Question about Pool & Spa
Aerware Hot tub. Temperature displays shows 8888. How do you reset?
2 Suggested Answers
  • 37 Answers
SOURCE: savannah spas
probably a dirty filter!! take it out turn tub off to reset turn back on with filter out and c if nthis solves problem if so replace filter.
Posted on Dec 05, 2009
Filled hot tub with cold water but error 98 comes up on display saying water to hot and wont reset
Julie Palmer... hello,
Somewhere you got a THERMOSTAT that is giving a bogus reading (on a fairly nominal temperature)...
You are going to have to find it... and most likely replace it.
https://www.bing.com/search?q=hot+tub+thermostat&form=EDGEAR&qs=PF&cvid=6bf0d109ca4a4c49b09ff562b296ea64&pq=hot%20tub%20thermostat&PC=DCTE
May 25, 2016 | Pool & Spa
My hot tub control panel says 8888. Can someone please tell me how to reset it.
Disconnect all power from unit. Line voltage and low voltage. then turn back on.
Jul 21, 2015 | Pool & Spa
Why is hot tub over-heating past max temperature?
Sounds like a problem with the thermostat.
Aug 05, 2014 | Jacuzzi Home
BEACHCOMBER HOT TUB NO DISPLAY
This could be failure of the display, the controller, or both.
Dec 12, 2013 | Jacuzzi Pool & Spa
Infinity maax hot tub
all systems must be working or the spa will not heat. If one of the sensors is not functioning then the spa water will not heat.
Rod
US Parts Center
Nov 25, 2013 | Home
Samsung microwave displays 8888 beeps then 6666
how can i fix this problem i have an air conditioner whit the same problem and don t work please help me here are very hot
Jun 20, 2012 | Microwave Ovens
My Oaisis II hot tub stays at 103 and now it's dropped down to 68 degrees for the past 3 days? Could there be a problem with my heater element? Or is there a sequence of resetting the temp buttons on top...
Information on the care of your product and troubleshooting is available here:
http://www.oasisleisure.ca/customer_care/SpaCare.html
Did you have a recent power outage? It is necessary to reset the temperature after a power outage.
Check the temperature setting on your hot tub; if it has defaulted do to a power outage reset to the desired temperature. If it is still set at your desired setting and is operating at 68 degrees then there is a problem that is preventing the tub from reaching the set temperature.
Some possible causes and actions are:
Pull filter (see if light comes on) / Replace filter
Knife valves not fully open / Open knife valves
Pressure switch cut of calibration / Adjust pressure switch
Faulty Pressure Switch / Replace pressure switch
Air leak, check pump suction line / Tighten pump union
Heating element corroded / Replace element
Faulty control panel / Replace panel
Find the Manual for you specifc model for more explansyion on Troubeshootig.
Feb 06, 2011 | Home
The scale displays 8888 every time you stand on it. If you go to choose p1 it flashes data. Can seem to get the scale to reset using the instructions and removing batteries does nothing
I have a "Thinner" scale. You have to put a little weight on it to activate, it will show 8888. Don't step on, wait a few seconds and it will change to 0000, then step on.
Jan 05, 2011 | Conair WW81 Weight Watchers Body...
GE PFSS6PKW Displays 8888
Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel.
May 10, 2010 | GE PFSS6PKSS
Savannah spas
Nov 20, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pool & Spa Logo
89 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
