Question about Kipor Electrical Supplies
I have a kipor generator with a fault code p-03 which then switches to p-06. The power cuts after a few secs. How do I solve this?
CarlGehrke
  • 169 Answers
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Posted on Feb 23, 2009
adnanbhatti
  • 1188 Answers
SOURCE: Kipor 6700TA displaying charge fault (P5)
Check for loose or rusty battery cables. Unscrew the rear cover and locate the red battery wire. Disconnect it and, using a multi meter, check its resistance: it should have a very low value. Do the same with the other wire.
Start the generator and remove battery wires. If the voltage between them is zero then a fuse is blown.
Next open the front panel (where the display is), there you will find two blue wires with covered fuses, check and replace those fuses if found faulty.
If the problem is still there then it could be the charge regulator. Open the back cover by removing the six nuts. Near the edge you will find a component with silver cover resembling plates. There are three wires leading from it. Check resistance between these wires (one by one) and its body: it should be infinite, if not then replace it. remove the charge regulator and take it to a generator spare shop. The person there will further inspect it and will tell you if you need to replace it or repair it.
Hope this solves your problem.
Thank you for using fixya!
Posted on Aug 20, 2009
  • 905 Answers
SOURCE: I have a kipor ig6000 generator.When i connect my
Your generator is running a bit too fast, and the frequency is greater than 60Hz. Most generators are setup for 62-63Hz no load. You can adjust this at the governor for the engine.
Another possibility is that the alternator is providing electric with a large amount of harmonic distortion, which some appliances don't tolerate well (dirty power). Try adding a noise filter between the generator and espresso maker and see if that helps. The espresso maker may also expect to be grounded, which the generator is not able to provide (unless you are driving a ground rod). The noise filter may also require a ground as well.
Posted on Jan 04, 2010
  • 342 Answers
SOURCE: Iam looking to download a manual for a Kipor KDE
looks very similar to the kde 6700 ta
Posted on Apr 04, 2010
  • 342 Answers
SOURCE: My "KDE19STA3" Kipor generator keeps showing fault "L&H Freq.
this is telling you that the power frequency is above or below the safe limit and so shuts down.
do not run a load but
press the function button and hold then switch on but dont start keep holding until ph2 or similar is displayed then start read the frequency and adjust the engine speed until it reads correct then try will full load and adjust accordingly 1 or 2 hz either way will be ok
My kipor 7000 diesel generator is burning avr. Replaced avr don't last beyond few days. Can someone tell me cause
You need to run these tests in the video to see the state of the alternator. How to test your Electricity Generator AVR Brushes and Alternator on... With this info we can assist you further. :)
The Generator Guru Team
Jan 11, 2017 | Kipor Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Why unit keeps shutting down after it starts.
Your question is general without specific details. Any one of many things will cause your generator engine to stop running.
Is this question about a Kipor KDE5000TA? If so, your generator is powered by a diesel engine. There are safety shut downs built into the generator to protect the generator head and engine. Do you have any fault codes showing on your control panel display screen? (Trouble codes P-01 through P-05 will be displayed if there's a detected fault)
If you have no fault codes, then you likely have a fuel problem. Do the obvious:
  1. Visually check the fuel level in your tank. DO NOT rely on your fuel gauge. It may be stuck or otherwise not working.
  2. If you have fuel, check your fuel filter. It may be clogged. If your fuel filter is good, you may have water contamination.
  3. Drain your tank and refill with fresh #2 diesel fuel. I use "Diesel 911" with a biocide to prevent water contamination and bacteria growth in my fuel.
  4. Make certain your fuel oil supply and return lines are clear, not leaking, and the fittings are tight.
I know I'm shotgunning, peppering the target. However, I don't have enough information to zero in on a specific area where the problem could be. Good luck!
Apr 26, 2015 | Kipor Generator Diesel Kde5000ta
I have generator kipor kde19sta3 when we start then generator after 1 or 2 minutes generator will automatically off and show the fault p 03 so plzzz tell me about p 03 fault thankx
Sounds like an overload on the board. Be sure you're not drawing more amperage out of the plugs on the front of the unit than is listed (typically 12.5 or 20 amps is the limit). If you try and draw more or a surge on the appliance happens during startup, you may end up having to use the 240 volt plug and direct that into a distribution panel to get the 110v unhindered by the plug limitations.
Sep 23, 2013 | Electrical Supplies
I have a kipor power with a fault code p-03 and it shuts off after a cople of secends . what could be the problem.i found in a forum that the posible cause could de the avr put i do not no were its located...
press and hold the function button turn on the ignition and hold until it ges into test mode should display something like ph 2 then start it up and test the output voltage and wether or not it produces power correctly. if it does test the output voltage with a multimeter to confirm the output is the same as displayed on the machine if not remove the control panel and adjust the trim pot on the rear of the display panel until it displays correctly,
if not it could be the carbon brushes in the altenator or the avr which is a black box bolted to the frame
Mar 09, 2010 | Kipor Electrical Supplies
Aug 18, 2009 | Electrical Supplies
My "KDE19STA3" Kipor generator keeps showing fault "L&H Freq.What could be responsible and what can i do? It shuts down about 30seconds after dispalying the fault.
Jun 16, 2009 | Kipor Electrical Supplies
Electrical Supplies Logo
359 people viewed this question
Top Kipor Electrical Supplies Experts
jhnolson
Jay Finke
Jay Finke
Chuck Graybill
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
