Question about Sharp LC-32D64U LCD TV
Sharp LC-32GA8E connecting to PC using HDMI
I wanted to connect my PC, using a GTX560, to my Sharp television but when i do and i set my PC resolution to 1920x1080 my screen doesnt fit. This means that i cant see my Taskbar, i've been trying all sorts of things now for the past two hours but i can't seem to figure out how to make my screen fit. Any suggestions? Thanks in advance
JMuskovitz
  • 135 Answers
SOURCE: How to connect my Sharp LC-26DA5U to my computer as a monitor
There are two possible problems: 1. You are connecting a 15-pin (on the laptop) to the 9-pin (on the TV) connection. This isn't the video-in connection for the TV. The TV has a DB-15 connection near its DVI input connector. You should be using a 15-pin to 15-pin cable. The DB-9 connector on the TV is a serial port for servicing the TV. 2. You aren't enabling the external video port for the laptop. Try hitting Fn+F5 on the laptop to cycle between the three display modes: laptop only, laptop + TV, TV only. Make sure to wait a few seconds after hitting Fn+F5 to let the displays sync up.
Posted on Feb 21, 2007
SOURCE: aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Posted on Dec 06, 2007
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
  • 3 Answers
SOURCE: Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Posted on Jun 26, 2009
Where is the HDMI connection on my Sharp LC-46SB57? I installed X1 and cannot get picture. Sharp Input 1,2&3 are grayed out but Inputs 5Roku & 6blue ray work.
The X1 box acts like a set-top cable box. The HDMI output can be connected to any HDMI connector. There are three HDMI connections on the rear of the set. You have the Blu-Ray connected to one of them, Input 6. You should have no issues with connecting the X1 to either Input 7 or Input 8. There is no specific "TV" HDMI connection. You simply use the remote to select the HDMI port that the X1 is connected to.
Nov 18, 2015 | Sharp Televison & Video
Hdmi connection
sounds like your TV is not compatible to ps3..or you can try to adjust your resolution
Jul 23, 2012 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have a Sharp LC46D65E and ant to connect it by HDMI on my Acer laptop with ATI HD5470 Wich screen resolution should i use and which bit and rate? I do not want to damage the screen but als want a HD...
You can't damage the screen. Connect the cable and go thru the 1080 options. See which one fits the screen. If it's wrong for the TV a message will pop up saying so.
Aug 06, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a Sharp LC-42D62U and have our DVR from cable connected to HDMI #4. I want to hook up a Roku via HDMI to HDMI #5 but the input source shows unavailable sign. Is there a way to get both HDMI...
If your Tv has this many HDMI ports it will have a menu to access each one separate. Go to your Tv's settings menu and look for your HDMI ports to use.
Jul 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to connect tv to my hp pc
First you need to know what type of physical connection you're using. You have may options, depending on your video card (if you got one separate from the onboard video: VGA-VGA, DVI-HDMI, or HDMI-HDMI). Make sure you set your TV's input to the correct connection (i.e. HDMI, or VGA). Turn you PC on and it should work, if it's not, the problem is probably your PC was set to a resolution that the TV could not display. A quick fix for this is to plug in the old monitor that you were using and set it to a lower resolution. Shut off, plug in the TV, and turn on.
Jul 27, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a HP Notebook I connecedt it to a LC-19SB24U(Sharp) using a HDMI cable, I want the desktop to show on the TV, How do I do that?.
right click on the notebook screen go to "Settings" or if Windows7 go to screen resolution. in there you should see the option to connect to a projector.
Mar 10, 2011 | HP Computers & Internet
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My sharp LC-19DV22U Will not connect to my PS3
well alex welcome to fixya technical support online.i just read your problems. there is an option to your problem you can use another cables with RCA inputs capable in your PS3 that can works on videos and also you can buy video converter. thanks!
Aug 14, 2009 | Sharp LC19DV22U 19 in. LCD Television
Aquos lc-26ga5u to mac mini
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
Sharp LC-32D64U LCD TV Logo
78 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
