Question about MSI Computers & Internet
My motherboard is not reading my hardwire connection
    Renaissance:
    An user who is expert in 3 categories / brands.
  • MSI Master
  • 2,226 Answers
Are the drivers in first the check out power to board and hd dvd
Posted on May 27, 2014
Cpu red led light not working
If A Desktop---Check Hardwire Connections On Motherboard----If Laptop--Motherboard Circuit Problem
Feb 05, 2014 | Computers & Internet
Network driver missing
Drivers.
http://www.gigabyte.com/products/product-page.aspx?pid=3440#dl
Nov 13, 2012 | Computers & Internet
I've replaced and re-soldered the DC jack twice and it keeps coming loose after a couple of months of use. Is there anyway to hardwire the power adapter cord directly to the motherboard? More to the...
I'd advise against hardwiring the ac adaptor to the motherboard, as this can cause sparking and burning of the board if it ever was to work loose. To effect a better repair, you might want to consider packing the edges of the jack port with some form of epoxy resin which will hold the DJ jack socket in place. There is a good product used by plumbers that you mix like putty and apply, which avoids mess and does not smell.
Jul 19, 2011 | Toshiba Satellite A65-S1068 Notebook
Can not load the drivers because windows are not loaded yet, but my usb plug keyboard goes dead when I enter the widows set up as I am trying to load Windows XP and can not hit enter when asked to continue...
Have you tried a different usb port, keyboard, check your connector and connections, is the usb
port hardwired or wired from a connector on the motherboard..
Feb 19, 2011 | Soyo KT600 Dragon Plus Motherboard
I cant install my ethernet driver.. when i install my ethernet .. still i cant use my internet??
If you use a hardwired eathernet connection though that port you are installing the driver for, then no, you will not be able to access anything outside of your computer.
Mar 02, 2010 | EliteGroup nForce3-A Motherboard
How to connect to net via wire and wifi
I'm assuming Windows is the OS. After disconnecting from one access method but before connecting with another (modem to wifi or network wire, etc. the IP address on the notebook will likely not be acceptable to the new connection) open a DOS or Command "Box" or "Window" (go to Start --> Run --> type the word "cmd" or "command" without quotes and then click ok. At the prompt, (without the quotes) type: "ipconfig /release" (You can see all the variables for the ipconfig command by typing "ipconfig /?")
Establish a new connection via hardwire network or wifi and allow the PC obtain a new IP address as normal. If unable to access internet sites, you can try to forcing a new IP address by opening the DOS box again and type "ipconfig /renew" This should cause the machine to get a new IP address. The "ipconfig" commands will probably not force a modem connection to get a new IP address (I haven't run modems for a long time - so I'm not familiar with their procedure of obtaining an IP address)
Oct 09, 2009 | Computers & Internet
Front Panel help for Dell Dimension 4600
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Jun 17, 2009 | Dell OptiPlex 170L PC Desktop
Gateway laptop, can't connect to internet
Network controller in SouthBridge chip on motherboard needs REFLOW or replacement.
Basically board needs service.
Apr 02, 2009 | Computers & Internet
Ep-9npa3 ultra LAN port non-existant
What I need you to do is look at you mother board and tell me what chipset you are running -it should just be the biggest chip on there-
Dec 09, 2008 | EPoX EP-9NPA3 Ultra (EP9NAPA3ULTRA)...
Local area connection, no internet connection
My guess is the LAN port on your motherboard is bad. The simple solution would be to add a PCI ethernet card and disable the one on your motherboard in device manager.
Jun 18, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computers & Internet Logo
27 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
