Question about Refrigerators
I have kenmore refrigerator 253.56519400 and stop to cooling
It running but do not cooling
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
SOURCE: bkenmore refrigerator blower running. not cooling
for this you have to open the back pannel and only the technician knows the skill, so please call the nearby authority................have a nice day :-)
Posted on Jun 15, 2009
dmftrucker
  • 1922 Answers
SOURCE: Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Posted on Nov 01, 2009
Testimonial: "That's what my fridge is doing? Thanks for the help."
woodchuck789
  • 4070 Answers
SOURCE: kenmore refrigerator stop cooling but fan working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Posted on Apr 06, 2010
drsn
  • 42 Answers
SOURCE: My Kenmore refrigerator model 253.6419240N
you would probably need to replace the defrost thermostat sensor......it is probably defective.....its a sensor that detects temps and shuts down the compessor when temps are satisfied.....now your unit just keeps workin, and working, and working and never shuts down....until the compressor overheats and shuts down due to the overload protector kickin in.............
you will need to open the back panel in the freezer compartment.....unplug unit first........take out panel and unplug harness.......there should be a round sensor that clips onto the copper pipe............it should have two wires coming out of it..........unclip it from the pipe............cut the wires at least one inch from the clip......wires should be orange/yellow or blue/brown......just cut the wires that comes out from it........do not be confused of the other two wires.................get your model number and source for a replacement part....or just purchase a universal replacement......just resplice wires follow the color codes,yellow to yellow and orange to orange....and use wire nuts and black tape afterwards and install panel and test unit.....observe it for 24 hours....................................
note evaporator coils are very sharp be careful and safe at all times.......
a feed back would be good if this helps.................
Posted on Jun 07, 2010
Refrigerator has stopped cooling. fan still running and compressor is warm. what is wrong?
Several things could be wrong. The simplest is that the coils under the refrigerator are dirty with dust and need cleaning; or other parts may not be working properly. Go to the link below for a video that discusses the operation and various components of the refrigerator. Good luck. Kenmore Refrigerator Not Cold Enough
Oct 16, 2014 | Kenmore Refrigerators
Water pooling below the crisper drawers at bottom of the fridge. Kenmore model #363.79262991
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Kenmore Top Freezer Refrigerator
Model 596.72232200, s/n 10428892ap - top section stopped cooling, but the freezer (bottom) is OK.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Feb 11, 2011 | Kenmore Refrigerators
Refrigerator stopped cooling but freezer is fine. what could cause this and will it be expensive to fix?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 16, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
