops, here is an opportunity for you to know.
We see these buttons on most laptops but don't know what they are used for. F1, F2....... buttons are the first set of buttons on the keyboard. These buttons makes it easy for anyone to access some programs on the computer without using mouse.
Follow the below procedures on how to use some of these functions
>To put your Acer laptop on stand-by or to view shut down options, Press and hold Fn button on your keyboard, (without leaving it) then press F4 (Fn + F4).
>To make your Acer laptop be on sleep mode, Press and hold, Fn button, then press F6 (Fn + F6).
>To lock your Acer laptop's Touchpad, press and hold Fn button, then press F7 (Fn + F7).
>To put your Acer laptop on mute Press and hold Fn button, then press F8 (Fn + F8).
>To shut down your laptop or to view other shut down options, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
>To close any page on your Acer laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Oct 23, 2010 | Computers & Internet
How to turn off the fn key
1 - Function Keys f1 through f122 - Configurable Function key fnDisable fn in the BIOSTo disable, or enable, the function key (fn) in the BIOS, do the following steps.
  1. Press the power button to turn on the computer.
  2. Press the f10 key to open the BIOS setup window.
  3. Use the right-arrow or left-arrow keys to navigate to the System Configuration option.c02035200.jpg
  4. Use the up-arrow or down-arrow keys to navigate to the Action Keys Mode option, and then press the enterkey to display the Enable / Disable menu.
  5. Select the desired mode:
    • Disabled : Requires pressing fn key + f1 through f12 to use the action as indicated on the action key.For example, if Disabled , pressing fn + f11 will mute the sound as indicated on the key on this model PC. Alternatively, pressing f11 only will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
    • Enabled : Requires pressing only f1 through f12 to use the action as indicated on the action keys.For example, if Enabled , pressing f11 only will mute the sound as indicated on the key on this model PC. Alternatively, pressing fn + f11 will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
  6. Press f10 key to save the selection and restart the computer.
The function key (fn) option can be reset at any time.
May 22, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
My computer laptop model is Toshiba satellite P750. The FN key doesn't work. Nothing happen when i touch it.
The "Fn" key is a function key, it works with the top row of F1 to F12 keys.
By pressing and holding down the "Fn" key, then pressing one of the top
row "F" keys,
I'v provided a link for you to go to for the full list of "F" functions and what they
do for you as well as how to operate them on your Toshiba Laptop.
http://www.ehow.com/list_5941452_laptop-keyboard-functions.html
Aug 27, 2011 | Computers & Internet
How do you turn on the volume? Thank You.
1. Press the Fn key and while holding it down, press the F8 key momentarily to toggle muting of the speaker. An icon of the speaker appears at the bottom middle of the screen showing muting on or off.
2. After making sure the muting is off (no slash symbol on the speaker icon), press and hold Fn again.
3. With Fn pressed, press the key with the upward triangle and speaker symbol to increase volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume ''''''''''''
4. With Fn pressed, press the key with the downward triangle and speaker symbol to decrease volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume '''
Apr 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
Presario v2000
Try this; Press Fn+F1 instead of F1 alone or Fn+\F2 not only F2. Most laptops are by default Fn key activated so we always need to press it with the key combination.
If this doesn't help, there must be internal faulty/problem. Boot up the system and keep pressing F8 and go into "Advanced Boot options", if it's working, then there's no hardware, must be the Fn key.
Good luck
Thanks for using FixYa.
Jul 03, 2010 | Computers & Internet
Hope it helps.
Sep 08, 2009 | Medion md40298 Notebook
Mar 20, 2009 | Fujitsu AMILO PC Laptops
Blank Screen
press any key to ctivate screen.
you my have activated the instant pasword feature by pessing fn and f1 simultaneously. if you have registered a password press any key,type the password and press enter. if no password is registered,press any key to reactivate the screen.
The other option is to press fn and f5 simultaneously.
goodluck
don't forget to rank my fixya.
Dec 30, 2007 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
