Mistral Mas 101 a/c fan speed does not seem to change
With this problem could there be a capacitor that may be faulty
3 Suggested Answers
SOURCE: Casablanca fan only runs at highest speed
When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
Posted on Jun 22, 2013
Mistral mpac60 Won't cool every thing else seems to work ok just no cool air. Need to find wot causing that
Compressor is not coming on check capacitor could be bad .check wireing going to compressor. Make sure power is off when looking at wireing. Sounds like either capacitor had failed or compressor failed
Mar 01, 2015 | Heating & Cooling
Mistral Mss15 inside fan is working but external compressor is not coming on
does outside fan run? could be capacitor, compressor, or burnt wires. recommend have capacitor tested.
Feb 19, 2014 | Heating & Cooling
Ceiling Fan Repairs
possibly but it is doubtful. It is designed to work all the time but it is possible to fail during use. Replace it or complete fan unit as the motor may be faulty causing the capacitor to overload.
May 05, 2013 | Dryers
I have 2 pcs panasonic Fan buy from 2005 problem speed , please advise how to repair , what component need to replace , My friend also find same problem , why panasonic fan very easy defect
Hello
You are reporting about the lack of speed to your fans I thinks and posts this solution. Normally lack of speed will be due to faulty capacitor. In most cases the value of this capaitor will get reduced. Replace it. Its capacinace value will be markde on it. After replacing the capacitor; till the speed does not get improved, make sure that either start or run windings in the fan has shorted winding in it. If this is the case, the body of the fan will get hot, and a hum sound also will be present. First replace the capacitor and check. If you want any more assistance from me get me by Fixya. OK.
Jun 25, 2011 | Panasonic Dryers
Hi, my mistral (MPAC50 just started coming up with an error code E5. it wont go into airconditing mode and only uses the fan
E5 Outdoor activation of compressor over heatprotection or motor lock
Compressor overheated due to condenser block or fan motor lock. Clean condenser/replace out door fan capacitor.
Dec 30, 2010 | Heating & Cooling
Have a mistral air con, outside unit not working
there is no fuse on your condensing unit outside. pull the disconnect to kill the power to the unit and take off the removable panel above the 2 service valves. there will be an oval shaped capacitor that is marked herm and fan. there will be a rupture disc on the top that may have ruptured. also inspect the low voltage wiring(will still be hot unless you turn off the switch at your furnace). this low voltage wire operates a magnetic coil on the bottom of the contactor that closes a high voltage circuit to the fan and compressor.
Dec 14, 2009 | Heating & Cooling
Hampton Bay Garrison 52" fan stuck on high
nothing wrong with the power supply, or the remote, the speed switch in the fan is faulty, as it is more finiky than a manual speed change(like with a cable)
Jun 15, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hunter 3 speed ceiling fan now turns slowly
Probably a bad capacitor. What model is it? If it completely wireless (in other words: no pull chains for light or fan) the capacitor is located on the receiver for the fan (in the canopy or the lower switch housing). Unless you are handy with a soldering iron, it is easier to purchase a replacement receiver.
Apr 13, 2008 | Hunter Dryers
Uncontrolled CPU fan speed
Make sure you have used the proper Fan connection on the motherboard and that you used all the pins in it. Usually it consists of 3 to 4 pins for CPU fans. Does your Fan have 3 pins? If not then it is not compatible for Fan Speeds. Also check your BIOS for Fan adjustments. Hope this helps.
Sep 15, 2007 | HP Compaq d530 SFF PC Desktop
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
