We need to re-tune a remote control for a J & L IFS22-1L ipod tower, please?
We have obtained a replacement remote for one that was lost but - even with a brand new battery the tower is not responding to the remote. ipods will still play, but it's no longer possible to select input, control volume or do anything else with the new remote.
KaeZoo
  • 156 Answers
SOURCE: auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Posted on Mar 15, 2007
marked
  • 6487 Answers
SOURCE: I have a brand new
Try resetting your Ipod follow this:
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Hope that helps.........
Posted on Aug 18, 2008
VOTIT
  • 2071 Answers
SOURCE: my remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Aug 21, 2008
SOURCE: Dynex iPod Dock with Remote
i had the same problem. it seems that you have to use the remote to turn the volume up on the ipod instead of doing it manually. that worked for me.
Posted on Sep 13, 2008
  • 5 Answers
SOURCE: Apple remote control
At the bottom of the remote is a small button that can be pressed by a pin or pen. Press it and the battery will pop out. Replace the battery and you will have a working remote
Posted on Dec 07, 2008
Tower fan codes
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Dec 01, 2015 | Tower Dryers
I've lost my Phillips control so I bought a Titan 1200 control. I need a code to tune the TV in
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Sep 16, 2014 | Philips 42PFL5603D 42 in. LCD HDTV
My tv set is nt tuning any channel
your electronic tuner in the set may need replacement.
Are you using a remote to change channels it may be the batteries in the remoter that needs to be refreshed.
Not a lot of detail here as to what model TV this is or what remote is used.
Jan 23, 2010 | Apevia X-TELSTAR-BL ATX Full Tower Case
My Toshiba 2939DB needs to be tuned in to pick up SKY. I cannot tune the TV as I do not have the original remote control - any tips?
HELLO
There are many companies on the net that make generic remote controls for TV,VCR etc and it may be possible to obtain an original. If you Google "Replacement remote controls" then I'm sure you'll find one. Don't be tempted by these cheap remotes where you get a code book with them, many of them will NOT operate certain functions of the TV, including tuning. Beware!
Your problem seems to be that you want to tune the Sky box into the TV via the RF output of the box. Why not connect it by scart socket? You'll get a much better picture and if your set is nicam, stereo sound too.
I wish you luck!
Sep 12, 2009 | Televison & Video
Goodmans DPL905 amp no remote
The applicable code would be in a compatible remote control. However, alluniversal remote controls do not contain all possible codes.
Dec 24, 2017 | Audio Players & Recorders
Tuning radio without remote.plese help....
You need to have remote control to perform tuning for radio because unit has no control buttons to do so.
You can get remote from Sony Accessories. Please write model number DAV-S300 in search box to get result.
Remote details are as under...
141883811 RM-SS300 REMOTE CONTROL Approx $70
Nov 10, 2008 | Sony DAV-S300 System
Aloha Breeze Tower fan remote control no longer functions consistently. A replacement remote control is needed, or this one needs to be fixed. Is a purchase of a just a remote possible? Suggestions?
I'm serious even though it sounds like a joke.
Call 1-800-REMOTES
or here is their site
http://www.remotes.com/store/aloha_breeze/84001.html
Aloha Breeze 84001 Remote for $28.95
Shipping in US and Canada is $7.95
Hope this helps!
May 03, 2008 | Tower Aloha Breeze Fan
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
