Question about Asko D1776 Built-in Dishwasher
Danby DDW497W Dishwasher pump not working - Asko D1776 Built-in Dishwasher
    New Friend:
It could be 3-4 things that are causing this issue,first: something got in pump and jammed it,second:pump is not getting power,remove back plate and check wire plug to pump,push it all way in and see what happens,check flood switch it could be defective and is not activating when unit is turned on,check wire plug to flood switch and make sure is all way in,if pump is not humming or do nothing or no sounds at all,than drain pump is bad or not getting current (power)drain pump should run as soon as you turn on unit,you must check Flood Switch,is on drip pan at the middle,it has styrophone in it,be careful or you can get the shock of your life.Good luck.
Posted on Apr 12, 2013
My danby countertop dishwasher ddw497w turns on, drains the water in the tub, refills and right before it usually fires up. click and nothing. just sits there with no fault code. any ideas before i sm
Hey Derrick,
According to the manual:
http://www.danby.com/cms/documents/pdfs/en/DDW497W_EFSOM.pdf
The most likely cause is the appliance not being leveled properly. Apart from that, I have found no useful information.
If you have a smart phone, try using one of the various, 'Surface Level' apps which will allow you to set your phone on the top of the appliance and then adjust the level until the bubble is centered in the crosshairs.
Hope this helps.
Oct 03, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Why is my danby countertop dishwasher is leaking?
I would check hoses to make sure they are not kinked.... mine also loosened after I pushed it back and had to re-tighten. HTH
Jul 08, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Danby dishwasher faucet adapter
Yes, I have a new portable dishwasher and no adapter, not sure what size to get. model DDW1899WP-1
Jun 25, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
My Danby countertop dishwasher won't wash-the dishwasher detergent is never used at the end of the wash and nothing is clean
Was it working before, and now has stopped working? If so, it sounds like it has poor water circulation. It might be caused by a leak. If you have not noticed a leak, it might be clogging due to hard water deposits. Do you live in a region with hard water?
Feb 10, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
I turned on my Danby countertop dishwasher without water! and now it does not work at all. Someone help me please, how can i fix it!!!
unless it ran for quite a while there should be no damage. plug it into the water, add a few cups of water to the water to fill the sump and prime the pump and turn it on it should work then.
Our danby at home shuts itself off when there is no water so I'm assuming thats what you are seeing.
Aug 23, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
Plexi glass on the inside of danby dishwasher is broken
Try calling the number below - we managed to get parts for our portable dishwasher (after a considerable wait). Dan by Products Inc. 1-800-263-2629 Ext. 212 1-419-425-8627 Fax: 1-419-425-1244
Feb 04, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
Asko D1776 Built-in Dishwasher Logo
85 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
