Question about Maytag MED5820TW Electric Dryer
Push to start switch - Maytag MED5820TW Electric Dryer
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Jump it out ,if it works then replace it
Posted on Jan 16, 2013
Have to push key real hard to start...Will not start at all now
2008 Ford Escape Have To Push Key In Ignition Very Hard ...
www.carcomplaints.com/Ford/Escape/2008/.../have_to_push_key_in_ig...
push key switch in hard to start 2nd time (3 reports) ... Our next step is to replace the lock housing assembly or the ignition lock cylinder. ... The ignition switch on my 2008 Ford Escape randomly turns over -- apparently when it feels like it.
Ford Escape ignition switch no start switch replac - YouTube
? 1:10
https://www.youtube.com/watch?v=bv8tDCf83Vc
Jan 28, 2014 - Uploaded by mosaitogo
Sometimes vehicle would not start when crank/start pos. ...having to push in on the key because the tip of rod is jumping out of switch . .... I currently have my ignition switch dangling down, and I just manually turn it with a screw driver .... Thanks I had this issue since last year with My Ford Escape 2008 but ...
22 Ford Vehicles No crank/ No Start Trick - YouTube
Dec 26, 2015 | 2008 Ford Escape
Motorcycle will push start but not ignition switch start
Does it turn over when trying to start? If no then it could be the starter, switch, or battery. Sounds like the starter, especially if you tried another switch.
Apr 14, 2014 | 2008 kawasaki Ninja 250R
START SWITCH BROKEN
try joining both wires on door push switch then push to start,if it starts then have to change push button on door,or fuse inside blown
Apr 08, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Door is ajar message when shut light comes on but doesnt run
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Nov 27, 2013 | Samsung DV337 Electric Dryer
Bad switch on Electric Started
hello,if it is the one i think it is to where the push button is a closed unit with no screws as far as i know there is no repair for the push button switch,how ever there is a good how to on u tube repairing snowblower electric starters,from what i have seen the push button doesn't go bad,now if the push button comea apart you can repair it which useally the black box or circut thing that cost around $40.00 found on most s 200 blowers,hope this helps,,
Jan 23, 2012 | Garden
When the push start button is pushed in the dryer starts and every thing is ok until you release the button then all stops. I have replaced the bank of push button and just relaced the timer controls.
Good day,
Seems you've covered the timer and push to start switch.
If so then....
The principle the system runs on is, if the timer is turned on, 2 wires come out of it to run the the motor.
The first goes to the push to start switch and when pressed it sends power directly to the motor.
The second wire goes to the motor, but thru a centrifugal switch that must be up to speed before it sends power to the motor.
That is why it continues to run even when you release the start button.
The centrifugal switch is a part of the motor.
Either the centrifugal switch failed, or the power wire to it is disconnected or broken.
Feb 11, 2010 | Washing Machines
I have an older kenmore gas dyer. as soon as the door is shut it starts running with out pushing the start button, and it doesn't shut off till you open the door . is it the start switch or the timer that...
Good day,
It could be either the push to start switch, or the centrifugal switch on the motor. You would need an ohm meter to check the push to start.
The way the system works, is the power goes first to the door switch, and then the timer.
If the timer is in the on position, it sends power out on TWO wires.
One goes to the push to start switch, which in turn goes to the motor, bypassing the centrifugal switch.
The other power wire goes to the centrifugal switch, and thru it to the same place on the motor, but only if the motor is already up to speed.
That's why it under normal conditions it will continue to run when you release the start switch.
Hope that helps.
Thanks for using FixYa
Jan 27, 2010 | Dryers
Kenmore dryer...65852 timer switch does not work. dryer starts on its own when I shut the door and bi passes the push/start dryer button. Can a woman fix this?
Good day,
Ma'm I don't know your mechanical background. So you'll have to be your own judge
One cause could be the contacts in the push to start switch welded together.
Even though it might appear to go in and out properly, the insides of the switch are bad.
Remove the back cover of the consule. Remove one of the wires connected to the push to start switch, and tape up end to prevent shorting.
Plug machine back in and test. If it won't start, then the push to start switch is bad, and needs replaced.
If the push to start switch is not the problem, then it would be the centrifugal switch in the main motor itself. Here is a tutorial on accessing the motor. A major job, with some complications involving the blower wheel.
http://www.applianceaid.com/wpmotor-change.html
P.S. If the dryer performs normally other then the starting problem, there is no reason you cannot use it indefinately
There was a time when dryers had no push to start function.
Proceedure was, with the timer off, and door open, load cloths, set timer, close door. Works great.
Jan 02, 2010 | Dryers
Push to start switch only works when held in.
Go thru the back to access the push to start via 1/4 inch screws. More than likely the push to start isnt the problem with the heat issue. i would lean towards the motor relay and the heater relays that are on this unit
May 27, 2009 | Kenmore 659 Electric Dryer
Maytag MED5820TW Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
