Question about Kohler Home
Leaking jacuzzi jet
One of the jacuzzi jet connections appears to be leaking where the pipe meets the tub. It looks like there is nothing to tighten down on the outside, do I need to take the jet apart from the inside?
  • Kohler Master
  • 717 Answers
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Posted on Feb 07, 2013
  • 68 Answers
SOURCE: Bathtub jacuzzi (motor turns runs but nothing coming from jets)
Each Jet will have an adjustment many times right on the jet nozzle. Carefully try to rotate them counter clockwise to open up the jet. This assumes you can here the motor running.
Phil
Posted on Dec 09, 2008
  • 7 Answers
SOURCE: Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
Posted on Dec 12, 2008
  • 10865 Answers
SOURCE: Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
Posted on Jan 21, 2009
PartsCenter
  • 125 Answers
SOURCE: jacuzzi tub makes noise but jets wont work
sounds like maybe the impeller is just spinning on the shaft of the motor.
Posted on Feb 24, 2009
mrhotandcold
  • 248 Answers
SOURCE: i have a leaking jet in a pearl jet tub. it's an
one of the quick ways to fix leaks at jets is by using Millaput two putty resins mixed and worked round the outside of the defective jet hope this helps
Posted on Oct 03, 2009
Hello, I have a Jacuzzi tub - model number 8450000. One of the jets is leaking and I am not sure what the best remedy is (do I need to replace a gasket - or the jet)?
Have a look at the leaking jet & decide whether it has a screw thread & a nut fitting in place or if it's bonded to the tub.?
If it's held on by a nut, a new gasket will probably suffice.
If it's bonded on, it will need to be very carefully removed.
The mating faces THOROUGHLY cleaned-up & the exactly right kind of adhesive used, to re-bond the jet onto the tub.
Then it needs to be left to properly dry & cure, before you put any water in it.
Best of luck
Mar 15, 2018 | Jacuzzi Home
Leaking at jet to tub connection
You can fix that with a small amount of "plumber's putty". You have to remove the jet from the tub first, then smear the plumber's putty around the junction where the two meet each other, then reassemble.
Aug 04, 2014 | Jacuzzi Home
The casing around the jet on the tub side is cracked and is causing water to leak on the outside of the tub. This has happened to three of the 10 jets. What can I do to fix this?
Cheap plastic fatigues with heat . Silicone will work but will not keep the crack from continuing. The fix depends upon what type of plastic you have . It is likely a polyester like fiberglass in which case you can use regular fiberglass to fixit . Rough up the outside with 80 grit , brush in fiberglass resin ( don't forget to mix in hardener) lay in glass material , repeat until built up . Repair the front with a good "gelcoat " repair kit which allows you to mix match color.. sand with 220 , then 600, then 800, then 1500, then 3000 , polish with automotive whit polishing compound , wax
Nov 14, 2017 | Jacuzzi Home
What cleaner gets the bad smell and crud out of jacuzzi jets?
Here is a link to a site that sells jetted tub cleaners.
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Any of these cleaners work very well at removing the smell from a jetted tub and the bacteria in the pipes as well.
Rod
US Parts Center
Mar 15, 2014 | Jacuzzi Home
I have a old Jacuzzi that is leaking. on the tub of the Jacuzzi is a knob you can turn to chage the air pressure. The knob is connected to a white tube that connects to a black box. the leak is where the...
Take the unit off of the tub and see if there is a seal there,if there is a seal there try putting some silicone caulking around the seal or where the seal would be and then put the unit back together but don't over tighten the unit until the caulking is cured(24hrs) and then tighten the unit back up and this should seal it back up,unless the water is leaking past the actual switch itself,then you will need to replace this switch!Good Luck!!
Aug 30, 2013 | Jacuzzi Home
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
Feb 23, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
Jacuzzi Espree with side access pannels leaks.
you can use a scissor cutter or a utility knife and make a nice square cut in the hose. After replacing the nut, hopefully you can find one, you can get a pvc coupling, the hose is the same size as pvc pipe, and use pvc glue to reattach the 2 ends back together. Use Oatey Rain-N-Shine glue....it is in a light blue can and the actual color of the glue is blue.
Oct 21, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Black come out the jets when first operating them
Didn't fully drain at the end of last year, that gunk was mold, rust and gunk that's been sitting in the piping since last year. Not really a problem just remember to take a closer look at the plumbing on your tub next year and get all of the possible places that water may hold drained completely.
May 25, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
Oct 06, 2008 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Home Logo
371 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
