SOURCE: Stitching Problem
adjust the stitch width to "0". If it still needs adjusting, somehting is sticking in the pattern mechanism
SOURCE: kenmore model 158.17810 sewing machine noise
that is a fifty fifty chance you have to take. It may be something minor rubbing or you could have a slightly bent shaft underneath making noise
SOURCE: I have a PfaFF sewing machine, model 1221. The
The power pedal (not foot feed) needs to be replaced.
You can check sewingmachinesplus.com and other Internet parts vendors or just call your local Pfaff dealer to see if they have one or if it has to be ordered.
SOURCE: My serger won't start. Motor is running but
Hi, On most of these newer machines they have a clutch that you engage to fill the bobins.
Please make sure that the clutch is disengaged for normal use. If this is all OK see that belt
is attached on motor.
SOURCE: i have a singer stylist model 413 that the bobbin
I have the same problem! Did you ever figure it out?
