I have a Sanyo PLV-Z700 and after a short circuit the "replace lamp" indicates. Before it was working well. So I don't think that the lamp has to be replaced. Do you have any idea what to do?
2 Suggested Answers
SOURCE: We have a Sanyo PLV-55whd1.
You have to pull the chassis out and it sits on top. Also there are 2 squirrel cage fans that cool the bulb, be sure to blow these out, especially the supply fan, its gets caked up really bad and then there no air to the bulb which makes the thermal switch trip. Theres also two other computer type fans a larger on which is out in the open on the right side and a smaller on on the left as viewed from the rear of the TV. The small one is burried, you will need to pull the tuner to get a good crack at it.
Posted on May 30, 2011
PLV-Z2000 Projector Your question about PLV-Z2000
what about the Projector Condition leds: POWER, WARNING and LAMP REPLACE? How are they lit? For good measure you should also clean the air filter (the projector might not be getting enough air to cool the lamp)
Jan 09, 2012 | Sanyo PLV-Z2000 Projector
Hi, I 've the following problem with my PLV-Z2. When I turn on the PLV, the red light is flashing, then when the light is fixed, I push on the main button, the light turn on green. Then the main lamp...
There may be a burnt capacitor on the circuit board. If you are savy in electronics and soldering you may be abel to replace yourself if you can determine which one it is and find an exact replacement. I don't believe there are too many on the board. Otherwise take to a repair shop and have them check out the capacitors.
Apr 22, 2011 | Sanyo PLV-Z2 Multimedia Projector
MY SANYO plv-z700 HAS A FILTER WARNING COMING ON THE SCREEN EVERY NOW AND THEN. WHAT DOES THIS MEAN AND HOW DO I FIX IT?
It might mean the temperature sensor is detecting that the interior temperature or lamp temperature is too hot and asking you to clean the filter or filters. The internal fan will blow air out one side and pull fresh air in on the other side. Check the side with the air going in and see if there is a foam filter. It should easy to remove. I clean mine in the sink and dry with a paper towel.
Feb 12, 2011 | Sanyo PLV-Z700 LCD Projector
Looking for replacement lamp for Sanyo PLV-WHD1 TV Lamp type # POA-LMP96 service parts # 6103227382. Need some help finding one that is compatible for reasonable price.
You can get replacment lamps for this TV from www.TvRepairKits.com
Models Supported = PLV-55WHD1, PLV-65WHD1, PLV55WHD1, PLV65WHD1 ,PLV-55WR2C, PLV-55WR2CH POALMP96 , POA-LMP96 , 6103227382. and more.
Feb 03, 2011 | Sanyo Genuine Original 6103227382 ...
I have an PLVZ700 that is showing a faint yellow circle in the middle of the image
The Blue LCD has burnt due to either an old lamp or poor ventilation/blocked filters.
There is no cure for this except a replacement blue LCD panel is required. It is a specialized job and cannot be attempted by some one without the tools and experience.
Cleaning the filters may stop anymore deteriation.
Jan 05, 2011 | Sanyo PLV-Z700 LCD Projector
Just replaced the lamp on a sanyo plv-z4 and it still indicates lamp needs replacement. what do i do now?
reset your lamp counter. go to the menu find lamp setting. then reset. click OK 3 times
Oct 07, 2009 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo plv-z1 wont turn on
Hi
This is normally a clear indication that the lamp is in need of replacement.
Take out the lamp and check for any damage like discolouration or bubbles just to make sure before you invest in a new lamp.
Apr 19, 2008 | Sanyo PLV Z1 Multimedia Projector
18 people viewed this question
k24674
jasbo
jasbo
