Question about Home
Why would the water level be low in one of my toilets?
I have 2 toilets in the house. Only this one has a low water level after flushing. I just replaced the flush handle. The rest of the system in the tank has been intact for years. This problem just started or was just noticed.
  • 979 Answers
Th problem is not in the flushing handle. You have a problem in the out take. Chances are there is something in the trap as it is taking the waste out OR your flapper is closing up too fast in the tank thus not allowing enough water into the bowl.
Posted on Feb 03, 2013
  • 35 Answers
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Posted on Dec 21, 2008
  • 14 Answers
SOURCE: Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Posted on Jan 10, 2009
miket756
  • 2702 Answers
SOURCE: Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Posted on Oct 24, 2009
  • 3600 Answers
SOURCE: Increase water in toilet tank-low flush Toto toilet
Yes adjust the float level to raise the amount of water in the tank, If you have a float that is a ball around the tank you will have to turn the water off and remove the hose from the tank and remove the nut then pull the water float device out and you will see a clap on the bottom of the float you will turn the float base so that it gets longer, increase it by two inchess so that you increase water flow. Reinstall into the tank hook it all back up and leave the lid off turn on the water and watch the water level rise be sure the float shuts the water off before it over flows, if it starts to over flow then fush it to bring the water down giving you enought time to shut off the water valve.
There is a problem adding low water systems to older septic systems. The septic pipe settles in the ground over time and may cause a ~~~ in the pipe thus causeing blockage. For future reference you can add a one gallon bottle of water in the tank like a milk jug or a used up bottle of puerified water that you have drank and this will decrease it by one gallon per flush. Hope this helps. If you need more asstance just posttothis reply!
Posted on Nov 11, 2009
projdoc
  • 2237 Answers
SOURCE: toilet wont flush completely. it may take 4 times
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Posted on Nov 13, 2009
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
How do i get more water in the toilet bowl?
On some toilets the float level is adjustable inside the tank. If there is an arm with a large ball attached then bend the arm up slightly. If it has a small plastic float then some of these can be screwed up or down on the tube supporting the float. The higher the float the more water that will transfer to the bowl. If your house is built in the 1980's or newer then you should have all plastic pipe and I would switch out to a low flush toilet. If your house is old (pre 1960) then you have cast iron or clay pipe and you may want to keep your 3 gallon flush as long as you can. If you are in the between zone then you need to check and see what kind of pipe was used. A smooth wall pipe requires less water to flush. If you go with a new toilet go for a mid grade one. The cheep ones have poor castings on the inside and it causes friction that results in a miss flush more often. I like the Delta with 3 bolts on the tank in the $150 to $200 price range. If all else fails a new flush valve will come with instructions and they do go bad after a while so now may be a good time to replace it. Flowmaster has been pretty good to me and you can pick one up for about $20. There are ones that are supposed to shut the water off if the flapper sticks but they take a bit more experience to figure out how to set them and you will find yourself flushing the toilet and nothing is happening because the float switch has the water shut off.
Oct 22, 2014 | Home
Just installed the cadet 3 and here is what is happening. First let me say that the toilet it replaced was working good. The water filled very slow and the bowl would not fill much. I messed with the...
The amount of water in any toilet bowl is determined by its construction and no tank adjustment will ever change that. American Standard has a history of having small water surface areas in their low or ultra low flush toilets. Take a large container of water and pour directly into the bowl. If the ending level remains the same, then that is the manufactured level for your toilet.
Not all tanks completely discharge all of the water when flushed. Measure 1.5 gallons of water into a container. Turn off your water supply to the toilet then flush normally. Replace the water in the tank with your premeasured amount and observe this new water level. You might be surprised to find it is at the same level it always is. Since water weighs more than 8 pounds per gallon, one concept used in todays toilets is to have more than 1.5 gallons of water in the tank and use the extra weight push the water past the flapper at a faster rate while designing the flapper to drop after only 1.5 gallons have passed through.
Sep 29, 2010 | American Standard Cadet 3 Right Height...
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
Dear sir/madam. when flushing toilet it takes a
Some water saver toilets are very problematic about not having enough water to thoroughly flush. Here are 2 things to look for:
First, after toilet stops running completely, check the water level. Most tanks will have a "full" line marked inside. If the water level is low, your fill valve will need to be adjusted.
Second, if the water level is fine, your "flapper" valve (very bottom of tank) may not be opening all the way. Watch valve as you flush the toilet. It should come up far enough to allow total unobstructive flow of water. If it isn't, adjust chain length until it does. Make sure there is a little slack left.
If neither of these solves your problem, you may have a partial clog that will need to be gotten out with a drain snake that can be purchased at any hardeware store.
Jun 08, 2010 | Home
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
When I flush toilet wht water swirls and flushes,
check the water level in the tank, if you do not have enough water it will give problems flushing. if the level is low there are two different adjustments you can make on the float and valve to get the required water level to get an efficent flush.
Aug 20, 2009 | Home
Cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
May 08, 2009 | American Standard Cadet 3 Right Height...
Low water level in toilet bowl
Sorry, but there is no way to raise the water level in the bowl of a low-flow toilet. The water level is determined by the height of the internal trap, usually visible from the side of the toilet (that squiggly little bend). If the toilet is not flushing satisfactorily, you can make adjustments to the water level in the tank and adjust the closing of the flapper. If the problem is odors, flush half way through your business or turn on the bathroom exhaust fan. If you found this answer helpful, please don't forget to rate it.
Apr 09, 2009 | Bemis Home
Home Logo
50 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
