Question about Miele 24 in. G693 Free-Standing Dishwasher
Dishwasher not stopping
My Miele G 665 dishwasher has (as of last night) stopped 'stopping' if that makes any sense. It gets all the way through the cycle, but then goes through again, and again, .... We woke this morning with it still going, and I had initially thought it was 'stuck' at one part of the cycle, so moved the timer forward a little, but after seeing it go through the rest of the cycle, and then go around again, I figure it's not stopping for whatever reason. Any thoughts before I contact Miele $ervice?
  • pisoi Oct 20, 2008
    We just had the engine of our dishwasher replaced. Everything seems fine and the machine works. However when the timer reaches 1h and 12 minutes, the machine keeps doing the same thing and never finishes. What can it be?
  • 51 Answers
If it keeps going around then it is probably the programer timer motor unit. You will need to call Miele.
Posted on Jul 25, 2007
SOURCE:
Kenmore dishwasher 665-1703 wont stop washing
Unfortunatly you are looking at the timer which is now built into the controller which would need to be replaced. If the relays are fused shut on the timer or the gears are missing some teeth then you will only get sofar I the cycle and the washer will just stay where it's. Sorry
Sep 08, 2012 | Dishwashers
Miele G 2630 stopped working. It started and then just stopped now no power
Hi
The power issue with the Miele G2630 dishwasher is due to a blown fuse inside the dishwasher or due to faulty main board of the dishwasher. However, before checking internal components we can first reset the circuit breaker, make sure it is a 15 A breaker. If the breaker is fine then you'll need to disassemble the dishwasher. Try and dis-mantle the dishwasher from its place, before this remember to turn off power and water supply. And also check for the drain hose. After the dishwasher is dismantled, you can remove the back panel of the dishwasher and check for the blown fuse and also check for any loose connections on the power supply board. Inspect for burnt components on the main board.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 30, 2010 | Miele G2630SCiSS Dishwasher
Dishwasher runs and never stops
hi,
Sounds like you would need a new timer which can be purchased from Miele directly or through a authorzised service agent
Jun 30, 2010 | Miele 24 in. G870 Built-in Dishwasher
I need a new timer for my miele g 665 dishwasher, were can i buy it?
hi,
spares are only available through Miele spare parts or their registered service agents who will probably then source the part from Miele spare parts anyway.
Dec 15, 2009 | Miele 24 in. G665 Built-in Dishwasher
Dishwasher not filling
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 21, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
May 13, 2009 | Kenmore 15939 Built-in Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Miele g 665
it is the "FAN" inside the door, i had that problem too.
if it leaks after you open it when it stops and the door is on the ground.
You can open up the front and clean the black small tube witch comes from the fan on the left upper side (if you're in front of the machine) and down to the magnet opened valve.
On my Machine i replaced the tube with a new one as you don't get everything out.
Meins321
Mar 23, 2008 | Miele 24 in. G693 Free-Standing Dishwasher
Miele 24 in. G693 Free-Standing Dishwasher Logo
465 people viewed this question
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
