Question about Sewing Machines
Replacing needle on Elna Pro 905 DCX serger
During a recent move, the #1 needle (to the left) on my Elna Pro 905 DCX serger got broken, and I also have not been able to find the manual. Does anyone know how to get the broken needle out?? I have looked at this thing from every possible angle, tried loosening any screw that looked likely, but I simply can't find any clue to remove this needle. Help!
  • knittique Jan 24, 2009
    What I was trying to say in my original post is that there is no visible screw in the vicinity of the broken needle; there is a tiny hole that looks like it might take a hex tool, but it's far smaller than any I have in my toolkit.
    Thanks, Michaelle! I'm going to try and find the right tool in the morning, and I'll post here again when (being optimistic) I have this thing fixed.
    Scholar:
  • 65 Answers
Try and loosen the screw, and use a magnet to pullout the broken piece. It likely slightly bent in there so you may need a pair of tweezers as well
Posted on Jan 24, 2009
  • Michaelle
    Michaelle Jan 24, 2009
    The hex screw is what you need to unloosen. you might have lost the tool for it in the move , or god forbid the manf. didn't include it ( an oversight I'm sure)
    Is it in the front of where you'd normally insert the needle? If so you may want to go to the hardware store and get a long handled hex screwdriver (I have 3 for my Baby lock ;just in case) they are inexpensive, and pretty easy to find. Mine is a 1.5 MM
    I hope this helped a little more.
Elna Pro 4De serger thread breaking
Be sure to thread each in the ORDER specified--for most machines (but yours may differ) upper looper, lower looper, then needles. Follow (closely) the threading diagram on the machine. Missing one guide or hitting the guides out of order will throw you machine into a tizzy! On my serger, the lower looper has to lay over the top of the upper looper/thread before it all gets pulled under the presser foot toward the back of the machine.
It also may help to RAISE the presser foot when threading the machine.
Having problems threading my Elna Pro DE 4 sewing discussion topic...
Threading elna lock pro 4 DE green knob
Oct 06, 2017 | Elna Sewing Machines
Setting a elna 792d for rolled hem
I don't know your model in particular but generally this is how you set up a serger/overlocker to create a rolled hem. Remove the left hand needle and thread if 4 threads are threaded). Now there is usually a lever around the stitching area that you slide back towards you to remove the stitching finger back (disengaged). Then you adjust the top looper tension looser (about 2-3) and lower looper tension tighter (7 or 8). Leave needle tension at normal tension (5). You may need to move the cutting blade to the right too. The technique is to cut the fabric wider but with a narrow stitch so the cut edge rolls under within the stitching. You want the top looper thread really loose so it rolls right around underneath up against the needle thread, the lower looper thread needs to be tight and almost invisible, pulling the upper looper thread down. I usually do a few test runs and check the stitching. Once happy, I turn the stitch length right down to 1 so it is very dense. This uses a lot of thread up.
Ideally use a wooly overlock thread on the upper looper as this "fluffs" out once stitched and "fills" in covering the fabric edge completely.
some good images here
Sewing Basics Narrow Rolled Hems with Serger Sew Mama Sew Outstanding...
Jul 18, 2017 | Elna Sewing Machines
What size needles do the Elna Pro 4 DE take, thanks
http://www.sewingpartsonline.com/elna-pro4de-serger-overlock-parts.aspx
https://www.janomesewingcentre.com.au/shop/instruction-manuals/instruction-manual-elna-lock-pro-4dc-4de/
May 17, 2017 | Elna Sewing Machines
Elna Overlocker PRO 905 DCX manuel
Search for:
Make Model manual
Apr 29, 2017 | Elna Sewing Machines
I have a elna pro 4 de serger. After changing the right needle. The stitches aren't forming. Please help anyone
Install a new needle. There could be something wrong with the needle (sometimes they are defective out of the package). Also, check that it is installed facing the correct direction and that it is pushed all the way up. Also be sure that you are using the right needle for your machine.
Oct 18, 2016 | Elna Sewing Machines
How to replace a broken needle in baby lock serger pro line modle BL450
I use a small screw driver to undo the screw, insert the needle all the way into the needle holder--flat side to the back of the machine, then tighten the screw back
Feb 21, 2012 | Baby Lock Sewing Machines
Elna serger 925 presser foot lift lever broke off.
Here are 2 dillers that will repair it for you.
Sew Pros Inc 393 Broadway
El Cajon, CA 92021 (619) 442-3100 4.61 mi Burdick's Chula Vista Sew 278 Third Ave
Chula Vista, CA 91910 (619) 422-5325 10.56 mi
Good luck and please rate
Sep 16, 2009 | Elna Sewing Machines
Elna Pro 5DC Serger
Sound to me you should get it serviced. Your timing is off. It also could be your needle make sure you use serger needles
Aug 08, 2009 | Sewing Machines
Sewing Machines Logo
604 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
