Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
Which wire goes to h, which wire goes to c, which wire goes to l?
  • 717 Answers
The black wire goes to H (high) White wire should go to C and green to the I.
Rod
US Parts Center
Posted on Feb 06, 2013
How do you know on the three wire from stator to regulator the ends has no conector which wire goes to which wire
USUALLY THE THREE WIRES FROM THE STATTOR ARE IN THE SAME COLOR,. THOSE THREE WIRES GOES DERECTLEY TO THE REGULATOR. AND THE RED WIRES OF THE REGULATOR IS POSITIVE THAT GOES TO THE BATTERY, AND THE BLACK WIRES GOES TO THE BODY GROUND.
Aug 14, 2014 | Motorcycles
Hi guys. i hav an acer ac713 crt monitor. the cable that connects the monitor to the tower/hardrive has been cut by burglars. where can i find a wiring diagram to fix it? thanx.
in 15pin connector of the monitor,
red wire goes to pin No:1
green wire goes to pin no:2
blue wire goes to pin no:3
yellow wire goes to pin no:13
white wire goes to pin no:14
and black wire goes to 5&15. Now display will come!
Sep 08, 2010 | Acer AC713 17" CRT Monitor
How to wire a 3 phace 5 hp baldor motor
the neutral or white is not used. if the fourth wire is a ground then it goes to the motor frame. if it is a dual voltage motor then here is the wiring: for 240 volt 3 phase connect 4-5-6 together and tape, 3-9 goes on L1, 2-8 together goes on L2, 1-7 together goes on L3. To reverse direction swap any two line wires. For 480 volts 3 phase: L1 goes on T1, L2 goes on T2, L3 goes on T3. Connect together T6-T9 and tape, connect T5-T8 and tape, connect T4-T7 and tape. again to reverse direction swap two line wires.
Oct 14, 2009 | Baldor 115v,1ph, 3,600rpm 7" 1/2hpbnch...
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
How to connect wires on plug on dryer
3 wire plug,middle wires goes to middle terminal,each of the other 2 wires goes 1 on each side,does not matter which one but the middle wire must go on middle terminal,4 wire plug-the white wires goes to the middle terminal,the red goes to red and the black goes to black,the green wire must be mounted the the case-mike
Jun 28, 2009 | GE DVLR223 Dryers
What are the colors of the speaker wires in a dodge stratus 1997 coming from the wire harness of the car itself
The easiest way is to check the speakers themselves as manufacturers tend to change colors of speakers at a whim. Usualy though you will have 8 wires (4 front & 4 rear) paired in colours (white goes with white+black stripe(stripe is possative on speaker))etc.
Not knowing the cars electrics I can't be more specific.(I live in UK so don't know that much about U.S. cars)
Jun 27, 2009 | 1997 Dodge Stratus
Trying to hook up cable to a raytheon r10 radar scanner.Needs wiring diagram to show where each wire goes.
Large Blk and Large Wht goes to 2a
Large Red goes to 1a
Grn goes to 1b
Blu goes to Bz
Coax goes to Vd
Wht (shielded) goes to Gs
yel goes to 33
Red Shielded goes to Bp
Brn (small) goes to pl
black shielded goes to tI
Large brown not used tape end fold back and secure to harness.
Apr 19, 2009 | GPS
Wiring of Ethernet cat6 cable for computer to the modem asm32 to excess to internet
Pinout is as follows:
http://www.mae.ufl.edu/sysinfo/cat6_cables.htm
Looking at the Cat6 connector with the lock tab facing up, look at the pins, (brass colored contacts) going from left to right.
From the left it's pins 1,2,3,4,5,6,7, and 8.
The wires are twisted together in pairs.
First pair
1.Pin 4 goes to the White wire with Blue bands.
2.Pin 5 goes to Blue wire.
Second pair
1.Pin 1 goes to the White wire with Orange bands.
2.Pin 2 goes to the Orange wire.
Third pair
1.Pin 3 goes to the White wire with Green bands.
2.Pin 6 goes to the Green wire.
Fourth pair
1.Pin 7 goes to the White wire with Brown bands.
2.Pin 8 goes to the Brown wire.
Apr 15, 2009 | Avaya Computers & Internet
Trying to hardwire my mini fridge in my popup. I have a blue and a gray wire coming from the condenser and a black and a white wire coming from the thermostat control, and a white and a black wire coming...
ok the black wire from the powersource goes to the (-)negative terminal in the converter, the white wire goes to the (+) positive.
From the converter the white wire goes to the white wire on the termostat.
the thermostat black wire goes to the grey wire on the condenser
the blue wire on the condenser goes to the black wire on the Conveter.
Mar 27, 2009 | Refrigerators
Changing from 3 wire plug to a 4 wire plug. What color goes where?
you have a 4 wire plug,
Green wire on plug goes to the cabinet ground
Black goes to the terminal block, where the other black wires are, usually on one side of the block.
White is Neutral it goes to the Terminal block,where the white wires are, usually in the center.
Red goes to the other side of the terminal block where the other red wires are.
Do you have your owners installation manual? it should tell you in the manual how to wire it.
If all else fails call an Electrican, Repair person, or a friend who knows.
Aug 20, 2008 | GE Dryers
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
110 people viewed this question
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
Jay Finke
Jay Finke
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
