Question about Bosch Kitchen Ranges
Removing halogen lamp from bosch range hood
Halogen lamp should twist and drop out. There are two pins on the base that slip into keyholes in the socket of the range hood. I can remove one lamp but can't remove the other. It is loose but won't drop out. Any suggestions are welcome.
SOURCE: How do you change a halogen bulb in my dacor range hood
Believe it or not - they just unscrew like regular light bulbs. There is supposed to be a suction cup that came with the hood to replace the bulb - we lost ours. I was able to remove it by using a little bit of pressure on the face of the bulb and twisting it back and forth. The other bulb was stuck, so I made a "handle" using duct tape on the face of the bulb.
Posted on Dec 28, 2007
Cyril J
  • 45 Answers
SOURCE: I need assistance on how
usually you replace the whole fixture ,popping it out and cuttung wires then popping new unit in
Posted on May 16, 2008
shaggyrat
  • 1224 Answers
SOURCE: Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Posted on Jun 01, 2008
SOURCE: oven light exploded and seems fused in socket
I was able to remove the base from the socket by inserting pliers and opening them so that they pressed against the inner sides of the base and then turning while exerting pressure.
Posted on Nov 13, 2008
  • 338 Answers
SOURCE: Halogen bulb melted the socket
most likely a bad socket. if it were bad wiring the problem may have occured somewhere else in the range..
Posted on Jan 20, 2009
My Sirius Range Hood has two lights that take G4 Halogen bulbs. Is there a 115V bulb made for this application or is there something that converts the voltage to 12V?
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb is just as bright but runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Nov 29, 2016 | Sirius Kitchen Ranges
Why does one of the halogen lamps burn out frequently?
Halogen lamps draw considerable current. There may be some defect in the socket such as cracked ceramic or damaged wiring contributing to short life.
Apr 20, 2016 | Zephyr Kitchen Ranges
Instruction manual KuKoocooker hood light bulbs
Just look this youtube video, and it can't be more clear.
Don't forget to unplug the hood, or switch it of. Although the halogen lamps are only 12 volt. In the hood are dangerous voltages. How to replace cooker hood halogen bulb or lamp
Sep 22, 2014 | Kitchen Ranges
Need replacement halogen lights for SU3
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Mar 07, 2013 | Sirius Hoods SU3
DA 399 mEILE RANGE HOOD CANT GET OLD GLOBE OUT TO CHANGE HALOGEN 50 WATT
Remove the grease filters. This will expose the two screws that hold the lamps in. Turn the screws anti clockwise until the lamps drop a little. Twist the lamps gently anticlockwise to release them from the fittings. My instruction manual says reverse the procedure to insert new lamps. Haha. Good luck and be careful.
I had a lot of trouble getting the lamps back in. So much so that I have somehow damaged the fittings or wiring and now have to have a repairman out.... looking at $150 plus just because a light blew!
Feb 01, 2011 | Microwave Ovens
How to change a front turn light in a 1996 taurus.
Lamps, Parking Front Lamp-Lamp Assembly, Taurus
Removal and Installation
  1. Remove Headlamp (13008) as outlined.
Headlamp Assembly
  1. ani_caut.gif WARNING: THE REPLACEABLE HALOGEN HEADLAMP BULB CONTAINS GAS UNDER PRESSURE. THE HALOGEN HEADLAMP BULB MAY SHATTER IF THE GLASS ENVELOPE IS SCRATCHED OR THE HALOGEN HEADLAMP BULB IS DROPPED. HANDLE HALOGEN HEADLAMP BULB CAREFULLY. GRASP HALOGEN HEADLAMP BULB ONLY BY ITS PLASTIC BASE. AVOID TOUCHING GLASS ENVELOPE. KEEP HALOGEN HEADLAMP BULB OUT OF REACH OF CHILDREN.
    Position headlamp switch (11654) and headlamp time delay switch (13736) in the OFF position.
  1. Remove two bolts retaining headlamp (13008) to upper support assembly and loosen pinch bolt. Remove headlamp assembly from vehicle.
  1. Remove park lamp bulb and socket (Sable only) and headlamp bulb and socket from Headlamp Assembly as outlined.
    Headlamp Assembly (Taurus Shown, Sable Similar)
  1. Turn lamp socket and wiring (13410) assembly 1/2 turn counterclockwise and remove from parking lamp (13200) housing.
  1. Remove screw from park/turn signal housing.
  1. Using 1/4 inch drive socket extension and swivel, insert tool through two access holes in upper radiator support. Remove screws from park/turn signal housing.
  1. Remove parking lamp from vehicle.
  1. To install, reverse Removal procedure.
Nov 19, 2010 | Ford Taurus Cars & Trucks
Headlights wont turn on
Hi, check the fuse for the headlight after shutting off your motorcycle.
There is usually a fuse box under or just near the seat area. Sometimes it is located adjacent to the motorcycle battery. Check your user manual for the fuses location.
If that fuse is OK, remove the headlight element and remove the headlight halogen lamp by gently removing the wiring plug and rotating the halogen lamp that is inside, so you can inspect it for damage. A blown halogen lamp is usually indicated by a white or dark spot inside the glass lamp.
If you have a multimeter set it to Ohms and see if you can get a circuit thru the pins on the rear of halogen lamp before re-installing the lamp. There will be 3 pins - one is a common, one is the low beam, and the other is high beam. You should get continuity using ohms thru each separate pin to the common pin.
Make sure you remove any greasy spots on the halogen lamp before you put it back, as this causes hot spots on the glass and is a common cause of early failures of halogen lamps.
If you are comfortable measuring 12 volts DC with a meter, check that you have 12 volts DC at each pin on the harness which connects to the halogen lamp. Your ignition key will need to be turned on so that indicators and horn etc are all powered up. You normally shouldn't have to have your engine running to check power to your headlight, but it is possible that you may need to do so.
There will be 12 volts on 1 pin only and when you change to high beam that pin will then go dead and the other pin will then have 12 volts DC.
There is also a small chance your headlight relay is bad or has a loose connection. If you know what you are doing it should be easy to locate the headlight relay, otherwise take it to a reputable auto electrician or motorcycle repair shop.
Cheers,Steve PS Please vote for my answer or give me a testimonial if I have helped.
Oct 19, 2010 | kawasaki Ninja 250R Motorcycles
How do you replace the light bulbs? There is a lens cover over the bulb.
This is how to replace the lights on the KitchenAid khlu162m hood. If this is not you hood please give the right make and model # so I can get you the right info.
Replacing the Halogen
lamps:
The hood liner uses 12-volt, 20
watt halogen lamp bulbs.
Before you begin, make sure that
the range hood is turned off and
that the lamps have had sufficient
time to cool.
To replace a halogen lamp:
• Remove 2 screws from the
circular metal trim around the
lamp assembly.
• Pull the trim with the lamp
assembly attached down far
enough so that the lamp can be
pushed out of the socket clips.
• Insert the new lamp into the
socket clips and push the lamp
and trim assembly back up into
the hood.
• Replace the screws.
Good Luck and please rate 4 thumbs up for the free answer.
Jun 13, 2010 | KitchenAid KHLU162M Kitchen Hood
Dec 22, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Kitchen Ranges Logo
573 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
