Keyboards connect to Smart TVs using two main processes, but check the user manuals for both devices to determine the specific instructions. For wireless keyboards, push the wireless USB dongle into one of the TV's USB ports, while both the TV and keyboard are turned on. https://www.techwalla.com/articles/how-to-connect-a-keyboard-to-a-tv
Plug the wireless receiver into USB port 2 on the back of the TV. Turn the TV on and allow to power up. Press and hold the CONNECT button on the backside of the keyboard for 3 seconds or more to connect to the TV.
https://support.dynabook.com/support/viewContentDetail?contentId=4009228
1. Verify that your Samsung Smart TV is connected to the
Internet using a wireless or wired connection. ...
2. Power on your television and select "Smart Hub" from
the main menu.
3. Select "Apps," then scroll to and select "Samsung Apps"
using your remote control.
Jane, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to connect the TV to WIFI
If you have bluetooth on the tv then there should be an option to search for the device you wish to pair with in the settings on the tv. If you don't have that option then you would most likely need to purchase a bluetooth adapter to plug into your tv in order to connect your keyboard
I've never seen a smart TV setup, but here's a couple of thoughts I had:
Has the keyboard worked with the smart TV yet? It's possible you haven't plugged in the dongle to the USB port, if it's a wireless keyboard. Then again, you might need to use an on-screen keyboard for a setup entry.
Hi, commonly these TVs use a network cable for connecting to Internet through a router, another TVs are wireless enabled, in this case you need a WiFi router to get Internet in your smart TV. The process is similar as you connect a computer to Internet but the keyboard of your TV is the remote control, some smart TVs can work with standard wireless keyboards and mices to surf Internet as with a computer.
