Washer stops mid cycle
Washer will stop washing in mid cycle. Sometimes I can get it to start again by raising the lid and then dropping it down hard. However, it is getting more difficult to make this work. I heard this could be a fuse problem? Any thoughts? thanks. whirlpool LSC5000PQ2 fills with water then stops, will start to fill again if I drain it using a wet vac
  • rhaneyjr Jan 24, 2009
    found the switch but when i press it i can hear it click, but also sounds like and electrical short happeneing at the timer control
    related issue or seperate problem?
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
  • 54 Answers
OK.. to the back left of your lid, under the top casing, by the hinge.. you have a hook metal bar that activate the lid switch.. hard to describe, but I'll do my best.. use left hand lift up on down on lid.. use right hand, reach under lid and find metal hook.. ok.. push up on lid and right hand push back on metal hook slightly(not to much).. now try closing lid and see if you heard clicking noises.. also, in the future try not to let the lid drop down, that will bend the hook.. hope you got it.. good luck...mike
Posted on Jan 23, 2009
GE WBSE3120 Washer stops mid cycle
if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
Dec 04, 2017 | GE Washing Machines
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it. watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer has been stopping mid-cycle like the lid was opened lately. I have been able to open and close the lid to "jar" it into finishing the cycle(rinsing) until now. It has just stopped and...
The lid switch will need a slight adjustment to properly activate, or you could bend the raised bump on the back of the lid out a bit so it activates the switch better.
Jul 27, 2011 | Maytag Washing Machines
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
Whirlpool washer spin cycle works off and on
no the slowing down maybe caused by a sticking clutch and as before the lid switch may also be broken if when you depress it the reason i'll give is if you bump it it sometimes starts up replace the lid switch and once done the circiut will close properly then the delicate cyc should work
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washing machine model 110 wash cycle stops
Aug 21, 2009 | Kenmore Washing Machines
Washer stopping mid-cycle
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine timer stops mid cycle
Your lid switch needs replacing.
Part number 3949237 available at any applinace parts store.
Apr 05, 2009 | Estate TAWS800JQ Top Load Washer
Whirlpool washer stops for no reason.
i would be concerned teh the door/lid switch is not being activated, or is loosing contact withthe swtch mid wash causing unit to shut off. unitll the lid is lifted and closed to make better contact.. tyhe activator for the lid switch is actually the underside of the lefthand lid hinge. so if your able toreah under the lid while open you feel the metal lever, as you push and pull hte lid youll feel the lever move as well. with a hollow shafted screwdriver/1/4 nutdriver. place the driver over the metallever andslightly bend it toward the rear of the uni, so it makes better contact with the switch mounted tothe underside of the main top assembly
Nov 20, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
