Question about Refrigerators
My ge refrigerator pfss6pkwbss freezer dont work and 88 6A on the left
MNTECH
  • 1543 Answers
SOURCE: GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Posted on Aug 28, 2008
  • 833 Answers
SOURCE: GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Posted on Dec 12, 2008
  • 103 Answers
SOURCE: freezer works refrigerator doesn't ge tbx-25zle
Hi: Your defrost heater or defrost timer is bad. There is an off chance your freezer or fresh food compartment are so full they block the airflow. If not full, Remove the food from the freezer, unplug the ref. and hit the back wall of the freezer with a hair dryer. Avoid plastic components as they will melt. When your defrost mechanism fails frost will form where it shouldnt and block the airway to the fresh food compartment. That's why the freezer still works. That will get you a week or two of fresh food getting cold. If your'e handy remove the back panel of the freezer at the bottom will be a glass tube with a metal coil in it. If the coil is broken buy the new defrost heater and install it. If not look for a defrost timer. Use the model number of the refrigerator to find the part. www.searspartsdirect.com will have a parts schematic to help you find out where the timer is located. There shipping is high so try to buy it locally. I hopes this helps, Jeff
Posted on Jun 25, 2009
  • 864 Answers
SOURCE: GE side by side refrigerator(GSS22ifrf ww) not cooling
Try unplugging it for 30 seconds and then plug it in again. It may reset itself that way.
Posted on Jul 29, 2009
SOURCE: GE refrigerator pfss6pkwbss flashing 88
Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel! I was told by both GE and a local repair service that I had to replace the entire control panel...what a RACKET!! GE needs to start telling people this trick when they call in with this error...it will come up every time there is a power outage.
Posted on Apr 04, 2011
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
How to remove ice maker on ge profile pfss6pkwbss
You would first have to distinguish between if the tray has a crack in it or if the water valve is not closeing which would mean you would need a new water valve. Most all ice makers are held to the freezer wall by 3 1/4" screws you would unscrew these screws and unplug the power connector and remove the ice maker from the unit. Fill the ice tray with water and see if you do have a crack in the tray which is not as common as a water valve allowing to much water to go into the ice tray makeing it overflow. If you have any further questions message me back I await your reply.
Thank you,
Rick
Jan 19, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE refrigerator pfss6pkwbss flashing 88 82 after a brief power outage...any info on how to resolve? Tried unplugging for about 2 minutes, and this did not solve it. buttons on door panel do not work at...
To reset the panel display, press and hold the top left (Energy Saver) and top right (Alarm) buttons at the same time for about 10 seconds--the panel will beep and reset.
The panel will require a reset whenever the power is interrupted..
Feb 03, 2011 | Refrigerators
Nov 23, 2010 | Refrigerators
My GE side by side refrigerator isn't working right. The freezer works great, but I can't get any coldness on the refrigerator side. Even at the highest cold setting.
Check your air door at the top left rear of your refrigerator side. If no air is flowing try opening it by hand while you are there. Also check the freezer for a fan sound to be sure your fan isnt stuck or dead.
Mar 14, 2010 | GE GSL22JFPBS Side by Side Refrigerator
Aug 27, 2008 | GE Profile Arctica Stainless Steel Top...
GE model GTST2BPLWW
they all have fans the freezer does all the cooling for the whole unit there is nothing in the bottom unit that cools the freezer fan blowes air from the freezer down to the bottom and draws air to the top if you dont hear the freezer fan running and there would be no doubt in your mind if it was then pull the fan cover and see why and let my know hold my rating till we are done please
Feb 11, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
