Question about Kohler Automatic Battery Charger C-292865 120/240 Vac 1 Phase
The kohler charger can't seem to work automatically, it keeps charging
The kohler charger seems to keep charging, don't seem to work automatically
    Prodigy:
    An expert who has answered 500 questions.
  • Kohler Expert
  • 573 Answers
It is supposed to bulk charge then drop to a float charge, it is more likely an issue with the battery
Posted on Nov 27, 2013
My acer tablet a110 wont charge over 50 percent
The battery pack is exhausted replace it.
Apr 05, 2017 | Cell Phones
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
I don't have a manual for my small Black & Decker Smart Charger. I'm trying to charge the battery on my '07 Honda Rebel 250cc. It has settings for 2/6/12 volt batteries. How do I hook it...
You just need to set black & decker charger to 12V . Don't make mistake while connecting + / - leads. + lead usually come with Red color cable. You can use the AVO tester to justify the lead cable. The charging time is normally about 10 -12 hours (or just just check the status on your charger display). If your charger does not has trickle charge facility, you have to disconnect your charger after 12 hours continuous use.
Also, you can find the guidance about your charger here :
www.blackanddecker.com/power-tools/VEC1087CBD.aspx
Regards
Sep 22, 2011 | Honda CB 250 Motorcycles
I have a GE model 25836CE-B cordless phone. My problem is this: when the phone is off the charger base, after a few minutes it will keep on beeping even if no one pressed the paging button at the charger...
Actually, you can't overcharge the battery. The base is designed to hold the handset indefinitely. Once the battery is charged it doesn't do any damage. You probably just don't have the battery charged enough to use the phone. Leave the handset on the base overnight, let the thing charge, and it should work properly.
Jul 12, 2011 | Uniden Cordless Phone
Toshiba a60-155. keep getting press f1 setup screen. have to enter date. keys 1 and 2 don't seem to work. can I bypass this page
Don't think you can bypass this thing because the RTC (Real Time Clock) battery is, most likely, dead. But if you can replace the just the keyboard, then you'll still have a working computer. I'd leave the RTC battery alone and use software (such as Atomic Clock Sync) to set the date and time automatically every time the computer boots into Windows.
Jul 08, 2011 | Toshiba Satellite A60 Notebook
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
Faullty makita DC1804T charger red lights keeps flashig and wont turn green.
I think if you have a battery that is pretty much dead, the Makita charger will never fully charge it and so it blinks. My newer battery charged up in 1/2 an hour but my old-as-the-hills one just keeps on blinking. I removed it and it works. It never really held a charge long though, for years now. It would be nice if the charger had some kind of manual telling you what all those universal symbols(I don't know who's universe they're talking about) mean.
Dec 05, 2010 | Makita Univ Volt Charger
The unit suddenly stopped working; contact is plugged in but on-button does not work. No lights on, it does not seem the unit has power.
I faced a similar problem with Mine a couple of days ago.
Try these below
1. Keep the unit plugged to the wall socket (and charge). Green light (indicating charging) may not glow. It doesnt matter. Keep it on for a few hours.
2. Then try to turn on the unit.
3. If it still doesnt turn on, fold the unit and keep it aside for a few mins (say 10 mins).
4. Open it and then try to turn it on.
Mine worked with step 4.
See if this helps.
regards,
Lakshmi
Nov 21, 2010 | Altec Lansing Inmotion-IM600...
Kohler Automatic Battery Charger C-292865 120/240 Vac 1 Phase Logo
143 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
