My Rosen Z10 makes a clicking sound when DVD is inserted, it freezes and won't eject DVD.
The game portion of this product works fine it's just the DVD we have trouble with.
snakehead
  • 1074 Answers
SOURCE: Works fine, then no picture.
clean the lens of your dvd.if that does not work your lens must have gone bad have a tech look at your set for possible repairs.good luck
Posted on Jan 06, 2008
MATRIX_MMX
  • 209 Answers
SOURCE: panasonic portable dvd player
Dear cathy1017
Well this is a similar problem that i have encountered on many CD/ DVD optical units (cd players, stereos, personal walkmans, DVD players, ROM drives etc) and the problem is likely to be mechanical rather than an electronic fault. The fault is quite easy really, its just possible that your laser head on your dvd player is mis-aligned or out of place. Even by a millimetre or so, the laser wont be able to read the disc, and as a result, the error message is displayed, and while the laser head is trying to read the disc, a "clicking" sound will be emitted.
Now i did say that this fault could likely be mechanical, but do not ignore that it could also be electronic issues too. If the electronics to the laser head or to the read area have been comprimised/ broken, then this will put out the same fault, becuase the problem has been caused electronically rather than mechanically, but both issues usually have the same end-result.
Now in the worst case scenario, and there is an electronic fault, i would not recommend trying to overhaul this device yourself, really i wouldnt, unless you are pretty good with a multimetre, electronics, and have access to precision equipment and solder/ de-soldering irons (and you know how to use them of course). Now, you could take it to someone who knows how to fix these units, or even send it back to your manufacturer/ vendor (and definitely do this, if it is still under warranty), or you can discard the unit/ sell it for spare parts and purchase another one (as these are fairly cheap to buy now).
Ok, now for the better bit, if this is a mechanical problem, then you are more than likely to get this sorted out quickly and easily, you may even be able to do this yourself if the laser head lens just needs realignment. All you would do is carefully either lift or depress the lens accordingly by moving the mount that the lens sits on. NOTE: NEVER EVER TOUCH THE LENS, AS SCRATCHING IT WILL RENDER IT UNUASABLE (they are also difficult and expensive to replace/ repair).
Now Once again if the problem is an electronic fault, then there are some things here which i have listed which you can either have looked at either by an electronic engineer, or yourself, and these are the following
Laser head,
Laser lens,
Motor, and motor spindle (turning the discs)
Laser unit motor (moves the laser sideways on cradle to read different areas of disc)
Laser PCB (printed circuit board)
Motor PCB
DC (direct current) supply to the laser unit and motors
DC circuitry resistance, and resistors (measured in ohms) ω
DC circuitry capacitance (checking that capacitors and storage charges are discharged properly and flow of current is regulated properly (measured in uF, pF, (microfarads, and picofarads)
Check that the powersupply is not failing (if this is of the adapter type wich plugs into the DVD player, then take the unit to your serive personnel in order to have the supply and supply ratings tested)
Now a lot of this may well be out of the reach of most general people in order to carry out these tasks, but if you are willing to give this a try then you can always go to the manufacturers/ vendors website, and try to get hold of copies of various manuals and documents. To do this, you may want to try looking under the support or FAQ (frequently asked questions) section on the website, of you cvan get hold of their telephone number and call them up in order to find out how you can acquire the literature that will tell you more about the fault.
If you go to http://www.google.com and you type in the manufactures/ vendor model of your unit, followed by the words "srervice sheet" you may be able to get hold of the repair manual and disassembly guide, that will tell you how to overhaul the unit yourself, it should also give you a list of every single component and part that is built into your Panasonic DVD player. Now in addition to this, Panasonic are quite a large vendor, and mostly develop their own components, or use certain parts from other semiconductor manufacturers such as Toshiba (and the parts are faily readily available). Now even with the service manual/ sheets in mind, and you still did not want to try to resolve the fault yourself, at least you will have gained a degree of knowledge about the fault, and who to send the unit to for servicing.
Whichever descision you choose, i hope that the solution is right for you, and i hope this fixya, will fixya up with the best way on how to deal with this effectively. Also I would be interested for you to stay in contact through this site and let me know how the projectis going, that way, if you need anymore expert advice or need a specialist in order to overhaul yor unit/ any other electronic device, then i can assist in getting this for you at the most competitve rate for you..
Im readily available here, and will respond to you as quickly as i can with regards to any of your technical related issues for home/ high end electronics, computers, appliances and consumables. and will answer any/ all of your questions and comments in relation to this.
In the meantime, i wish you all the best once again, and please take care and i hope to hear from you soon
yours sincerely
Oz
Posted on Apr 13, 2008
opherator
  • 44 Answers
SOURCE: TV DVD VCR combo eats tapes and now won't eject DVD's
Its shot, time to get a new one. dvd players are now only $20
do you have a newer lcd tv. Id say look into getting an upconverter,itll play your dvds at 1080 :) better picture.
