Question about Homelite Garden
Homelite 23 av will not run wide open
It will start and run BUT will not open up all the way and sputters when full throttle.. what and how do i fix this??
    Sergeant:
  • 322 Answers
Generally when you have a problem at wide open throttle it is a sign of the unit not getting enough fuel. It can be either a simple carburetor adjustment on the high speed side or a kit in the carburetor to replace a stiff or stiffening diaphragm
Posted on Jan 15, 2013
4 Suggested Answers
SOURCE: homelite runs wide open all the time
intake boot under carb is probably bad, mine did the same thing and this was the problem. about a 6 or 7 dollar fix
Posted on Apr 11, 2009
dontbother10
  • 2220 Answers
SOURCE: My 031 AV Stihl Chainsaw idells sporadic
No response to clarification.
Posted on Feb 23, 2010
dontbother10
  • 2220 Answers
SOURCE: homelite timberman only runs wide open
Start with "H" and "L" at 1.5 turns CCW from lightly seated then tune for performance as follows:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 01, 2010
How do you fix liquid locked in a homelite mp88 chop saw
EXTREME Caution should be used. A FIRE can result if this is done improperly !
1) Remove spark plug, ground the plug wire if possible
2) Make sure ignition is in the OFF position
3) NO choke
4) Wide open throttle
5) Shop rag over spark plug hole
6) Pull until no liquid comes out of plug hole
7) Re-install spark plug
8) Continue to pull recoil with throttle open, NO choke
9) Engine will start slowly with huge amounts of smoke, run until the smoking stops.
Feb 15, 2017 | Homelite Garden
Why does homelite chainsaw runs wide open?
if your saying your saw runs full speed as soon as it starts , one of two things is happening :
(1) your low speed carb jet is too far open
(2) your throttle trigger has disconnected or become stuck from your carburetor and now the throttle blade inside carb is full open
Jun 15, 2014 | Homelite Garden
How do I adjust the carburator?
There are two needle screws that can be adjusted to make the engine run properly. Be certain that the carburetor is clean and the diaphragm is in good condition, and the fuel is new. The two needle screws mentioned above should initially be adjusted at one turn open from turned in all the way (lightly seated). Each of these needle screws performs different functions. One is for idle and throttle response (this screw is marked "L" and the other screw is marked "H". L and H are marked on the carburetor body and also on the plastic "shroud" near the adjustment screws. These screws are not interchangeable, being foolproof since the thread sizes are not the same. When properly adjusted the low speed screw (L) allows the engine to idle properly and throttle response will work properly. When the high speed screw is adjusted properly the engine will have correct power at full speed. Adjust the low speed screw so that the engine idles and when you squeeze throttle all the way to wide open the engine should not hesitate and should come up to full speed and when you drop the throttle it should idle nicely without stalling. Now adjust the high speed screw. Hold throttle wide open, holding it there while you adjust the high speed screw. If this scares you (be carefully so that the spinning chain does not cut you!) you may adjust the high speed screw at idle, turning it just slightly in or out. The high speed screw should be adjusted so that the engine does not run clean at wide open throttle but sputters slightly, slightly adjusted open from running clean to slightly sputtering. When under load (cutting a log) the engine should run clean. Good luck!
May 21, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Homelite timberman only runs wide open
im no pro but id start with the throttle stop adjustment and the low speed jet.
screw low jet in, till its fully seated, do not force it. then back it out 1 and 1 / 8 turns. this should get it running and ideling.
Feb 28, 2010 | Garden
Not running at full throttle
close to the carb you will find two tiny screws. They are labeled H and L. L sets the idle speed. H sets the max RPM. Hold the throttle wide open and turn the H screw. When you find the very top end, back it down some or it will be running too lean. That would make it run hot, and provides less lubrication. Could result in engine failure if you run it too lean.
Dec 23, 2009 | Garden
How do I adjust needle valves on a 25cc Homelite UT08111A Backpack leaf blower?
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Oct 23, 2009 | Homelite Consumer Products Backpack...
Homelite saw runs wide open(homelite ut10520)
There is a recall on the UT models, all you have to do is call the costumer service center for homelite. they will give you a number for the closest warrenty center that will adjust you throttle cable free of charge. I went through two UT 10520's before i started researching the problem.
Feb 02, 2009 | Garden
Homelite runs wide open all the time
Nov 13, 2008 | Homelite Garden
Garden Logo
171 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
