Question about Electrical Supplies
Wiring up a switch in kitchen
Got two single on/off switches in kitchen trying to change one and now light wont switch on.
  • 691 Answers
Do they control the same lights please post picture of back of light switch and the wires in the wall. pictures of old light switch too please
Posted on Jan 14, 2013
Need help rewiring two single celing fan and kitchen lights wall switches.
Two single switches operating a ceiling fan and a ceiling light?
Aug 06, 2017 | Electrical Supplies
TWO BLACK WIRE COMING FROM THE WALL ONLY DIMMER SWITCH LIGHT WONT GO UP AND DOWN
You are trying to connect a three-way dimmer in place of a single pole switch
Jul 02, 2013 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
I remodeled my kitchen and replaced my leviton dimmer switch with another brand. After installation I turned the light fixture on. Only one of the three lights of the single fixture turned on for...
Hi Leonard,
I'm a licensed electrician and will be happy to help you get this working again. I suspect an incorrectly wired or incompatible switch or a load that is not designed for dimming. To know which one(s) is the problem and to be able to provide a solution, I need a little more information.
1) What was the old switch brand and model number?
2) What is the new Leviton switch's model number?
3) What type of light bulbs are you trying to operate in the 3 fixtures?
4) What is the number of and wattage of each lamp in the fixtures?
5) How many switches operate the lights?
5a) If more than one switch is used, what is the brand and model number of the other switch(es)?
Thanks
Oct 05, 2012 | Electrical Supplies
How to you install a Leviton Slide Dimmer with Preset No. IPI06 to a double switch box where one switch controls the ligth fixture over the table(the one I want to connect the dimmer to) and the secon
Hi Velie,
I am an electrician and can help you wire this switch. If I understand correctly, you have a two-gang switch box in the wall. In it, you have two switches installed. One switch is a 3-way type, and is one of two (or more) switches used to control preparation area lighting. The other switch is a single pole type and controls a light over your kitchen table. Right?
If this is correct, remove the double switch wall plate. Let's set aside concerns with the 3-way switch. We have nothing to do to this switch so we will not need to remove it from the box, nor will we need to disconnect it. It works independently of the switch that controls the light over the table.
Remove the switch that operates the light over the table. If it is indeed a single pole switch, it will have just two terminals for wires to connect. It will probably also have indications for ON and OFF on the handle. If installed correctly, flipping the toggle up or pressing the top of the switch will turn the light on. If is a 3-way switch, it will have terminals for 3 wires to connect. One of the terminals will be a dark color from the other two. Additionally, no ON and OFF markings are on the switch handle and the light may turn on in either handle position (depending on the position of other switches controlling the light). With this information, I assume that you have now verified that it is in fact, a single pole switch. Right?
If all is going as expected, then we can continue. Shut off the power. Since a single pole switch has only two wires to connect, this should be fairly easy to do. One terminal should have a single wire that goes to the light over the table. The other terminal should have a wire that is powered all the time. It is very possible that the wire that connects to this terminal is ALSO is connected to the the 3-way switch either directly, or by a short length of wire that has a wirenut to connect several wires together. If you need to verify a connection to the 3-way switch, remove the switch from the box if needed (do NOT disconnect any wires). The wire should be connected to the dark colored terminal screw of the 3-way switch. This would indicate that this wire - and those connected by wire nut to it - is the source of constant power. Carefully fold the wires into the box and re-secure the 3-way switch if you pulled it from the box.
You new switch has a single RED wire and TWO black wires. Twist a wirenut cap on ONE of the black wires (it does not matter which). Remove the wire that was determined to be powered all the time (was also connected to the 3-way's dark colored terminal) from the old switch, and twist it around the dimmer switch's remaining BLACK wire with a wirenut. Disconnect the remaining wire from the old switch and twist it around the dimmer switch's RED wire with a wirenut. Add the dimmer switch's GREEN wire in to the bundle of uninsulated ground wires in the wirenut inside the box. Fold all the wires gently into the box and secure the dimmer to the box. Install the wall plate and turn on the power.
I hope this helped & good luck!
Feb 10, 2012 | Leviton MFG L00-IPI06-1LM DIMMER SLIDE...
Want to install ab switch
hello. this installs just like a regular switch. NOW let me ask you one important question. Is this the only switch that controls the light or are there two or more.
if it is the only switch, called a single pole switch all you do is kill the power, remove the old switch and connect the two black wires to the new switch, and the ground wire[if there is one] to the ground screw.
if there are two switches that control this light you have what is called a three-way switch. it is still easy to change but you must change using a three way AB switch, not a single pole switch.
Also, you can only put the AB switch at one end, not both.
Sep 14, 2009 | Lutron AB-S6AM-IV Light Control by LUTRON
Dashboard lights won't come on
Most often the tail lights and dash lights share a single feed and fuse.
Assuming you have checked the fuses (probably marked as tail or courtesy)
If you have good fuse and the head light gives a voltage out while in the 'parking light' position (usually between off and headlights) then you need to start chasing wiring.
Jan 30, 2009 | 1989 GMC Suburban
Connecting Leviton Decora light switch.
At the switch you have a feed wire coming in this brings in power which originates in the electric panel. You also have a feed or feeds goings out to other lts or switches, this you seem to have on the switch. instead of the closet switch loop.undo all the wires. find the only hot this is the one wire you can touch to the others and make different lts come on i reccomend getting a electric tester to do this. FInd the wire that goes to the closet lt. Once your sure put it to the side. wirenut all other wires together with the hot wire. this makes all other switches independantly hot. connect the hot to the switch and the closet lt to switch. I HOPE THIS MAKES SOME SENSE TO YOU . let me know if i can help
Dec 13, 2008 | Leviton 104-05611-2WS 15A Decora Single...
My tenant was complaining taht he was getting a shock when he touched a Leviton 104-05611-2WS 15A Decora Single Pole switch for a bedroom closet. My problem is I now cannot figure out how to reconnect the...
The three black wire are as follows: One is the hot wire. One feeds the closet light. One feeds the lights for the kithen and bath. Turn off the power at the circuit breaker or fuse panel and disconnect all three black wires and be sure they aren't touching anything. Turn the power back on and using a test light or meter determine which black wire is live. Turn the power back off and mark the hot wire with a pen, marker, or piece of electrical tape. Connect the wire you marked with a wire nut to one of the other two black wires. Turn the power back on. If the closet light comes on, that is the wire that you want to connect to one of the terminals of the switch. If the lights in the kitchen and bath now work, leave these wires connected together and connect the third wire to one of the switch terminals. Turn the power back off. While the hot wire and the wire for the kitchen might have both connected to the switch terminal, this is no longer allowed by code. Instead take another piece of wire of the same type and connect it to the hot wire and the kitchen wire with the wire nut and connect the other end to the other switch terminal. There should be a green ground screw terminal attached to the metal frame of the switch. Using a green or bare copper wire connect this to the ground wires in the switch box. Reinstall the switch and turn the power back on. Everything should be good now. If the fuse blows or the breaker trips, replace the switch.
WIRE CONNECTIONS
may i know the exact model # of your unit, and the part # of your switch control.
let me know, thanks.
micro
Aug 26, 2008 | Kitchen Ranges
Electrical Supplies Logo
26 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
