Question about Dometic RM2652 Refrigerator
Getting power to frig. then checked the control board not getting any AC current at all. Light will not work on frig. fuses are good inside and out. Any suggestions?
    Top Expert:
  • Dometic Master
  • 5,080 Answers
Check fusible link if ok bad control board
Posted on Oct 06, 2017
SOURCE: dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Posted on Nov 11, 2008
  • 19 Answers
SOURCE: Refrigerator not working
LOWER CIRCUIT BOARD
The controls for Models RM2612, RM2812, RM2652 and RM2852 are unique to these models. They
are NOT interchangeable with any other models.
If you suspect mismatched part numbers, compare the part numbers on parts to the ones listed below
to ensure a proper match.
The RM2612 with Serial Number 41900000 or higher will have Version III controls as original
equipment.
The RM2812, RM2652 and RM2852 should have only Version Ill controls as original equipment.
VERSION I
Display Panel 2932189.01
Power Module 2931842.02 or 2931842.03
Thermistor 2931863035
VERSION II
Display Panel 2932189.02
Power Module 2931842.02X
* Power Module has red plugs and a Red Dot on
the cover.
VERSION Ill
Display Panel 2932189.03
Power Module 2931842.04
Posted on Nov 18, 2008
  • 6 Answers
SOURCE: operates with gas, does not operate with AC.
Check the heater element for power.
Posted on Jul 01, 2009
VtToolMan
  • 704 Answers
SOURCE: Dometic RM2811 stopped getting cold
Here's a link to a step-by-step troubleshooting guide to help you resolve your issue with your fridge.
http://gasrefrigeration.net/does_not_get_cold.htm
Hope you find this helpful and best regards!
Posted on Aug 08, 2009
  • 905 Answers
SOURCE: I have a 2004 Coleman
Hello Barry,
More than likely, your heating element has become shorted to its case, thereby allowing current to flow outside of the neutral, tripping the GFI. If you have a multimeter, you can measure the resistance of the heater itself (AC heater should be 125 ohms, +/-10%). There should not be any continuity between each of the heater wires to the case of the heater itself.
Service Manual
bryantrv.com/docs2/docs/rm2100.pdf
Owners Manual
bryantrv.com/docs2/docs/rm2193.pdf
Posted on Aug 18, 2010
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
Thermal fuse location
It's not a thermal fuse..You're getting power so issue is either the board or the fuse inside the board..that's what you should be looking at..All switches are mainly for safety
Mar 16, 2014 | GE Profile Harmony DPGT750EC Electric...
Domestic Dm2652 will not work on AC without DC power is this correct. We have been camping for a week plugged into 30amp power. Refrigerator worked fine then check light came on and refrigerator...
This is an RV frig correct? It SHOULD work either/or. AC or DC. If your plugged into AC then often the frig will work with that alone. DC is for when you have no AC so you can power your appliances of the battery. Maybe you have a converter (AC to DC which most RV's do) that somehow is not getting the DC to the frig.
Oct 11, 2013 | Dometic RM2652 Refrigerator
Portable AC is completely dead
Technicians trick. Power goes into board but not out.. Bad board. Replace it. The only repair on a PC board should be done but someone who does it everyday. I've made that mistake before.
Jul 02, 2013 | Whirlpool ACP102PS Portable Air...
LG Frig LFC23760ST 3 Door French Refrigerator : No power!
LG LFC23760ST
I recorded a 2 part movie clip on how I repaired the blown fuses on my LG refrig's circuit board.
Mar 31, 2010 | LG LFC23760ST Side by Side Bottom Freezer...
Refrigerator is staying at 50 degrees, will not get any cooler
May be your computer board, not turning on the defrost heaters in the freezer section. The freezer will eventually get warm too. Are you getting frost build-up on the rear wall of the freezer? If you are, you can temporarily solve the problem by turning off the whole refrige for a day and open up the freezer door- put towels on the floor under the freezer doors. Then turn it back on - mine worked fine again. I am currently waiting for a computer board replacement. It is behind the metal plate on the back (outside) of the cabinet. Good luck.
Sep 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Feb 03, 2009 | Dometic RM2652 Refrigerator
I'm getting a SC 558 error
SC558 Abnormal zero
cross signal
- Timing & Condition -
Zero cross signals
generated within certain
period do not reach a
predetermined target
value.
• Poor connections
• Blown fuse
• Defective AC drive board
• Defective main control
board
• Defective I/O control
board
1. Make sure the following are connected
properly:
• CN212 and CN229 on the I/O control
board
• CN303 on the main control board
• CN7 on the AC drive board
2. Check the current through the signal lines
in the above harnesses.
3. Replace the fuse (FU101) if it is blown.
4. Test the AC drive board, I/O control
board, or main control board by checking
the signal line at each pin.
[Signal Check]
• Zero cross: CN7-5 on the AC drive board/
CN229-6, TP216, or CN212-B8 on the I/O
control board/CN303-B4 or TP120 on the
main control board
Any problems get back to me
Than You
Mar 11, 2008 | Ricoh 6513 Copier
Dometic RM2652 Refrigerator Logo
37 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