Posted on Feb 27, 2009
SOURCE: rosen a7 car dvd player keeps ejecting any dvd
what is called the end sensor thats got tobe replaced
Posted on Apr 23, 2009
  • 80 Answers
SOURCE: I have a go video vcr/dvd player. The vcr works dvd doesn't
if this happens to all discs needs to be repaired.my panasonic was playing up and not very old,and cost me $350.00 for a new driver.
Posted on Aug 11, 2010
Phillips dvp3345 connecting to LG42LV4400 + can't get VCR audio to play
I tried looking up the image of your recorder online to help you out but I cannot find a clear image. If you can get me clear pictures of the unit I will help you out.
Jan 21, 2013 | Televison & Video
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
Game has error, says to consult Wii operations manual
It's most likely the disc that is causing trouble. If all of your other games work, it the game you bought. I had the same problem with MySims Party, I went to the store where I bought it, they gave me a new disc, which worked fine.
May 25, 2012 | Nintendo PokePark 2: Wonders Beyond
Disney d-style karaoke won't read disk or spin disk
The problem is in the laser pickup assembly, the pladder motor is not working that spins the disk, and unfortuneately the only way to correct this is to replace the entire assembly which probably won't be cost effective.
Mar 06, 2012 | Televison & Video
The GPS portion of the Pioneer Unit in my motor home does not work. The screen indicates a disc reading error. Everything else on the unit seems to work fine. Can you give me any ideas on fixing the...
Sounds as if the disk is bad. You'll need to find a torrent download for the disk (there's one for the eastern part of the continent and one for the western part). If it's an .iso file you can burn it directly (as a disk image, of course, not as a file). If it's a .uif file, you can convert it to an .iso with uif2iso (http://aluigi.altervista.org/mytoolz/uif2iso.zip), then burn it. You'll need a dual-layer DVD (and Pioneer products seem to prefer DVD+R disks to DVD-R ones.) Or you can just buy a new disk for the exorbitant Pioneer price.
Aug 01, 2011 | Pioneer AVIC-N3 GPS Receiver
I'm having trouble with Age of
Hello just curious did you pirate the game it could be corrupt if not try this, set your task bar to classic and right click on the short cut to the game on your desktop, bare with me i am using linux, look through the tabs and there should be an option to run in windows 98 compatible mode or something then try it, i hope this sorts the problem out.
Jul 16, 2011 | IBM Lenovo ThinkPad R60 Notebook
One of my game dvd can't be read properly.Whenever I'm trying to install the game it is showing an error report showing a corrupted file.The same thing is happenening when I'm trying to extract...
It may be possible that the Game DVD is corrupted. Try to use the DVD on a different computer to ensure that the disc is fine. If it is working on a different computer that means the DVD is working fine. Instead of installing the game directly from the DVD try to copy the entire contents of the dvd to your computer and then try to install it from the computer.
If the above doesn't work you can try to use REVO uninstaller to completely remove the Game from the computer and then try to re-install it.
Hope this will resolve your issue.
For any further assistance feel free to get in touch..
Jul 16, 2011 | Origin Burnout Paradise The Ultimate Box...
Protron pdv 288 AC adaptor (need part from wall to converter) (USA)
Hello Javargas - Your unit will work fine with any generic 12V DC 3 AMP AC adapter. It's probably marked somewhere on the back of the unit (at least the 12V part).
If you have trouble finding one with 3 AMPs you can buy universal ones that will dial up automatically the voltage/amps the unit needs.
The generic kind can be had for about $20 (USD) while the second kind usually sells for around $35-40.
Happy movie watching.
Mikeywaf
May 16, 2011 | Protron PDV-288 7" LCD Portable DVD Player
DVD portion was intermittent on reading portion & now does not work at all. VCR side records fine & tuner works ok. Was there a problem with these units.
Like all DVD Players & Recorders the Laser only has a certain life span before it burns out. Some last longer than others and most aren't cost effective or viable to replace.
In your case it's even worse beause you'd have to replace the complete DVD Mechanism.
http://www.encompassparts.com/products/?JVCLG-EAZ41878721
Please leave feedback
Cheers
Andy
May 14, 2011 | JVC DR-MV150B DVD Recorder/VCR
PS2 slim
the laser is dirty or damaged. Try swabbing the lens with rubbing alcohol and immediately drying with canned air. if that doesn't work, a repair shop can do a more in depth cleaning, but there is the chance that the DVD portion may never work again. I do this repair about 5 times a day...
Sep 12, 2007 | Sony PlayStation 2 Slimline Console
Televison & Video Logo
258 people viewed this question
Top Televison & Video Experts
Electro Med Services...
